cisco ASR9k bridge-domain -How can be disabled ,if the Interface ethernet goes down
ilirnako1
how can the bridge-domain be disabled if the Ethernet member interface goes down ?
for examplein this config :
bridge group 5
bridge-domain 5
interface TenGigE0/0/0/2
neighbor 10.1.7.6 pw-id 5
neighbor 10.1.1.3 pw-id 5
neighbor 10.1.1.4 pw-id 5
I want that if the TenGE0/0/0/2 goes down , the bridge domain also to goes down
tkarnani
If the Attachment circuit goes down, the xconnect will go down as well.
I believe this is what you are trying to achieve?
here is an example from our lab
RP/0/RP0/CPU0:6008-A#show l2vpn xconnect interface Te0/0/0/53
Thu Aug 31 11:55:05.048 UTC
Legend: ST = State, UP = Up, DN = Down, AD = Admin Down, UR = Unresolved,
        SB = Standby, SR = Standby Ready, (PP) = Partially Programmed
XConnect                   Segment 1                       Segment 2
Group      Name       ST   Description            ST       Description            ST
Test       test       UP   Te0/0/0/53             UP       1.1.100.7       200    UP
RP/0/RP0/CPU0:6008-A#conf t
Thu Aug 31 11:55:11.664 UTC
inRP/0/RP0/CPU0:6008-A(config)#int Te0/0/0/53
RP/0/RP0/CPU0:6008-A(config-if)#shut
RP/0/RP0/CPU0:6008-A(config-if)#commit
Thu Aug 31 11:55:17.174 UTC
Thu Aug 31 11:55:19.267 UTC
Test       test       DN   Te0/0/0/53             AD       1.1.100.7       200    DN
Thu Aug 31 11:55:28.432 UTC
RP/0/RP0/CPU0:6008-A(config-if)#no shut
RP/0/RP0/CPU0:6008-A(config-if)#no loopback ?
  <cr>
Thu Aug 31 11:55:40.160 UTC
Thu Aug 31 11:55:42.528 UTC
Test       test       DN   Te0/0/0/53             DN       1.1.100.7       200    DN
