CSCut52232 - Post SMU Installed and Temporary Root-Certificate disapper
riduque
Hi Guys,
I added css-root.cer and I installed Post-SMU in ASR9010. But, after SMU is installed I can't see the temporary root-cer and I only see the old one.
XXXXX#sh sam certificate bri all
-------------------- SUMMARY OF CERTIFICATES -------------------
Certificate Location    : root
Certificate Index       : 1
Certificate Flag        : TRUSTED
  Serial Number  : 32:E0:A3:C6:CA:00:39:8C:4E:AC:22:59:1B:61:03:9F
  Subject:
        CN=Code Signing Server Certificate Authority,O=Cisco,C=US
  Issued By      :
  Validity Start : 01:46:24 UTC Tue Oct 17 2000
  Validity End   : 01:51:47 UTC Sat Oct 17 2015
  CRL Distribution Point
        file://\\CodeSignServer\CertEnroll\Code%20Signing%20Server%20Certificate%20Authority.crl
        http://codesignserver/CertEnroll/Code%20Signing%20Server%20Certificate%20Authority.crl
RP/0/RSP0/CPU0:MIA-PEER-01#
Is it the expected behavior?
Please your help
smilstea
This is expected behavior, there is no CLI to check if the certificate install went through okay, you just have to try install adding a package to verify that it works.
Sam
Thank you Sam. But it's expected too that temporary certificate be deleted after I install Post-SMU??
Because I checked in other devices with same command and I see both certificates (old one and temporary).
XXXXXXX#show sam certificate brief all
Thu Mar 17 12:35:35.629 GMT
  Subject:
  Issued By      :
Certificate Index       : 2
  Serial Number  : 90:B6:F4:F9:FF:B8:A9:DB
  Subject:
        emailAddress=jamohamm@cisco.com,CN=CSS Certificate Authority,OU=CSG,O=Cisco Systems,L=San Jose,ST=CA,C=US
  Issued By      :
  Validity Start : 10:19:42 UTC Thu Oct 09 2014
  Validity End   : 10:19:42 UTC Sun Oct 06 2024
