09-18-2015 10:32 AM
Hi, All:
With version 5.1.3 (or in other version), is it possible to map 2 different inside-vrfs so that they are NAT'd to the same outside pool in default-vrf?
Something like:
service cgn cgn1
service-location preferred-active 0/3/CPU0
service-type nat44 NAT44
portlimit 2048
inside-vrf nat1
map address-pool 172.16.120.0/22
inside-vrf nat2
As shown, i have 2 inside VRFs and the 172.16.120.0/22 is in the global table.
Thanks in advance!
c.
09-21-2015 02:48 AM
Hi Carlos
If it is same mapped public address pool, it is going to be challenge to configure o2i without getting o2i drops.
Otherwise following configuration is allowed:
RP/0/RP0/CPU0:Router(config-cgn-invrf)#show
Fri Jun 15 16:54:52.430 PDT
service cgn demo
service-type nat44 nat44-1
inside-vrf Inside-1
map address-pool 151.0.0.0/24
inside-vrf Inside-2
map address-pool 151.0.1.0/24
From 5.2.0 onwards, using ABF based redundancy, same public address pool can be configured across two different cards.
Ranga
09-21-2015 06:04 AM
Thanks for your reply, Ranga.
See, the thing is that (using your example) pool for vrf Inside-1 is underutilized so, but for design reasons we need vrf Inside-2 and would like to avoid using more ip space so that Inside-2 has its own pool.
From what you say, I have 2 choices:
1) Splitting Inside-1 pool
2) Maybe route-leaking
