01-15-2015 04:10 PM
hi, all:
i was wondering if you could help out. I'm having a problem where i have an interface in up/up state, but when i configure an l2transport subinterface it doesn't come up/up. I was under the impression that as long as the parent interface is in up/up state, the subinterface will assume the same state.
RP/0/RSP0/CPU0:XXXXXX#show run int ten0/1/1/3
Thu Jan 15 23:58:38.452 UTC
interface TenGigE0/1/1/3
cdp
RP/0/RSP0/CPU0:XXXXXXX#show int ten0/1/1/3
Thu Jan 15 23:58:46.028 UTC
TenGigE0/1/1/3 is up, line protocol is up
Interface state transitions: 9
Hardware is TenGigE, address is 5087.8933.5bdf (bia 5087.8933.5bdf)
Layer 1 Transport Mode is LAN
Internet address is Unknown
MTU 1514 bytes, BW 10000000 Kbit
[snip]
RP/0/RSP0/CPU0:XXXXXX#show run int ten0/1/1/3.2
Fri Jan 16 00:05:25.210 UTC
interface TenGigE0/1/1/3.2 l2transport
encapsulation dot1q 2
TenGigE0/1/1/3.2 is up, line protocol is down
Interface state transitions: 1
Hardware is VLAN sub-interface(s), address is 5087.8933.5bdf
Layer 2 Transport Mode
MTU 1518 bytes, BW 10000000 Kbit (Max: 10000000 Kbit)
reliability Unknown, txload Unknown, rxload Unknown
Encapsulation 802.1Q Virtual LAN,
Outer Match: Dot1Q VLAN 2
Ethertype Any, MAC Match src any, dest any
loopback not set,
RP/0/RSP0/CPU0:XXXXXXX#show run int ten0/1/1/3.93
Thu Jan 15 23:59:17.707 UTC
interface TenGigE0/1/1/3.93 l2transport
description PRUEBAS MARCATEL
encapsulation dot1q 93
rewrite ingress tag pop 1 symmetric
RP/0/RSP0/CPU0:XXXXXXXXX#show int ten0/1/1/3.93
Thu Jan 15 23:59:47.401 UTC
TenGigE0/1/1/3.93 is up, line protocol is down
Interface state transitions: 7
Description: PRUEBAS MARCATEL
stuff like cdp works over the 10G link:
RP/0/RSP0/CPU0:XXXXXXXXX#show cdp ne
Fri Jan 16 00:02:32.009 UTC
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
S - Switch, H - Host, I - IGMP, r - Repeater
Device ID Local Intrfce Holdtme Capability Platform Port ID
XXXXXXXXXX Te0/0/0/0 179 R ASR9K Ser Te0/0/0/1
ME38001 Te0/0/0/1 148 R S I ME-3800X- Te0/1
ME3600 Te0/1/1/3 150 S I ME-3600X- Te0/1
XXXXXXXXXXX Te0/1/0/0 120 R ASR9K Ser Te0/0/0/1
Seems weird to me, since we haven't had this happen before at all. Might be something very simple, but I cannot find it. On the other side I have a 3600 configured like this:
interface TenGigabitEthernet0/1
switchport trunk allowed vlan 2
switchport mode trunk
speed nonegotiate
Any ideas would be appreciated.
c.
10-14-2015 04:41 PM
Sub-int dot1q, dot1ad, qinq protocol are down on WX with 20x1GE EP
11-04-2015 10:00 PM
Hi Ehsan
thanks for the bug info
As per the bug workaourd we reset the process l2vpn_mgr and vlan_ma but situation is still there, sub-interface are in UP Down state.
11-05-2015 03:03 AM
hi Prakash,
is there a TAC SR opened for this? It would be the best to continue the troubleshooting through a TAC SR.
regards,
Aleksandar
11-05-2015 03:08 AM
If I read it correctly, the issue is observed in XR 510 is that correct? Based on the symptom and details that I see the DDTS referenced CSCuj28971 is very much the suspect here.
It is somewhat of an undesirable scenario to run 510. It might be best to verify this with 513. If the issue persists there (unlikely) then we can investigate and smu it on the EMR. The 510 is end of maintenance already.
I think the best advice to give here is to go with 513.
regards
xander
11-05-2015 03:14 AM
We are palnning for the newer version but its pending due to some test case left .. and that will take time.
Will the reload of the router resolve the issue ?
11-05-2015 03:26 AM
hi Prakash,
Router reload will clear the 'node down' condition described in CSCuj28971. If you know what was the trigger, repeating that trigger should be avoided until the router is upgraded. Are you evaluating 5.1.3 or 5.3.3 for the upgrade?
regards,
Aleksandar
11-05-2015 03:28 AM
yeah I wanted to add that if you are considering a reload, it might be worth combining that with running 513/SP<latest> that way you solved the problem first as aleks described and second you have mitigation in place with the fix discussed.
but I understand that some sw changes require some extra validation/verification first also.
anyways, reload will help mitigate the situation today.
xander
11-05-2015 07:52 PM
Thanks Thujus
will update it when we complete the activity
11-05-2015 07:53 PM
I go for the reload and let u know the observations
01-15-2015 05:37 PM
Do you have the configuration and outputs from the other side of the link?
It happens to me once, with 4.0.3, and was because in the other side of the link i dont have any sub-interface with the same dot1q encapsultation.
01-15-2015 05:58 PM
I posted the config on the other side of the link. It's a dot1q trunk that allows the same vlan as the subinterface on the asr9k. Interface is up on the other side, of course, since CDP is working.
