Hi Experts,
I have two set ASR 9006 Chassis=2 x RSP 440, 4x4TE Line cards. Active software XR 5.4.3
I have 4 service providers, 2 cloud operators connection. I need a backup hardware.
I want to backup and redundancy for the ASR9K chasies. I'm looking the configuration example but I can't find.
Could you explain how to possible interchassis redundancy for the ASR9K?
Solved! Go to Solution.
Hi Umit,
there is the nv cluster solution, however it is not really supported anymore.
we can also do MC-LAG if your connection to the provider is layer 2
Hi Umit,
As Tarun mention nv edge is the only real method of clustering (vPC / multichassis / etc) available but its unsupported after 5.3.4. It is only supported with RSP440 and -TR -SE tengige cards.
MC-LAG is one alternative but config heavy as you need to offload 1 set of VLANs to one ASR9K and the other set to the other ASR9K for active/standby.
Another alternative would be EVPN which is an active/active method with dual routers.
Sam
