Hi expert,
I have two asr 9006. I'm using dual rsp on router. I'm using Cisco IOS XR Software, Version 4.1.2.
I want to use two asr 9006 to cluster. But How can do this? I can't find documents on the cisco web site or internet.
Solved! Go to Solution.
Hi Umit,
•Supported since 4.2.1
HW requirement – Chassis
HW requirement – Line card and RSP
We have more information on nV Edge posted here
https://supportforums.cisco.com/docs/DOC-34114
HTH,
Sam
Hi Umit,
HTH,
Sam
Many thanks.
I have dual a9k-rsp-4g. It seems I have unsupported hardware.
Sent from Cisco Technical Support Android App
