Beginner
CRS-X/16 - Dolly
Hello All,
I will have to install a CRS-X/16 in the near future and I need to understand if the "Dolly" (CRS-16-LIFT/B) from a CRS-3/16 is suitable for the CRS-X/16.
Thanks.
Pedro
1 ACCEPTED SOLUTION
Hi Pedro, We only have two
Hi Pedro,
We only have two lifts, one for the legacy chassis, and then the one you mention which is specific to the type B chassis and was introduced for CRS-3. So short answer is yes that one will work since CRS-X still uses the type-B chassis for 400Gbps, the legacy chassis with CRS-X would give you 200Gbps.
Sam
3 REPLIES 3
Hi Pedro,
Sam
Highlighted
Beginner
Hi Sam,Thanks for your prompt
Hi Sam,
Thanks for your prompt reply.
Another question, how can I know if the chassis is type-B or not? I have some CRSs in remote locations, and would like to know if they are upgradable to CRS-X or not.
Thanks.
PM
If you issue 'admin show
If you issue 'admin show inventory chassis' the PID for the LCC would be CRS-16-LCC-B, both can be upgraded to CRS-X just with reduced BW on the legacy chassis.
If you have more questions on CRS-X feel free to email me as there are some other requirements for the migration.
Sam
Content for Community-Ad
August's Community Spotlight Awards
