CRS-1 boot failed problem ( REDFS-5-INIT_FAILED)
Hi expert ,
today I face new problem with one RP , :
Initializing DDR SDRAM...found 4096 MB
Initializing ECC on bank 0
Initializing ECC on bank 1
Initializing ECC on bank 2
Initializing ECC on bank 3
Turning off data cache, using DDR for first time
Initializing NVRAM...
Testing a portion of DDR SDRAM ...done
Reading ID EEPROMs ...
Initializing SQUID ...
Initializing PCI ...
PCI0 device[1]: Vendor ID 0x10ee
PCI0 device[1]: Device ID 0x300e
PCI1 device[1]: Device ID 0x1100
PCI1 device[1]: Vendor ID 0x1013
PCI1 device[2]: Device ID 0x680
PCI1 device[2]: Vendor ID 0x1095
PCI1 device[3]: Device ID 0x5618
PCI1 device[3]: Vendor ID 0x14e4
Configuring MPPs ...
Configuring PCMCIA slots ...
System Bootstrap, Version 1.53(20090311:225342) [CRS-1 ROMMON],
Copyright (c) 1994-2009 by Cisco Systems, Inc.
Acquiring backplane mastership ........failed
Board type is 0x100002 (1048578)
Switch 0 initialized
Backplane FE port Up... Enabling
Enabling watchdog
G4(7457-NonSMP-MV64360 Rev 4) platform with 4096 MB of main memory
Acquiring backplane mastership....failed.
Unable to access backplane ... invoking READ EEPROM protocol
Enabling only inter-RP port... successful
Sending backplane ID EEPROM read request
Our MAC address is 0249.4450.0008
Interface link changed state to UP.
Sending ID EEPROM read request.
HIT CTRL-C to abort
ID EEPROM read request successful.
Reconfiguring switches with default config ...
Chassis type: 484
    CARD_RACK_NUMBER: 0
    CARD_SLOT_NUMBER: 0
        CPU_INSTANCE: 1
  RACK_SERIAL_NUMBER: TBM13332678
MBI Validation starts ...Our MAC address is 001e.1392.84ee
Interface link state up.
MBI validation sending request.
HIT CTRL-C to abort
HIT CTRL-C to abort
mbi_val_process_packet: received response.
RACK_NUM = 0, RACK_TYPE=0
Local image to boot : bootflash:disk0/hfr-os-mbi-3.8.2/mbihfr-rp.vm
boot: booting from bootflash:disk0/hfr-os-mbi-3.8.2/mbihfr-rp.vm
tracelogger: starting tracing in background ring mode
tracelogger running with args: -startring -F 1 -F 2
               Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS XR Software for the Cisco XR HFR, Version 3.8.2
Copyright (c) 2009 by Cisco Systems, Inc.
This (D)RP Node is not ready or active for login /configuration
RP/0/RP0/CPU0:Jan 15 09:28:36 : redfs_svr[83]: %OS-REDFS-5-INIT_FAILED : Failed to initialize no devices available: 0x13:No such device
and reboot again , I disabled WATCHDOG but nothing happen,?
this is the show platform from RP0
RP/0/RP1/CPU0:BGD-JAD-PGW1#sh plat
Wed Jan 15 12:08:50.549 Iraq
[KNode            Type            PLIM            State           Config State
0/0/CPU0        MSC             Jacket Card     IOS XR RUN      PWR,NSHUT,MON
0/0/0           MSC(SPA)        10X1GE          OK              PWR,NSHUT,MON
0/0/1           MSC(SPA)        1x10GE          OK              PWR,NSHUT,MON
0/0/2           MSC(SPA)        10X1GE          OK              PWR,NSHUT,MON
0/0/4           MSC(SPA)        1x10GE          OK              PWR,NSHUT,MON
0/RP0/CPU0      RP(Standby)     N/A             MBI-BOOTING     PWR,NSHUT,MON
0/RP1/CPU0      RP(Active)      N/A             IOS XR RUN      PWR,NSHUT,MON
thanks alot
Leo Laohoo
Duplicate posts.
Go here:  https://supportforums.cisco.com/thread/2260981
Rivalino Tamaela
From RP1 please capture:
- show context
- show reboot history location 0/rp0/cpu0
thanks,
rivalino
