CISCO 4321 NOT BOOTING
tomerb
Hi all
I accidentally did a factory reset to my ISR4321
Now i boot from usb the new OS - 17.3 and copy to flash and even i do this command -
boot system flash bootflash:isr4300-universalk9.17.03.05.SPA.bin  and wr mem
Of course I checked that I have the IOS file on the FLASH.
After is reload the router i'm still on Rommon mode.
someone have idea what i can do to boot directly to the IOS?
thanks!
Router#sh ver
Cisco IOS XE Software, Version 17.03.05
Cisco IOS Software [Amsterdam], ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 17.3.5, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2022 by Cisco Systems, Inc.
Compiled Wed 09-Feb-22 10:37 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2022 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: (c)
Router uptime is 6 minutes
Uptime for this control processor is 7 minutes
System returned to ROM by Reload Command
System image file is "bootflash:isr4300-universalk9.17.03.05.SPA.bin"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Suite License Information for Module:'esg'
Suite Suite Current Type Suite Next reboot
FoundationSuiteK9 None Smart License None
securityk9
appxk9
AdvUCSuiteK9 None Smart License None
uck9
cme-srst
cube
Technology Package License Information:
Technology Technology-package Technology-package
Current Type Next reboot
appxk9 None Smart License None
uck9 None Smart License None
securityk9 None Smart License None
ipbase ipbasek9 Smart License ipbasek9
The current throughput level is 50000 kbps
Smart Licensing Status: Registration Not Applicable/Not Applicable
cisco ISR4321/K9 (1RU) processor with 1714631K/3071K bytes of memory.
Processor board ID FLM262210LQ
Router operating mode: Autonomous
2 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
3207167K bytes of flash memory at bootflash:.
3931620K bytes of USB flash at usb0:.
Configuration register is 0x8000
Router#dir fla
Router#dir flash:
Directory of bootflash:/
40161 drwx 28672 Sep 12 2022 14:33:16 +00:00 tracelogs
128514 drwx 4096 Sep 12 2022 14:28:22 +00:00 license_evlog
16 -rw- 30 Sep 12 2022 14:28:21 +00:00 throughput_monitor_params
12 -rw- 134458 Sep 12 2022 14:28:06 +00:00 memleak.tcl
120481 drwx 4096 Sep 12 2022 14:28:04 +00:00 .prst_sync
11 -rw- 788 Sep 12 2022 14:27:39 +00:00 mode_event_log
136545 drwx 4096 Sep 12 2022 14:27:01 +00:00 sysboot
20 drwx 4096 Sep 12 2022 14:14:04 +00:00 lost+found
8033 drwx 4096 Sep 12 2022 13:49:20 +00:00 .dbpersist
18 -rw- 702560970 Sep 12 2022 13:48:19 +00:00 isr4300-universalk9.17.03.05.SPA.bin
16066 drwx 4096 Sep 12 2022 13:41:27 +00:00 pnp-tech
88354 drwx 4096 Sep 12 2022 13:29:12 +00:00 iox_host_data_share
184738 drwx 4096 Sep 12 2022 13:28:52 +00:00 guest-share
112449 drwx 4096 Sep 12 2022 13:28:34 +00:00 core
176706 drwx 4096 Sep 12 2022 13:28:31 +00:00 onep
48193 drwx 4096 Sep 12 2022 13:28:28 +00:00 pnp-info
32129 drwx 4096 Sep 12 2022 13:28:04 +00:00 virtual-instance
14 -rw- 1923 Sep 12 2022 13:28:01 +00:00 trustidrootx3_ca_092024.ca
13 -rw- 20109 Sep 12 2022 13:28:01 +00:00 ios_core.p7b
176705 drwx 4096 Sep 12 2022 13:27:49 +00:00 gs_script
24097 drwx 4096 Sep 12 2022 13:27:47 +00:00 .rollback_timer
152609 drwx 4096 Sep 12 2022 12:12:55 +00:00 .sdwaninstaller
56228 -rw- 7538 May 25 2022 03:01:56 +00:00 packages.conf
19 -rw- 7538 May 25 2022 03:01:14 +00:00 prev_packages.conf
56237 -rw- 31244216 May 25 2022 02:59:47 +00:00 isr4300-rpboot.16.10.3a.SPA.pkg
56236 -rw- 360842236 May 25 2022 02:59:01 +00:00 isr4300-mono-ucmk9.16.10.3a.SPA.pkg
56235 -rw- 2192368 May 25 2022 02:58:51 +00:00 isr4300-firmware_sm_10g.16.10.3a.SPA.pkg
56234 -rw- 6304756 May 25 2022 02:58:51 +00:00 isr4300-firmware_nim_xdsl.16.10.3a.SPA.pkg
56233 -rw- 11490292 May 25 2022 02:58:51 +00:00 isr4300-firmware_nim_shdsl.16.10.3a.SPA.pkg
56232 -rw- 2520048 May 25 2022 02:58:51 +00:00 isr4300-firmware_nim_ge.16.10.3a.SPA.pkg
56231 -rw- 17490932 May 25 2022 02:58:51 +00:00 isr4300-firmware_nim_cwan.16.10.3a.SPA.pkg
56230 -rw- 10703860 May 25 2022 02:58:50 +00:00 isr4300-firmware_ngwic_t1e1.16.10.3a.SPA.pkg
56229 -rw- 50164 May 25 2022 02:58:50 +00:00 isr4300-firmware_dreamliner.16.10.3a.SPA.pkg
56227 -rw- 3 May 25 2022 02:58:50 +00:00 hugepage.conf
3258179584 bytes total (1272467456 bytes free)
Router#conf t
Enter configuration commands, one per line. End with CNTL/Z.
Router(config)#boot?
boot boot-end-marker boot-start-marker
Router(config)#boot s?
system
Router(config)#boot sy
Router(config)#boot system ?
WORD TFTP filename or URL
flash Boot from flash memory
ftp Boot from a server via ftp
mop Boot from a Decnet MOP server
rcp Boot from a server via rcp
rom Boot from rom
tftp Boot from a tftp server
Router(config)#boot system fla
Router(config)#boot system flash ?
WORD System image filename
<cr> <cr>
Router(config)#boot system flash isr4300-universalk9.17.03.05.SPA.bin
Router(config)#$ flash bootflash:isr4300-universalk9.17.03.05.SPA.bin
Router(config)#wr mem
% Invalid input detected at '^' marker.
Router(config)#exit
Router#wt
*Sep 12 14:36:16.851: %SYS-5-CONFIG_I: Configured from console by consolr
Building configuration...
[OK]
Router#et
*Sep 12 14:36:25.782: %SYS-6-PRIVCFG_ENCRYPT_SUCCESS: Successfully encrypted private config fiwr mem
[OK]
Router#reload
*Sep 12 14:36:34.555: %SYS-6-PRIVCFG_ENCRYPT_SUCCESS: Successfully encrypted private config file
Proceed with reload? [confirm]
*Sep 12 14:36:39.295: %SYS-5-RELOAD: Reload requested by console. Reload Reason: Reload Command.Sep 12 14:36:49.709: %PMAN-5-EXITACTION: R0/0: pvp: Pger is exiting: process exit with reload chassis code
Initializing Hardware ...
Checking for PCIe device presence...done
Reading confreg 8000
System integrity status: 0x610
Key Sectors:(Primary, GOOD), (Backup, GOOD), (Revocation, GOOD)
Size of Primary = 2288 Backup = 2288 Revocation = 288
RSA Self Test Passed
Expected hash:
DDAF35A193617ABACC417349AE204131
12E6FA4E89A97EA20A9EEEE64B55D39A
2192992A274FC1A836BA3C23A3FEEBBD
454D4423643CE80E2A9AC94FA54CA49F
Obtained hash:
Sha512 Self Test Passed
Rom image verified correctly
System Bootstrap, Version 17.6.2, RELEASE SOFTWARE
Copyright (c) 1994-2021 by cisco Systems, Inc.
Current image running: Boot ROM0
Last reset cause: LocalSoft
ISR4321/K9 platform with 4194304 Kbytes of main memory
rommon 1 >
Leo Laohoo
In ROMMON, enter the command "confreg 0x2102".
Also take the time to read Cisco ISR & ASR 1k Routers: IOS-XE/Firmware Upgrade (Install Mode).
Leo Laohoo
