11-12-2019 12:18 PM
I have problem setting up the dhcp on the asr 9010 equipment.
My settings are as follows:
--> ASR 9010
interface GigabitEthernet0/0/0/1
description ***Conect to sw***
vrf client_Multiservicos
interface GigabitEthernet0/0/0/1.41
description === Dados ===
ipv4 address 10.51.23.254 255.255.255.0
encapsulation dot1q 41
interface GigabitEthernet0/0/0/1.60
description === Management ===
ipv4 address 10.51.5.254 255.255.255.0
encapsulation dot1q 60
pool vrf client_Multiservicos ipv4 Dados
address-range 10.51.23.1 10.51.23.250
dhcp ipv4
profile Dados server
pool Dados
allow-move
dns-server 10.1.1.1 10.1.1.2
domain-name test.local
subnet-mask 255.255.255.0
default-router 10.51.23.254
interface GigabitEthernet0/0/0/1.41 server profile Dados
--> Switch 3650
interface Ethernet0/0
description *** CONNECT ASR 9010 ***
switchport trunk allowed vlan 41,60
switchport mode trunk
interface Vlan60
description *** Managment ***
ip address 10.51.5.253 255.255.255.0
ip default-gateway 10.51.5.254
interface Ethernet0/1
description ***CONNECT PC***
switchport access vlan 41
switchport mode access
duplex auto
Pc does not catch ip by dhcp. But if I configure dhcp on switch 3650 it works. In this case I need to have dhcp server on asr 9010.
Attached the topology
Can you help me please?
11-12-2019 02:33 PM
11-14-2019 06:04 AM
Hi Jaderson Pessoa,
I tested it that way too but it didn't work unfortunately...
11-12-2019 02:56 PM
You also need to assign the VRF to the DHCP profile.
Can you try that and then send the following outputs collected a few times:
show dhcp ipv4 server profile name <profile name>
show dhcp ipv4 server profile name <profile name> loc 0/0/cpu0
show dhcp ipv4 server statistic
show dhcp ipv4 server statistics loc 0/0/cpu0
show dhcp ipv4 server binding vrf <vrf name>
Sam
11-14-2019 05:53 AM
11-14-2019 10:20 AM
I don't see any packets coming in and reaching the server, will need to debug and see if they are dropping due to a specific reason or if we see any packets at all.
debug dhcp ipv4 packet filter-id interface <interface>
debug dhcp ipv4 server errors
debug dhcp ipv4 server events
debug dhcp ipv4 server internals
Sam
