ASR9K Repartitioning (CSCub41271) XR 4.3.2 -> XR 5.3.2
if have to upgrade a RSP4 from XR 4.3.2 to XR 5.3.2. Disk0: shows only 1.6 GB so I first thought that I could repartition it to 1.9 GB. As it seems to me the repartitioning should have been done during a previous upgrade, I can't find a SMU in 4.3.2 that includes the utility.
Can I use the 4.2.1 SMU on 4.3.2 (I doubt that very much)? Is there another tool in 4.3.2 that lets me do the repartitioning? Or should I use the FPD pie trick and leave the disk0: at its current partitioning?
Any idea is appreciated.
Kind regards
Mat
Eddie Chami
Hi Mat
The 4.2.1 SMU can't be used on 4.3.2, but for the purpose of this discussion the re-partitioning tool is already in 4.3.2, you'll just need to run it, more details here:
https://supportforums.cisco.com/document/145991/managing-disk-space-rsp-4grsp-8g-aka-rsp2
Eddie.
