asr9k interchasis configuration?
Umit AYDINLI
Hi Experts,
I have two set ASR 9006 Chassis=2 x RSP 440, 4x4TE Line cards. Active software XR 5.4.3
I have 4 service providers, 2 cloud operators connection. I need a backup hardware.
I want to backup and redundancy for the ASR9K chasies. I'm looking the configuration example but I can't find.
Could you explain how to possible interchassis redundancy for the ASR9K?
tkarnani
Hi Umit,
there is the nv cluster solution, however it is not really supported anymore.
https://community.cisco.com/t5/service-providers-documents/asr9000-xr-cluster-nv-edge-guide/ta-p/3151344
we can also do MC-LAG if your connection to the provider is layer 2
https://community.cisco.com/t5/service-providers-documents/asr9000-xr-multichassis-lag-or-mc-lag-mclag-guide/ta-p/3133825
tkarnani
Hi Umit,
As Tarun mention nv edge is the only real method of clustering (vPC / multichassis / etc) available but its unsupported after 5.3.4.  It is only supported with RSP440 and -TR -SE tengige cards.
MC-LAG is one alternative but config heavy as you need to offload 1 set of VLANs to one ASR9K and the other set to the other ASR9K for active/standby.
Another alternative would be EVPN which is an active/active method with dual routers.
Sam
