12-10-2015 06:29 AM
I am trying to implement both nv satellite and nv edge on two ASR 9006 devices (running 4.2.3). nv edge is working fine and but satellite is not coming up.
Output is
RP/1/RSP0/CPU0:ios#sh nv satellite status
Thu Dec 10 14:15:02.059 UTC
Satellite 100
State: Halted; Conflict: interface is down
Type: asr9000v
IPv4 address: 10.10.10.1
Configured satellite fabric links:
TenGigE0/0/1/0
State: Discovery halted; Conflict: interface is down
Port range: GigabitEthernet0/0/0-43
Can anyone give me the sample config for nvc edge with nv satellite.. Can any one please help me troubleshoot this.
12-10-2015 06:43 AM
The error seems to indicate that ten0/0/1/0 is down.
For cluster just remember that it is treated the same as single-chassis since its one logical system. For dual-homing (rings and such) two standalone 9Ks must be used.
Can you paste the show run nv and show run interface ten0/0/1/0 outputs?
Also include the show controller tengige 0/0/1/0 phy output.
Sam
12-10-2015 07:21 PM
Thanks sam for your reply. Please find the required output below
RP/1/RSP0/CPU0:ios#sh run nv
Fri Dec 11 03:15:57.263 UTC
nv
satellite 100
type asr9000v
ipv4 address 10.10.10.1
RP/1/RSP0/CPU0:ios#sh run int tenGigE 0/0/1/0
Fri Dec 11 03:16:29.936 UTC
interface TenGigE0/0/1/0
nv
satellite-fabric-link satellite 100
remote-ports GigabitEthernet 0/0/0-43
RP/1/RSP0/CPU0:ios#sh controllers tenGigE 0/0/1/0 phy ?
| Output Modifiers
<cr>
Fri Dec 11 03:16:58.734 UTC
XFP EEPROM port: 0
Xcvr Type: XFP
Ext Type: 1.5 W, CDR Supported, No Tx Ref Clk input req., CLEI present,
Connector Type: LC
Ethernet Xcvr Codes: 10GBASE-SR,
SONET Xcvr Codes:
Encodeing: 64B/66B, NRZ,
Bit Rate Min.: 9900 Mbit/s
Bit Rate Max.: 10500 Mbit/s
Link Reach 50u EBW fiber: 300 meter
Link Reach 50u fiber: 82 meter
Link Reach 62.5u fiber: 33 meter
Device Tech.: 850 nm VCSEL, No wavelength ctrl, Uncooled Xmtr, PIN detector, Xmtr not tunable,
Vendor Name CISCO-FINISAR
CDR Support: 9.95 Gb/s, XFI Loopback Mode,
Vendor OUI: 00.90.65
Vendor Part Number FTLX8511D3-CS (rev.: B )
Wavelength: 850.000 nm
Wavelength Tolerance: 10 nm
Vendor Serial Number: FNS15491DPH
Date Code (yy/mm/dd): 11/11/30 lot code:
Diagnostic Monitoring: FEC BER not supported, average Rx power measured,
Enhanced Options: Soft TX disable, Soft Power-down,
Extended Id: XFP (0x00 )
MSA Data (Table 01)
0x0080: 06 18 07 80 00 00 00 00 : 00 00 00 90 63 69 00 96
0x0090: 52 21 00 00 43 49 53 43 : 4f 2d 46 49 4e 49 53 41
0x00a0: 52 20 20 20 81 00 90 65 : 46 54 4c 58 38 35 31 31
0x00b0: 44 33 2d 43 53 20 20 20 : 42 20 42 68 07 d0 46 5a
0x00c0: 4b 96 04 00 46 4e 53 31 : 35 34 39 31 44 50 48 20
0x00d0: 20 20 20 20 31 31 31 31 : 33 30 20 20 08 60 70 8b
CLEI Code: COUIARMCAA
Part Number 10-2410-01 (ver.: V01 )
Temp/Alarm/Power Flags: COM, commercial -5C to 70C
Product ID: XFP-10G-MM-SR
Cisco Specific Data (Table 02)
0x0100: 43 4f 55 49 41 52 4d 43 : 41 41 31 30 2d 32 34 31
0x0110: 30 2d 30 31 56 30 31 20 : 01 00 00 00 00 00 00 00
0x0120: 00 90 00 00 00 00 00 00 : 00 00 5d 00 66 00 6e 00
0x0130: 82 00 00 00 1d 9e 0e 58 : 18 7f 00 6b 00 00 aa aa
0x0140: 58 46 50 2d 31 30 47 2d : 4d 4d 2d 53 52 20 20 20
0x0150: 20 20 20 20 00 00 00 00 : 00 00 00 00 00 00 00 3c
0x0160: 32 35 35 34 36 36 38 31 : 00 a5 00 00 00 00 00 00
0x0170: 00 00 00 00 00 00 00 00 : 00 00 00 00 00 00 00 00
Signal Condition Control: Normal Async REFCLK,
Thresholds: Alarm High Warning High Warning Low Alarm Low
Temperature: 78.000 73.000 -8.000 -13.000
Voltage: 6.318 Volt 6.295 Volt 2.343 Volt 4.907 Volt
Bias: 12.000 mAmps 11.000 mAmps 5.000 mAmps 4.000 mAmps
Transmit Power: 1.585 mW (2.00 dBm) 0.794 mW (-1.00 dBm) 0.186 mW (-7.30 dBm) 0.093 mW (-10.30 dBm)
Receive Power: 1.585 mW (2.00 dBm) 0.794 mW (-1.00 dBm) 0.102 mW (-9.90 dBm) 0.051 mW (-12.91 dBm)
Temperature: 32.625
Voltage: 0.000 Volt
Tx Bias: 8.058 mAmps
Tx Power: 0.639 mW (-1.94 dBm)
Rx Power: 0.000 mW (<-40.00 dBm)
Control Status: Module NR, Interrupt, Rx LOS, Rx not ready, Rx CDR not locked,
Digital Diagnostics Data (Lower Memory)
0x0000: 06 00 4e 00 f3 00 49 00 : f8 00 f6 cf bf ac f5 e9
0x0010: 5b 85 17 70 07 d0 15 7c : 09 c4 3d e8 03 a5 1f 07
0x0020: 07 46 3d e8 02 00 1f 07 : 03 ff 8d cc 75 30 88 b8
0x0030: 79 18 f3 d3 dc fd fb 3d : 6f ee 00 00 00 00 00 00
0x0040: 00 00 00 00 00 7c 00 00 : 00 00 00 00 00 00 00 00
0x0050: 00 40 00 40 1e 00 00 00 : 00 00 00 00 00 00 00 00
0x0060: 20 a0 00 00 0f bd 18 f7 : 00 06 80 eb 00 00 22 18
0x0070: 00 00 00 00 00 00 00 00 : 00 00 00 00 00 00 00 02
12-11-2015 04:53 AM
RX is -40dBm, which means that either the remote side is not sending, the remote side is not connected, or the fibers input wrong and the tx/rx need to be swapped.
Sam
12-11-2015 04:58 AM
Hi Sam,
My devices are at remote place , I can't physically check them. Do you think replacing the SFP's can work it out?
