Highlighted
Beginner
Disk space not sufficient for rpm installation on NCS5501-SE
during SMU installation on NCS5501-SE, IOS XR 7.1.2 I almost run out of a disk space. Here is the warning
%HA-HA_WD-3-DISK_ALARM_ALERT : A monitored device / ( rootfs:/ ) is above 80% utilization. Current utilization = 85. Please remove unwanted user files and configuration rollback points.
SMU installation finished with the following message:
Node 0/0/CPU0 encountered error(s) during operation. Please check 'show install log 71 detail' for error details
Error stack for location 0/0/CPU0
1# on / Available disk space(including additional buffer 104857600) 519483392 is not sufficient for rpm installation of archive size 481421256
2# failed to load files from ldpath (new)
Please collect 'show tech-support install one-showtech' from XR and 'show tech-support ctrace' from Admin and pass this information to your TAC representative for support.
Feb 18 22:14:07 activate operation completed for all package(s)
Feb 18 22:14:09 Action 2: install activate action completed, however 1 node(s) encountered problems and should be reloaded to recover.
Here is the "show media location all" output
RP/0/RP0/CPU0:ios#show media location all
Fri Feb 19 13:52:52.721 UTC
Media Information for node0_RP0_CPU0. ---------------------------------------------- Partition Size Used Percent Avail rootfs: 3.9G 2.0G 53% 1.8G apphost: 3.7G 106M 3% 3.4G /dev/sde 969M 429M 48% 474M harddisk: 5.6G 560M 11% 4.8G log: 459M 56M 14% 369M config: 459M 2.5M 1% 422M disk0: 2.0G 6.0M 1% 1.9G disk2: 15G 2.8G 20% 12G --------------------------------------------------- rootfs: = root file system (read-only) log: = system log files (read-only) config: = configuration storage (read-only) Media Information for node0_0_CPU0. ---------------------------------------------- Partition Size Used Percent Avail rootfs: 3.9G 3.1G 85% 587M apphost: 3.7G 106M 3% 3.4G /dev/sde 969M 429M 48% 474M harddisk: 5.6G 560M 11% 4.8G log: 459M 60M 14% 366M config: 459M 796K 1% 424M disk0: 2.0G 4.6M 1% 1.9G --------------------------------------------------- rootfs: = root file system (read-only) log: = system log files (read-only) config: = configuration storage (read-only)
It is obvious I need to free up some disk space to continue with patching. Any advice on what and where to free up?
Best Regards,
Peter
5 REPLIES 5
Highlighted
We can start with "show install inactive" check to see how many inactive packages are present.
these can be removed those with "install remove inactive"
Highlighted
No change. Please see the outputs:
RP/0/RP0/CPU0:ios#show install inactive
Tue Feb 23 14:35:25.640 UTC
4 inactive package(s) found:
cisco-klm-0.1-r0.0.xr
bcm-klm-6.5.16-r1.0.xr
kernel-image-3.14.23-wr7.0.0.2-standard-3.14-r0.1.xr
kernel-modules-3.14-r0.1.xr
RP/0/RP0/CPU0:ios#
RP/0/RP0/CPU0:ios#
RP/0/RP0/CPU0:ios#admin show install inactive
Tue Feb 23 14:35:38.513 UTC
Node 0/RP0 [RP]
Inactive Packages:
bcm-klm-6.5.16-r1.0.host
kernel-modules-3.14-r0.1.host
ncs5500-sysadmin-hostos-7.1.2-r712.host
kernel-modules-3.14-r0.1.admin
bcm-klm-6.5.16-r1.0.admin
ncs5500-sysadmin-hostos-7.1.2-r712.admin
cisco-klm-0.1-r0.0.host
cisco-klm-0.1-r0.0.admin
kernel-image-3.14.23-wr7.0.0.2-standard-3.14-r0.1.admin
kernel-image-3.14.23-wr7.0.0.2-standard-3.14-r0.1.host
RP/0/RP0/CPU0:ios#install remove inactive
Tue Feb 23 14:45:57.831 UTC
Feb 23 14:45:59 Install operation 79 started by cisco:
Feb 23 14:46:00 Install operation will continue in the background
RP/0/RP0/CPU0:ios#Feb 23 14:46:06 Install operation 79 finished successfully
RP/0/RP0/CPU0:Feb 23 14:46:06.171 UTC: sdr_instmgr[1293]: %INSTALL-INSTMGR-2-OPERATION_SUCCESS : Install operation 79 finished successfully
RP/0/RP0/CPU0:ios#install commit
Tue Feb 23 14:46:50.746 UTC
Feb 23 14:46:52 Install operation 80 started by cisco:
install commit
Feb 23 14:46:53 Install operation will continue in the background
RP/0/RP0/CPU0:ios#
RP/0/RP0/CPU0:Feb 23 14:47:30.418 UTC: sdr_instmgr[1293]: %INSTALL-INSTMGR-2-OPERATION_SUCCESS : Install operation 80 finished successfully
Inactive packages were not removed, but skipped
RP/0/RP0/CPU0:ios#sh install log 79 detail
Tue Feb 23 14:50:08.660 UTC
Feb 23 14:46:00 Action 1: install remove action started
Feb 23 14:46:00 Package list:
Feb 23 14:46:00 cisco-klm-0.1-r0.0.xr.x86_64
Feb 23 14:46:00 bcm-klm-6.5.16-r1.0.xr.x86_64
Feb 23 14:46:01 kernel-image-3.14.23-wr7.0.0.2-standard-3.14-r0.1.xr.x86_64
Feb 23 14:46:01 kernel-modules-3.14-r0.1.xr.x86_64
Feb 23 14:46:04 Following packages are skipped:
Feb 23 14:46:04 cisco-klm-0.1-r0.0.xr.x86_64
Feb 23 14:46:04 bcm-klm-6.5.16-r1.0.xr.x86_64
Feb 23 14:46:04 kernel-image-3.14.23-wr7.0.0.2-standard-3.14-r0.1.xr.x86_64
Feb 23 14:46:04 kernel-modules-3.14-r0.1.xr.x86_64
Feb 23 14:46:04 Action 1: install remove action completed successfully
Feb 23 14:46:06 Ending operation 79
Highlighted
do you have a lot of active packages installed?
can you paste
show install active summary
Highlighted
Here is the output
RP/0/RP0/CPU0:ios#show install active summary
Wed Feb 24 22:03:39.337 UTC
Active Packages: 21
ncs5500-xr-7.1.2 version=7.1.2 [Boot image]
ncs5500-mgbl-3.0.0.0-r712
ncs5500-eigrp-1.0.0.0-r712
ncs5500-isis-2.1.0.0-r712
ncs5500-li-1.0.0.0-r712
ncs5500-mpls-2.1.0.0-r712
ncs5500-mpls-te-rsvp-3.1.0.0-r712
ncs5500-ospf-2.0.0.0-r712
ncs5500-mcast-3.0.0.0-r712
ncs5500-k9sec-3.2.0.0-r712
ncs5500-os-support-4.0.0.1-r712.CSCvv42707
ncs5500-mcast-3.0.0.1-r712.CSCvv54838
ncs5500-fwding-3.0.0.1-r712.CSCvt02738
kernel-image-3.14.23-wr7.0.0.2-standard-3.14.p1-r0.1.r712.CSCvv99754.xr
kernel-modules-3.14.p1-r0.1.r712.CSCvv99754.xr
cisco-klm-0.1.p1-r0.0.r712.CSCvv99754.xr
bcm-klm-6.5.16.p1-r1.0.r712.CSCvv99754.xr
ncs5500-infra-5.0.0.5-r712.CSCvv86617
ncs5500-dpa-3.0.0.5-r712.CSCvv86617
ncs5500-isis-2.1.0.1-r712.CSCvw45546
ncs5500-dpa-fwding-4.0.0.4-r712.CSCvv81241
Highlighted
Beginner
The following commands helped me to solve my issue:
show install superseded
install deactivate superseded
install commit
install remove inactive all
install commit
Content for Community-Ad
