03-13-2020 03:36 AM
Hi Community,
Question about possibility to copy a file between two ASR devices - is it supported? If so then lets say i have a file asr-new-software.tar on harddisk: and now how the scp line should look like?
When I try the below one it does not seem to work:
scp username@deviceip:/harddisk:/asr-new-software.tar harddisk:
Regards.
03-13-2020 03:39 AM
03-13-2020 02:49 PM
Works for me, do you need to specify a VRF? Does it connect to the remote host at all or does it not copy the file? Note if you specify harddisk: only as the destination it will take the name of the source file.
RP/0/RSP0/CPU0:ASR9904-D#scp smilstea@172.18.87.102:/harddisk:/volt_cont harddisk:/volt_cont2 vrf calo-mgmt
Fri Mar 13 18:42:42.457 EDT
Connecting to 172.18.87.102...
!! The mandatory pies for our devices are as follows: !!
!! 1. mini !!
!! 2. k9sec !!
!! 3. mgbl !!
!! 4. fpd !!
Password:
Transferred 120192 Bytes
120192 bytes copied in 0 sec (6325894)bytes/sec
RP/0/RSP0/CPU0:ASR9904-D#dir harddisk: | i volt_cont
Fri Mar 13 18:43:00.244 EDT
24030 -rw- 120192 Fri Mar 13 18:42:49 2020 volt_cont2
For example if I remove vrf it hangs here:
Fri Mar 13 18:45:55.315 EDT
If I add the VRF back it copies the file with the source files name to harddisk:
Can you verify connectivity with SSH and correct VRF?
Sam
