Highlighted
Beginner
DHCP Server within a VRF - ASR9K running 5.3.3
I would like to create a dhcp server within a vrf. I did read the DAPS Support document which does allow the user to configure an address range within a vrf but the other options like default router, DNS, etc are not there. Any help would be appreciated.
1 ACCEPTED SOLUTION
Highlighted
Beginner
based on what I have read in:
http://www.cisco.com/c/en/us/td/docs/routers/asr9000/software/asr9k_r5-3/addr-serv/configuration/guide/b-ipaddr-cg53asr9k/b-ipaddr-cg53asr9k_chapter_0101.html#concept_CA2B956D03FB4533A3653BD0119AC788
I think you should be able to do it. If you try to do it, is there any missing commands or issues?
2 REPLIES 2
Highlighted
Beginner
Highlighted
Beginner
Hi Borgenstrand,
Hi Borgenstrand,
Thank you for your help. This was what I needed.
Fred
Content for Community-Ad
Cisco COVID-19 Survey
