ASR9K RSP440 1588 port configuration
carlos.bustios
Beginner
Beginner
Hi all,
Does anyone know how to configure the 1588 - PTP 10/100Mbps Ethernet port of the RSP440s?
I'm trying to configure it on an ASR9K with IOS XR 4.3.2 but I don't even find this interface  using the "sh run all-interfaces" command, I also don't see it in the port-parameters options of clock-interfaces configuration.
Thanks for your help,
Best regards,
CB
Hi Carlos,
there is no software suport yet for that port on the RSP440. It's reserved for future use.
If there is a particular use case scenario that you are interested in, please work through your account team.
Aleksandar
Hi Aleksandar,
Not in this case, I couldn't find on this document a way or guide of how to specifically configure the RJ45 interface labeled as “1588” on the RSP440s.
CB
Hi Carlos,
Aleksandar
Hi Aleksandar,
Ok, thanks for your time and help, I also thought the same and I was checking the latest IOS XR (5.1/5.1.1) release notes but I didn't find any news about this 1588 port at this time.
Best regards,
CB
Recognize Your Peers
