07-22-2016 11:01 AM
Hello!
I wonder if there is a way to copy files to the standby RSP on ASR9000 without first making said RSP active? I mean, sure, configuration and software packages are synchronized to the standby RSP, but other files (say, tcl scripts) are not. So in case of a switchover they will not be available any longer, possibly interferring with the event manager. I wonder if there is any way to access standby RSP storage, for example disk0?
It seems rather inconvenient to force RSP switchover every time one needs to update some scripts. It makes me miss that good old slavesup-bootdisk thing. Or am I missing something?
The system in question is an ASR9006 with a pair of RSP440-TR running 5.3.2 code.
Serge
Solved! Go to Solution.
07-22-2016 11:08 AM
We dont need to do failover to copy to stby RSP.
Please use this command:
copy <file to be copie> <destination loc and file name> loc <stby RSP>
Santosh
07-22-2016 11:08 AM
Santosh
07-22-2016 11:14 AM
It works, thanks a lot!
Serge
