12-14-2016 11:59 PM
Does IOS-XR minor upgrade from 5.3.1 to 5.3.3 on ASR9922 impact EEM and VRF license ?
Are there any issues for this ?
Also, rolling back from 5.3.3 to 5.3.1 impact anything like config, EEM,l icense etc ?
Regards.
Solved! Go to Solution.
12-15-2016 12:18 AM
No it will not effect EEM or license and the same for rolling back
If your asking are there any issues with that version , you should check the release notes online and see what open caveats/bugs there are in that software version and also the filed notices to see exactly what may be effected
5.3.4 Is the recommended safe harbour version for that platform not 3.3 currently
12-15-2016 12:37 AM
It will not impact Lic and EEM, but still you shouldn't be using 5.3.4..
12-15-2016 12:18 AM
12-15-2016 12:32 AM
Thanks for advice.
I am not talking about BUG but just minor upgrede/downgrade between 5.3.1 and 5.3.3 will impact config, license or EEM.
Regards.
12-15-2016 12:37 AM
12-15-2016 04:18 PM
Thanks for advice !
