DF bit Clear
sameer.shah
Any one knows hows to clear df bit in IOS-XR from interface.. we used to do it in IOS as follows:
interface xxxx
ip policy route-map CLEAR_DF
route-map clear-df-bit permit 10
match any
set ip df 0
We need to apply same for ASR running IOS-XR 4.2.1
This is not about PBR support on ASR, We need to know option of clearing DF bit from IPv4 packet
Sameer
dpothier
hi Sameer,
PBR is not currently supported on the ASR9K. Have a look at ABF alternatively:
http://www.cisco.com/en/US/docs/routers/asr9000/software/asr9k_r4.2/addr_serv/configuration/guide/b_ipaddr_cg42a9k_chapter_01.html#con_1158105
What is the use-case on the ASR9K as it doesn't do PBR ?
regards,
david
Neel Shah
E-PBR will be supported starting 4.3.1(March/April)
I tried looking for this feature on IOS-XR and still couldn't able to locate it? Is it possible for you to send me link where detail of the same being discussed?
Sameer Shah
Sameer,
This is supported in 5.1.0.  Here is an example of the config:
ipv4 access-list allow_acl
10 permit ipv4 any any (cfg)
class-map type traffic match-any df_class
match access-group ipv4 allow_acl
end-class-map
policy-map type pbr df_bit_policy
class type traffic df_class
set ipv4 df 1
Bryan
