BGP Graceful Restart
jschmied
Is BGP graceful restart per neighbor supported on XR? If so, how is it configured. Thanks.
Jamie
Eddie Chami
Here is the config, but i don't suggest you head down this path, upgrade to 5.3.2 or 5.3.3 (Jan) and use NSR (None Stop Routing).. GR capability has to be negotiated with peers..
Building configuration...
!! IOS XR Configuration 5.3.2
router bgp 64524
 neighbor 172.28.98.6
  graceful-restart
end
Hello Eddie,
I didn´t find per neigh as you described it, but:
!! IOS XR Configuration 5.3.3
router bgp XYZ
bgp graceful-restart
neighbor a.b.c.d
graceful-restart disable
Activate under BGP and disable it per neigh, At the end, same result,
It is on ASR9k, i'll checkit on CRS...
david
Hello Eddie,
I tried this configuration of GR per NBR in 5.2.4 and 5.3.3 and when I commit it, the commit fails and I see the following warning:
!!% 'BGP' detected the 'warning' condition 'Graceful-restart has not been enabled globally'
The changes do not take place. Is this expected behaviour? Is there any way to configure GR per neighbor without having to configure it globally?
Thanks!
Carolina
