nokoya001
Beginner
ASR9K VRF imported path
In ASR1000, importing path from global to VRF will import all available path into VRF itself depend on route-map too. For example if you have 3 paths for one prefix, no matter the as-path it will import all 3 paths. But in ASR9K XR OS seems very different, it import only one and if you set maximum-path that will import the number you set. And by default it will import only it is has same local-pref and same as-path length. I tried all 'bgp bestpath' options available and unable to get same result AS1000 gave which allow me to get the prefix path in the VRF whatever the local-pref and as-path length is.
These are my configuration
vrf Test
 rd 65432:4
 address-family ipv4 unicast
  import from default-vrf route-policy TestImport
  import route-target
   65432:4
  export route-target
   65432:4
  maximum prefix 5000000 80
  done
end-policy
router bgp 911
 vrf Test
  rd 65432:4
  bgp redistribute-internal
   distance bgp 200 200 200
   maximum-paths ebgp 3 order igp-metric
   redistribute connected
Any clue which option should I add to ignore as-path length and local-pref(set for default-vrf) ?
0 REPLIES 0
Content for Community-Ad
