04-20-2016 08:18 AM
i have in the log
mibd_interface[332]: %SNMP-IFMIB-3-SYSDB : Failed sysdb operation: stats bag decode, err: 'bag' detected the 'fatal' condition 'The specified bag is corrupted'
What can i do?
Frank
04-20-2016 08:26 AM
in the log is:
%SYSDB-BAG-7-INTERNAL : The bag infrastructure has encountered an error. Name mismatch: got 'ifstatsbag_basic', expecting 'ifstatsbag_generic' : mibd_interface : (PID=565610) : -Traceback= 93da4e4 93d8673 93d7505 e48c407 e48cd2a e48d731 df76e37 e48d2a6 e490904 e452282 e451311 de16061 de1b9e0 de1c36a bb2d413 df62f79
Frank
04-23-2016 09:51 PM
Frank,
The above messages are NOT service impacting. They are directly related to
SNMP and tend to occur if "IFMIB" is polled by SNMP while subinterfaces are
being added or removed and it stops after the interface being worked on is enabled.
This messages tend to only show 1-2 occurrences and then stop. (transient)
If you see these internal syslog error messages often, then need to check your router installed packages and snmp trace logs.
Its sounds that you are hitting a known bug CSCuv15754
< https://tools.cisco.com/bugsearch/bug/CSCuv15754>
Please execute the following to recover: (It is not service impacting)
process restart mibd_interface
Hope the above solution is helpful & clear the issue.
Let me know, How it goes..
-Prasad.
***Ratings Encourages Contributors ****
