Highlighted
[asr9k] interface up, but (l2transport) subinterface down
hi, all:
i was wondering if you could help out. I'm having a problem where i have an interface in up/up state, but when i configure an l2transport subinterface it doesn't come up/up. I was under the impression that as long as the parent interface is in up/up state, the subinterface will assume the same state.
RP/0/RSP0/CPU0:XXXXXX#show run int ten0/1/1/3
Thu Jan 15 23:58:38.452 UTC
interface TenGigE0/1/1/3
 cdp
RP/0/RSP0/CPU0:XXXXXXX#show int ten0/1/1/3
Thu Jan 15 23:58:46.028 UTC
TenGigE0/1/1/3 is up, line protocol is up
  Interface state transitions: 9
  Hardware is TenGigE, address is 5087.8933.5bdf (bia 5087.8933.5bdf)
  Layer 1 Transport Mode is LAN
  Internet address is Unknown
  MTU 1514 bytes, BW 10000000 Kbit
[snip]
RP/0/RSP0/CPU0:XXXXXX#show run int ten0/1/1/3.2
Fri Jan 16 00:05:25.210 UTC
interface TenGigE0/1/1/3.2 l2transport
 encapsulation dot1q 2
TenGigE0/1/1/3.2 is up, line protocol is down
  Interface state transitions: 1
  Hardware is VLAN sub-interface(s), address is 5087.8933.5bdf
  Layer 2 Transport Mode
  MTU 1518 bytes, BW 10000000 Kbit (Max: 10000000 Kbit)
     reliability Unknown, txload Unknown, rxload Unknown
  Encapsulation 802.1Q Virtual LAN,
    Outer Match: Dot1Q VLAN 2
    Ethertype Any, MAC Match src any, dest any
  loopback not set,
RP/0/RSP0/CPU0:XXXXXXX#show run int ten0/1/1/3.93
Thu Jan 15 23:59:17.707 UTC
interface TenGigE0/1/1/3.93 l2transport
 description PRUEBAS MARCATEL
 encapsulation dot1q 93
 rewrite ingress tag pop 1 symmetric
RP/0/RSP0/CPU0:XXXXXXXXX#show int ten0/1/1/3.93
Thu Jan 15 23:59:47.401 UTC
TenGigE0/1/1/3.93 is up, line protocol is down
  Interface state transitions: 7
  Description: PRUEBAS MARCATEL
stuff like cdp works over the 10G link:
RP/0/RSP0/CPU0:XXXXXXXXX#show cdp ne
Fri Jan 16 00:02:32.009 UTC
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
                  S - Switch, H - Host, I - IGMP, r - Repeater
Device ID       Local Intrfce    Holdtme Capability Platform  Port ID
XXXXXXXXXX Te0/0/0/0        179     R          ASR9K Ser Te0/0/0/1
ME38001        Te0/0/0/1        148     R S I      ME-3800X- Te0/1
ME3600          Te0/1/1/3        150     S I        ME-3600X- Te0/1
XXXXXXXXXXX Te0/1/0/0        120     R          ASR9K Ser Te0/0/0/1
Seems weird to me, since we haven't had this happen before at all. Might be something very simple, but I cannot find it. On the other side I have a 3600 configured like this:
interface TenGigabitEthernet0/1
switchport trunk allowed vlan 2
switchport mode trunk
speed nonegotiate
Any ideas would be appreciated.
c.
25 REPLIES 25
Highlighted
Just in case:
RP/0/RSP0/CPU0:XXXXXXXX#show ver brief
Fri Jan 16 00:10:40.743 UTC
Cisco IOS XR Software, Version 5.1.2[Default]
Copyright (c) 2014 by Cisco Systems, Inc.
ROM: System Bootstrap, Version 0.71(c) 1994-2012 by Cisco Systems,  Inc.
PE_CU uptime is 10 weeks, 5 days, 6 hours, 33 minutes
System image file is "disk0:asr9k-os-mbi-5.1.2/0x100305/mbiasr9k-rsp3.vm"
cisco ASR9K Series (Intel 686 F6M14S4) processor with 6291456K bytes of memory.
Intel 686 F6M14S4 processor at 2126MHz, Revision 2.174
ASR 9010 DC Chassis with PEM Version 2
4 Management Ethernet
88 GigabitEthernet/IEEE 802.3 interface(s)
16 TenGigE
16 DWDM controller(s)
16 WANPHY controller(s)
503k bytes of non-volatile configuration memory.
6111M bytes of hard disk.
12510192k bytes of disk0: (Sector size 512 bytes).
12510192k bytes of disk1: (Sector size 512 bytes).
Highlighted
Is the subinterface "tied" with any other configuration element?
bridge domain with a BVI?
xconnect?
VPLS?
Highlighted
It was at some point, we ended up deleting the whole l2vpn section and starting from scratch.
In the end, a reload of the mod80 fixed the whole thing. not cool.
Highlighted
hi Carlos,
yeah that is not cool, and normally this doesn't happen, if the phy interface is up, the sub interfaces unless using BFD should be up as well, no question about it. What has likely happened is an interface creation error. There were some known ddts related to that in XR 51. but it is hard to say without traces what the precise issue is.
the show tech ethernet interfaces will probably help as it captures the traces from the creation/deletion and may have a clue there.
However after a reload that detail is gone, but if this happens again I would recommend capturing that trace file and open a tac case to relate it to either a known or new issue so it can be taken care of.
cheers
xander
Highlighted
actually, we have 2 mod80s on same box, doing the exact same thing. i don't think my co-worker reloaded both, so next step is seeing if the other is still doing the same thing and going straight to tac.
we've seen some funky stuff in the past 2 months on 5.1.2.
Highlighted
yeah hey carlos, if you can, look at XR513, it is rather solid and has a lot of fixes. It is also the EMR / extended maintenance release which longetivity and excellent smu/service pack support.
yeah please report back when if you have a repro or captures.
cheers!
xander
Highlighted
yeah, i've been thinking 5.1.3 for the past 2 months. we might have to look into that, after checking with tac about this last happening.
thanks for the advice.
while on this: for 5.1 and service packs, does it still have this behavior where every SP requires a reload and you can't mix and match SPs with SMUs (it's either or)?
Highlighted
Service packs still require a reload for installation that is correct.
You can apply individual smu's on top of a service pack also, I would recommend only doing that for time critical issues that need to be addressed "now", but for ease of use/management etc and all that it is best to stay with service packs when you decide to go down that path.
I am sure you are aware; CSM/cisco software manager is a great tool to help with the SMU scheduling and implementation too if you prefer to keep individuals as opposed to SP's.
cheers
xander
Highlighted
I ran into the same issue, below is my logs. I am using VIRL -
RP/0/0/CPU0:NCS1#show run int gi0/0/0/1.10
Tue May  9 18:36:12.250 UTC
interface GigabitEthernet0/0/0/1.10 l2transport
 mtu 8918
RP/0/0/CPU0:NCS1(config-if)#do sh ver brief
Tue May  9 18:31:08.561 UTC
Cisco IOS XR Software, Version 6.1.2[Default]
Copyright (c) 2016 by Cisco Systems, Inc.
RP/0/0/CPU0:NCS1(config-if)#do sh ip int bri
Tue May  9 18:30:31.753 UTC
Interface                      IP-Address      Status          Protocol Vrf-Name
GigabitEthernet0/0/0/1         unassigned      Up              Up       default
GigabitEthernet0/0/0/1.10      unassigned      Up              Down     default
Initially the sub-interface was meant to be used under L2VPN xconnect config but even after removing it from L2vnp config; sub-interface is still down. Other side which is SR7750 however shows UP/UP.
Interface
If Name          : Sub_NCS
Admin State      : Up                   Oper (v4/v6)      : Up/--
Amit
Highlighted
Hi Thuijs
We have faced the same issue with L3 sub-interface and replaced the SPA card this has not resoleved the issue and we are running 5.1.0
RP/0/RSP0/CPU0:KABANMALSAR02C9010#sh int des | i 0/5/1
Thu Oct  8 17:18:56.427 IST
[KTe0/5/1/0          down        down
Te0/5/1/1          up          up          "TESTING"
Te0/5/1/1.100      up          down
RP/0/RSP0/CPU0:XXXXXC9010#sh int des | i 0/5/1
Te0/5/1/0          down        down
show tech ethernent interface is attched we have raised a tac case for the same ...
let us know if you require anything
Highlighted
hi kalsaria,
you have a sip700 with an ether spa? that is not a supported combination, you'd need to run ether on the tyhpoon or tomahawk linecards.
the sip700 can be used for pos, atm or channelized spa's only.
xander
Highlighted
We have tyhpoon card and on 1 SPA card it working and on second SPA card its not working.
for module 0/5/0 -- sub-interface are in UP UP state
for module 0/5/1 -- sub-interface are in UP Down state
Highlighted
Hi Prakash,
are you using a MOD80-SE? have a look on DDTS: CSCuj28971
Ehsan
Highlighted
Yes we using MOD80-SE
for the bug i have insufficient rights can you paste the content of the BUG
