ceRedunEventSwitchover trigger
alessandro.dona
Level 3
Level 3
Hi Guys,
any of you know how to triggre the ceRedunEventSwitchover traps.
i'm not able to receive this trap using redundancy switchover command
Regrads
6 Replies 6
alessandro.dona
Level 3
Level 3
i forgot...it is ASR 9912
which release?
6.1.4
And you have the following configured in SNMP?
snmp-server traps entity-state switchover
snmp-server traps entity-redundancy all
snmp-server traps entity-redundancy status
snap-server traps entity-redundancy switchover
Eddie.
Hi Eddie,
first of all thank you for your kindly reply.
For sure i enabled all the traps you wrote down.
I think, but not sure, manual switchover does not trigger this trap
A manual RSP/RP FO with the "redundancy switchover" command should trigger this. Do you have a route to your NMS at all times and its available right after the FO happens on the new active RP/RSP?
If so you probably want to have this looked at further and with these commands:
debug snmp general
debug snmp trap
debug snmp mis rfmib
Clear log
Log back in after the RP FO
sh snmp traps
sh snmp traps details
sh snmp trace traps
sh logging
Eddie.
