01-15-2015 06:59 AM
HI,ALL
when I telnet the CRS-1,I use show diag sum ,show led,show inv command,does the 0/13/* MSC fail?
I have not seen the machine,is there SIP-800 no SPA card cause the problem?
show diag sum
CARD 0/13/* : Unknown Card Type
PLIM 0/PL13/* : Cisco Carrier Routing System SPA Interface Processor Card (NO MSC)
CARD 0/RP0/* : Cisco CRS Series 16 Slots 6 GB Performance Route Processor
CARD 0/RP1/* : Cisco CRS Series 16 Slots 6 GB Performance Route Processor
show led
RP/0/RP0/CPU0:FZ-QY-CR-1.MAN.CRS#
0/13/*: Module (host) LED status says: OK
0/13/*: Module (jacket) LED status says: Unknown
RP/0/RP0/CPU0:FZ-QY-CR-1.MAN.CRS#show inventory location 0/13/CPU0
Wed Jan 14 15:52:43.142 GMT
NAME: "0/13/*", DESCR: "Cisco CRS-1 Series Modular Services Card revision B"
PID: CRS-MSC-B , VID: V08, SN: SAL1614915K
NAME: "0/PL13/*", DESCR: "Cisco Carrier Routing System SPA Interface Processor Card"
PID: CRS1-SIP-800 , VID: V04, SN: SAD140200WY
RP/0/RP0/CPU0:FZ-QY-CR-1.MAN.CRS#admin show led
Wed Jan 14 23:33:08.402 GMT
LOCATION MESSAGE MODE STATUS
0/0/* IOS XR DEFAULT UNLOCKED
0/1/* IOS XR DEFAULT UNLOCKED
0/2/* IOS XR DEFAULT UNLOCKED
0/3/* IOS XR DEFAULT UNLOCKED
0/4/* IOS XR DEFAULT UNLOCKED
0/5/* IOS XR DEFAULT UNLOCKED
0/6/* IOS XR DEFAULT UNLOCKED
0/7/* IOS XR DEFAULT UNLOCKED
0/8/* IOS XR DEFAULT UNLOCKED
0/9/* IOS XR DEFAULT UNLOCKED
0/10/* IOS XR DEFAULT UNLOCKED
0/11/* IOS XR DEFAULT UNLOCKED
0/12/* IOS XR DEFAULT UNLOCKED
0/13/* IOS XR DEFAULT UNLOCKED
0/RP0/* ACTV RP DEFAULT UNLOCKED
0/RP1/* STBYRDY DEFAULT UNLOCKED
0/FC0/* IOS XR DEFAULT UNLOCKED
0/FC1/* IOS XR DEFAULT UNLOCKED
0/AM0/* 0 13 SP DEFAULT UNLOCKED
0/AM1/* 0 13 SP DEFAULT UNLOCKED
0/SM0/* IOS XR DEFAULT UNLOCKED
0/SM1/* IOS XR DEFAULT UNLOCKED
0/SM2/* IOS XR DEFAULT UNLOCKED
0/SM3/* IOS XR DEFAULT UNLOCKED
0/SM4/* IOS XR DEFAULT UNLOCKED
0/SM5/* IOS XR DEFAULT UNLOCKED
0/SM6/* IOS XR DEFAULT UNLOCKED
0/SM7/* IOS XR DEFAULT UNLOCKED
01-15-2015 06:22 PM
RP/0/RP0/CPU0:FZ-QY-CR-1.MAN.CRS#show platform
Fri Jan 16 10:21:42.874 GMT
Node Type PLIM State Config State
0/0/CPU0 MSC-B Jacket Card IOS XR RUN PWR,NSHUT,MON
0/0/0 MSC-B(SPA) OC192RPR-XFP OK PWR,NSHUT,MON
0/0/1 MSC-B(SPA) OC192RPR-XFP OK PWR,NSHUT,MON
0/0/2 MSC-B(SPA) 5X1GE OK PWR,NSHUT,MON
0/0/4 MSC-B(SPA) 1x10GE OK PWR,NSHUT,MON
0/0/5 MSC-B(SPA) 2XOC48-POS OK PWR,NSHUT,MON
0/1/CPU0 MSC-B Jacket Card IOS XR RUN PWR,NSHUT,MON
0/1/0 MSC-B(SPA) OC192RPR-XFP OK PWR,NSHUT,MON
0/1/1 MSC-B(SPA) OC192RPR-XFP OK PWR,NSHUT,MON
0/1/2 MSC-B(SPA) 5X1GE OK PWR,NSHUT,MON
0/1/4 MSC-B(SPA) 1x10GE OK PWR,NSHUT,MON
0/1/5 MSC-B(SPA) 2XOC48-POS OK PWR,NSHUT,MON
0/2/CPU0 MSC-B Jacket Card IOS XR RUN PWR,NSHUT,MON
0/2/0 MSC-B(SPA) 1x10GE OK PWR,NSHUT,MON
0/2/1 MSC-B(SPA) 1x10GE OK PWR,NSHUT,MON
0/2/4 MSC-B(SPA) 1x10GE OK PWR,NSHUT,MON
0/2/5 MSC-B(SPA) 1x10GE OK PWR,NSHUT,MON
0/3/CPU0 MSC-B Jacket Card IOS XR RUN PWR,NSHUT,MON
0/3/0 MSC-B(SPA) 1x10GE OK PWR,NSHUT,MON
0/3/1 MSC-B(SPA) 1x10GE OK PWR,NSHUT,MON
0/3/4 MSC-B(SPA) 1x10GE OK PWR,NSHUT,MON
0/3/5 MSC-B(SPA) 1x10GE OK PWR,NSHUT,MON
0/4/CPU0 MSC-B Jacket Card IOS XR RUN PWR,NSHUT,MON
0/4/0 MSC-B(SPA) 1x10GE OK PWR,NSHUT,MON
0/4/1 MSC-B(SPA) 1x10GE OK PWR,NSHUT,MON
0/4/4 MSC-B(SPA) 1x10GE OK PWR,NSHUT,MON
0/5/CPU0 MSC-B Jacket Card IOS XR RUN PWR,NSHUT,MON
0/5/0 MSC-B(SPA) 8X1GE OK PWR,NSHUT,MON
0/5/1 MSC-B(SPA) 8X1GE OK PWR,NSHUT,MON
0/5/2 MSC-B(SPA) 8X1GE OK PWR,NSHUT,MON
0/5/3 MSC-B(SPA) 8X1GE OK PWR,NSHUT,MON
0/5/4 MSC-B(SPA) 8X1GE OK PWR,NSHUT,MON
0/5/5 MSC-B(SPA) 8X1GE OK PWR,NSHUT,MON
0/6/CPU0 MSC-B Jacket Card IOS XR RUN PWR,NSHUT,MON
0/6/0 MSC-B(SPA) 8X1GE OK PWR,NSHUT,MON
0/6/1 MSC-B(SPA) 8X1GE OK PWR,NSHUT,MON
0/6/2 MSC-B(SPA) 8X1GE OK PWR,NSHUT,MON
0/6/3 MSC-B(SPA) 8X1GE OK PWR,NSHUT,MON
0/6/4 MSC-B(SPA) 8X1GE OK PWR,NSHUT,MON
0/6/5 MSC-B(SPA) 5X1GE OK PWR,NSHUT,MON
0/7/CPU0 MSC-B Jacket Card IOS XR RUN PWR,NSHUT,MON
0/7/0 MSC-B(SPA) 1x10GE OK PWR,NSHUT,MON
0/7/1 MSC-B(SPA) 1x10GE OK PWR,NSHUT,MON
0/7/4 MSC-B(SPA) 1x10GE OK PWR,NSHUT,MON
0/7/5 MSC-B(SPA) 1x10GE OK PWR,NSHUT,MON
0/8/CPU0 MSC-B Jacket Card IOS XR RUN PWR,NSHUT,MON
0/8/0 MSC-B(SPA) OC192RPR-XFP OK PWR,NSHUT,MON
0/8/1 MSC-B(SPA) OC192RPR-XFP OK PWR,NSHUT,MON
0/8/4 MSC-B(SPA) 1x10GE OK PWR,NSHUT,MON
0/8/5 MSC-B(SPA) 1x10GE OK PWR,NSHUT,MON
0/9/CPU0 MSC-B Jacket Card IOS XR RUN PWR,NSHUT,MON
0/9/0 MSC-B(SPA) OC192RPR-XFP OK PWR,NSHUT,MON
0/9/1 MSC-B(SPA) OC192RPR-XFP OK PWR,NSHUT,MON
0/9/4 MSC-B(SPA) 1x10GE OK PWR,NSHUT,MON
0/9/5 MSC-B(SPA) 1x10GE OK PWR,NSHUT,MON
0/10/CPU0 MSC-B Jacket Card IOS XR RUN PWR,NSHUT,MON
0/10/0 MSC-B(SPA) 1x10GE OK PWR,NSHUT,MON
0/10/1 MSC-B(SPA) 1x10GE OK PWR,NSHUT,MON
0/10/4 MSC-B(SPA) 1x10GE OK PWR,NSHUT,MON
0/10/5 MSC-B(SPA) 1x10GE OK PWR,NSHUT,MON
0/11/CPU0 MSC-B Jacket Card IOS XR RUN PWR,NSHUT,MON
0/11/0 MSC-B(SPA) 1x10GE OK PWR,NSHUT,MON
0/11/1 MSC-B(SPA) 1x10GE OK PWR,NSHUT,MON
0/11/4 MSC-B(SPA) 1x10GE OK PWR,NSHUT,MON
0/11/5 MSC-B(SPA) 1x10GE OK PWR,NSHUT,MON
0/12/CPU0 MSC-B Jacket Card IOS XR RUN PWR,NSHUT,MON
0/12/0 MSC-B(SPA) OC192RPR-XFP OK PWR,NSHUT,MON
0/12/1 MSC-B(SPA) OC192RPR-XFP OK PWR,NSHUT,MON
0/12/4 MSC-B(SPA) 1x10GE OK PWR,NSHUT,MON
0/12/5 MSC-B(SPA) 1x10GE OK PWR,NSHUT,MON
0/13/CPU0 MSC-B Jacket Card IOS XR RUN PWR,NSHUT,MON
0/RP0/CPU0 RP(Active) N/A IOS XR RUN PWR,NSHUT,MON
0/RP1/CPU0 RP(Standby) N/A IOS XR RUN PWR,NSHUT,MON
04-20-2016 12:17 AM
I have quite same this problem but I met with CRS-1 Fabric Card.
Symptom:
Resolution:
Re-enable power of the card which have a problem.
