Critical Led on on ASR9000 series
SupportAC
Hello
The led on 0/RSP0/CPU0 is on with a message
RP/0/RSP0/CPU0:BSRZGZ01#show environment leds details
Fri Feb 19 14:57:45.427 MET
R/S/I Modules LED Status Alarm Reason
0/RSP0/*
host Critical-Alarm On Card temp. beyond range;
host Major-Alarm Off ----
host Minor-Alarm Off ----
host ACO Off ----
host Fail Off ----
However, the temperature is ok
RP/0/RSP0/CPU0:BSRZGZ01# admin show environment temperatures location 0/RSP0/CPU0
Fri Feb 19 14:59:13.518 MET
R/S/I Modules Sensor (deg C)
0/RSP0/*
host die_CPU 38.0
host die_FabArbiter0 46.0
host die_FabArbiter1 48.0
host die_FIA 47.0
host die_FabSwitch0 55.0
host die_FabSwitch1 55.0
host temp_u275 29.1
host temp_u276 37.1
host temp_u278 41.1
host temp_u277 36.4
host temp_u279 40.6
host temp_u280 52.0
host temp_u281 39.6
host temp_u282 53.3
host Inlet0 29.1
host Hotspot0 37.1
Is there any way to reset this led?. Is the alarm real?.
Thank you very much
0 Replies 0
