carlos.bustios
Beginner
ASR9K RSP440 1588 port configuration
Hi all,
Does anyone know how to configure the 1588 - PTP 10/100Mbps Ethernet port of the RSP440s?
I'm trying to configure it on an ASR9K with IOS XR 4.3.2 but I don't even find this interface  using the "sh run all-interfaces" command, I also don't see it in the port-parameters options of clock-interfaces configuration.
Thanks for your help,
Best regards,
CB
1 ACCEPTED SOLUTION
Hi Carlos,
there is no software suport yet for that port on the RSP440. It's reserved for future use.
If there is a particular use case scenario that you are interested in, please work through your account team.
Aleksandar
4 REPLIES 4
Aleksandar Vidakovic
Hi Aleksandar,
Not in this case, I couldn't find on this document a way or guide of how to specifically configure the RJ45 interface labeled as “1588” on the RSP440s.
CB
Hi Carlos,
Aleksandar
Hi Aleksandar,
Ok, thanks for your time and help, I also thought the same and I was checking the latest IOS XR (5.1/5.1.1) release notes but I didn't find any news about this 1588 port at this time.
Best regards,
CB
