Hi, Experts
Equipment: Cisco ASR9922, IOS-XR 4.3.2
Issue: I have problem that my RR do the next-hop-self by using route-policy for client routers, the next-hop is changed as intended but the MPLS label doesn’t changed to reflect the new next-hop.
What I would like to achieve: I would like RR to set next-hop-self only for selected prefixes(172.168.0.0/24, 0.0.0.0/0) but maintain original next-hop for the rest, I do this by using route-policy.
Detail:
I have routers running MPLS infrastructure with ASR9922 as an RR. RN router is in neighbor-group RN and CPE-xx routers are in neighbor-group AN.
Neighbor-group AN has the route-policy AN-OUT2 to set next-hop of prefix 172.168.0.0/24 and 0.0.0.0/0 to RR#loopback1 before send out update to CPE routers. Below is BGP and RPL configuration at RR.
router bgp 64549
nsr
bgp graceful-restart
ibgp policy out enforce-modifications
address-family vpnv4 unicast
additional-paths receive
additional-paths send
additional-paths selection route-policy ADD-PATH-iBGP
retain route-target all
neighbor-group AN
remote-as 64549
cluster-id 172.16.1.11
update-source Loopback1
route-reflector-client
route-policy AN-OUT2 out
soft-reconfiguration inbound
if destination in DEFAULT or destination in RNC then
set next-hop 192.168.10.11
else
pass
endif
end-policy
This is what RR advertises to CPE-24
RP/0/RP0/CPU0:RR#show bgp vpnv4 unicast neighbors 192.168.10.24 advertised-routes
Fri Dec 20 15:23:14.931 BKK
Network Next Hop From AS Path
Route Distinguisher: 64549:3339
0.0.0.0/0 192.168.10.11 172.16.1.1 ?
172.16.1.2 ?
172.168.0.0/24 192.168.10.11 172.16.1.1 ?
172.16.1.2 ?
192.168.0.1/32 192.168.10.11 192.168.10.24 i
192.168.0.26/32 192.168.10.26 192.168.10.26 i
192.168.25.1/32 192.168.10.25 192.168.10.25 i
192.168.211.8/30 192.168.10.22 192.168.10.22 i
The IP part works as intended but MPLS Label doesn’t work as intended. Please take a look at RN who is originates 172.168.0.0/24, label 16025 is locally assigned.
RP/0/RP0/CPU0:RN1#show bgp vpnv4 unicast labels
Status codes: s suppressed, d damped, h history, * valid, > best
i - internal, r RIB-failure, S stale, N Nexthop-discard
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Rcvd Label Local Label
Route Distinguisher: 64549:3339 (default for vrf VLAN3339)
*> 0.0.0.0/0 0.0.0.0 nolabel 16025
* i 172.16.1.11 16068 16025
* i 172.16.1.13 16033 16025
*> 172.168.0.0/24 0.0.0.0 nolabel 16025
* i 172.16.1.11 16059 16025
* i 172.16.1.13 16024 16025
172.168.0.0/24 at RR, label 16059 is locally assigned, label 16025 is receive from RN router. It should send 172.168.0.0/24 with label 16059 to CPE-24 to reflect next-hop changed.
RP/0/RSP0/CPU0:RR#show bgp vpnv4 unicast labels
*>i0.0.0.0/0 172.16.1.1 16025 16068
* i 172.16.1.2 16007 16068
*>i172.168.0.0/24 172.16.1.1 16025 16059
* i 172.16.1.2 16007 16059
*>i192.168.0.1/32 192.168.10.24 131070 16060
*>i192.168.25.1/32 192.168.10.25 131070 16062
*>i192.168.211.8/30 192.168.10.22 131070 16065
What I found at CPE-24 which is Alcatel router is that, RR send prefix 172.168.0.0/24, nh 192.168.10.11 with label 16025 which is incorrect.
A:CPE-24# show router bgp routes vpn-ipv4 172.168.0.0/24
BGP Router ID:192.168.10.24 AS:64549 Local AS:64549
Legend -
Status codes : u - used, s - suppressed, h - history, d - decayed, * - valid
Origin codes : i - IGP, e - EGP, ? - incomplete, > - best, b - backup
BGP VPN-IPv4 Routes
Flag Network LocalPref MED
Nexthop Path-Id VPNLabel
As-Path
u*>? 64549:3339:172.168.0.0/24 100 0
192.168.10.11 None 16025
No As-Path
Routes : 1
On RR If I just remove the policy and do the next-hop-self under vpv4 address family, CPE-24 will get corrent nh with correct label(16059) but that won’t achieve our requirement to change nh only on selected prefixes. Is this software problem? Or is there any solution to work around?
Regard,
Marit
Solved! Go to Solution.
Hello Marit,
I am able to recreate this in the lab, and unfortunately this scenario is not supported. BGP does not advertise allocated label if we set nexhop using route policy. The only way is by next-hop-self configured on RR, and yes it eventually will applies to all prefixes advertised to neighbor-group AN. Currently i do not have workaround available.
Below is the capture of what i have tested in the lab:
The topology:
CRS-4-02 ---------- CRS-8-01 ------------ ASR-9006-1
CRS-8-01 is Route-reflector of CRS-4-02 and ASR-9006-1.
CRS-4-02 advertise some prefixes.
This issue occurs when RR have route-policy toward ASR-9006-1, where it assign incorrect label. But it assign correct label if CRS-8-01 use next-hop-self.
Below is the test done in the lab if RR use next-hop-self:
Tue Jan 7 08:16:18.945 UTC
router bgp 1
bgp router-id 172.16.4.1
address-family ipv4 unicast
neighbor 172.16.8.3
remote-as 1
update-source Loopback0
route-policy PASS in
route-policy PASS out
vrf RTAMAELA
rd 100:1
redistribute connected
Tue Jan 7 08:16:29.001 UTC
Network Next Hop From Advertised to
Route Distinguisher: 100:1
78.22.11.2/32 172.16.4.1 Local 172.16.8.3
78.22.11.3/32 172.16.4.1 Local 172.16.8.3
93.22.15.61/32 172.16.4.1 Local 172.16.8.3
RP/0/RP0/CPU0:CRS-4-02#
Tue Jan 7 08:16:53.655 UTC
BGP router identifier 172.16.4.1, local AS number 1
BGP generic scan interval 60 secs
BGP table state: Active
Table ID: 0x0
BGP main routing table version 57
BGP scan interval 60 secs
Route Distinguisher: 100:1 (default for vrf RTAMAELA)
*>i22.51.32.77/32 172.16.8.3 16056 nolabel
*> 78.22.11.2/32 0.0.0.0 nolabel 16003
*> 78.22.11.3/32 0.0.0.0 nolabel 16003
*> 93.22.15.61/32 0.0.0.0 nolabel 16003
Processed 4 prefixes, 4 paths
Wed Jan 8 11:07:05.436 UTC
router bgp 1
allocate-label all
neighbor-group AN
remote-as 1
next-hop-self <-- use next-hop-self toward ASR-9006-1
neighbor-group RN
remote-as 1
graceful-restart
next-hop-self
neighbor 10.10.10.10
remote-as 1
neighbor 72.15.48.5
use neighbor-group AN
neighbor 172.16.4.1
use neighbor-group RN
RP/0/RP1/CPU0:CRS-8-01#show bgp vpnv4 unicast labels
Wed Jan 8 11:07:09.091 UTC
BGP router identifier 172.16.8.3, local AS number 1
Table ID: 0x0 RD version: 344169
BGP main routing table version 92
*>i22.51.32.77/32 72.15.48.5 16000 16056
*>i78.22.11.2/32 172.16.4.1 16003 16053
*>i78.22.11.3/32 172.16.4.1 16003 16054
*>i93.22.15.61/32 172.16.4.1 16003 16055
Wed Jan 8 17:02:02.796 UTC
router bgp 1
bgp router-id 72.15.48.5
neighbor-group RR
remote-as 1
graceful-restart
neighbor 172.16.8.3
use neighbor-group RR
neighbor 192.169.1.2
remote-as 1
vrf RTAMAELA
rd 100:1
RP/0/RSP1/CPU0:ASR-9006-01#show bgp vpnv4 unicast labels
Wed Jan 8 17:02:04.381 UTC
BGP router identifier 72.15.48.5, local AS number 1
Table ID: 0x0 RD version: 253825
BGP main routing table version 126
*> 22.51.32.77/32 0.0.0.0 nolabel 16000
*>i78.22.11.2/32 172.16.8.3 16053 nolabel <== 172.16.8.3 is the loopback address of CRS-8-01
*>i78.22.11.3/32 172.16.8.3 16054 nolabel
*>i93.22.15.61/32 172.16.8.3 16055 nolabel
From output above we can see that ASR-9006-01 received correct label for each prefix.
Below is the output with route-policy configured and ASR-9006-01 receive incorrect label:
Wed Jan 8 11:04:46.310 UTC
router bgp 1
allocate-label all
neighbor-group AN
remote-as 1
route-policy RTAMAELA out
neighbor-group RN
remote-as 1
graceful-restart
next-hop-self
neighbor 72.15.48.5
neighbor 172.16.4.1
Wed Jan 8 11:16:06.847 UTC
if destination in RNC then
set next-hop 172.16.8.3
else
pass
endif
end-policy
RP/0/RP1/CPU0:CRS-8-01#show run prefix-set RNC
Wed Jan 8 11:16:12.099 UTC
prefix-set RNC
78.22.11.3/32
end-set
Wed Jan 8 11:04:33.512 UTC
Table ID: 0x0 RD version: 344013
Wed Jan 8 16:59:41.601 UTC
router bgp 1
neighbor-group RR
remote-as 1
graceful-restart
neighbor 172.16.8.3
remote-as 1
vrf RTAMAELA
rd 100:1
RP/0/RSP1/CPU0:ASR-9006-01#show bgp ipv4 unicast labels
Wed Jan 8 16:59:52.173 UTC
Wed Jan 8 17:00:00.457 UTC
Table ID: 0x0 RD version: 253701
BGP main routing table version 123
*>i78.22.11.2/32 172.16.4.1 16003 nolabel
*>i78.22.11.3/32 172.16.8.3 16003 nolabel <-- It receive label 16003, which is wrong. it should receive label 16054.
*>i93.22.15.61/32 172.16.4.1 16003 nolabel
Rivalino
The MP-BGP vpnv4 unicast AF is to advertised the VRF prefixes. But eventually it is the IGP that will route the packet to destination.
For vrf-RN <--> vrf-AN:
With the logical topology, the AN will advertise its VRF prefixes to RN with AN's loopback as nexthop. And then the IGP will take the packet from RN to AN's loopback and vice versa. Looking at the physical topology, we can say that the packet should transit via RR, as this is the only way to reach AN from RN.
for vrf-AN <--> vrf-AN:
Each AN will advertise its loopback as the nexthop for each VRF prefixes. And RR will reflect this route advertisement to other AN router without changing the next hop address. This means that AN1 will receive VRF prefixes from AN2 with AN2's loopback as its nexthop. After this the IGP will be responsible to carry the packet from AN1 to AN2, and IGP will take shortest path. If you run ISIS between AN1 and AN2 on its directly connected link, then the packet will not go through RR, but it takes shortest path which is directly connected link.
rivalino
Hello Marit,
As you have opened TAC case, I will follow up on that case.
thanks,
Rivalino
Hi Rivalino,
I just see your message here.
Thanks.
Hello Marit,
The topology:
router bgp 1
neighbor 172.16.8.3
remote-as 1
vrf RTAMAELA
rd 100:1
Table ID: 0x0
router bgp 1
allocate-label all
neighbor-group AN
remote-as 1
neighbor-group RN
remote-as 1
graceful-restart
next-hop-self
remote-as 1
neighbor 72.15.48.5
neighbor 172.16.4.1
router bgp 1
neighbor-group RR
remote-as 1
graceful-restart
neighbor 172.16.8.3
remote-as 1
vrf RTAMAELA
rd 100:1
router bgp 1
allocate-label all
neighbor-group AN
remote-as 1
neighbor-group RN
remote-as 1
graceful-restart
next-hop-self
neighbor 72.15.48.5
neighbor 172.16.4.1
else
pass
endif
end-policy
prefix-set RNC
78.22.11.3/32
end-set
router bgp 1
neighbor-group RR
remote-as 1
graceful-restart
neighbor 172.16.8.3
remote-as 1
vrf RTAMAELA
rd 100:1
Rivalino
Hi Rivalino,
That's answer the issue i'm faceing, anyway i'm looking into the work around..
If we go back one step further, the reason I do this is
AN-AN communication: I would like it to take shortest path in golbal-routing instead going back and forth between AN-RR-AN. This is actually X2 interface for mobile node while AN is actually access node that eNodeB connected to.
AN-RN communication through RR: PN is inline-RR where there is MPLS-TE configure in network like this.
[AN]---mpls-te---[RR]---mpls-te---[RN]
[AN]---isis_b-----[RR]---isis_a-----[RN]
I would like to drive traffic from AN-to-RN trough tunnel-te that why i need to set next-hop-self. This is actually S1 traffic and RN is a router that EPC connected to.
Work Around:
Is there anyway to drive traffic from AN to RN through tunnel-te without sacrifying AN-AN communication? UMMT3.0 say that AN should do BGP with pre-aggregate node(RR) in the same ring where next-hop-self won't hurt cuz it is in same ring. In my case AN do BGP with aggregate node NOT in the same ring and it is far away.
rivalino
