11-28-2019 10:26 AM
We started seeing these errors below after doing a FPD upgrade on the A9K-48X10GE-1G-TR module running IOS XR 6.5.3 and with RSP880's. Before the FPD upgrade the module booted up without these error messages and only indicated that FPD upgrade was required. These errors only show up while the module is booting. Once it is in the "IOS XR RUN" state, it looks normal and we do not see any more error messages.
Please let me know if these errors are significant any may affect the operation of this module.
Any feedback is appreciated.
RP/0/RSP0/CPU0:Nov 26 15:19:15.195 UTC: canb-server[153]: %PLATFORM-CANB_SERVER-3-ERROR_INFO : Error from CBC in slot 0/1/CPU0, error msg Device=INTEL 82599, inst=0, errCode=EOBC Niantic-Switch Link Down
RP/0/RSP1/CPU0:Nov 26 15:19:15.200 UTC: canb-server[153]: %PLATFORM-CANB_SERVER-3-ERROR_INFO : Error from CBC in slot 0/1/CPU0, error msg Device=INTEL 82599, inst=0, errCode=EOBC Niantic-Switch Link Down
RP/0/RSP1/CPU0:Nov 26 15:19:25.386 UTC: canb-server[153]: %PLATFORM-CANB_SERVER-3-ERROR_INFO : Error from CBC in slot 0/1/CPU0, error msg Device=INTEL 82599, inst=0, errCode=EOBC Niantic-Switch Link Down
RP/0/RSP0/CPU0:Nov 26 15:19:25.393 UTC: canb-server[153]: %PLATFORM-CANB_SERVER-3-ERROR_INFO : Error from CBC in slot 0/1/CPU0, error msg Device=INTEL 82599, inst=0, errCode=EOBC Niantic-Switch Link Down
RP/0/RSP0/CPU0:Nov 26 15:19:42.083 UTC: canb-server[153]: %PLATFORM-CANB_SERVER-3-ERROR_INFO : Error from CBC in slot 0/1/CPU0, error msg Device=INTEL 82599, inst=0, errCode=EOBC Niantic-Switch Link Down
RP/0/RSP1/CPU0:Nov 26 15:19:42.087 UTC: canb-server[153]: %PLATFORM-CANB_SERVER-3-ERROR_INFO : Error from CBC in slot 0/1/CPU0, error msg Device=INTEL 82599, inst=0, errCode=EOBC Niantic-Switch Link Down
Solved! Go to Solution.
12-01-2019 05:09 AM
These are the links we are interested in
48 | Up | VLAN_EOBC_0 | LC_EOBC_0_0 51 | Up | VLAN_EOBC_0 | LC_EOBC_1_0
As long as they come up, you should be fine
12-01-2019 05:11 AM
hi!
if the card booted up correcty, and is functioning then this is likely not something to worry about (but always a nuisance when you get scary messages) and is likely described with: CSCvn69012
the thing is that during boot, the link status is incorrectly interpreted and reported down.
this is cosmetic if the card boots up correctly. if the eobc (ether out of band, used for rp<>lc communications for image download, lc programming etc) was truly down
then heartbeats would fail and the card would be reloading constantly and eventually end up in-reset.
the root cause is a rommon operation if I am not mistaken. so you could update all fpd's but skip the rommon for the other card possibly.
cheers!
xander
11-29-2019 05:58 AM - edited 11-29-2019 05:59 AM
Good Day,
those error messages are alerting you that the EOBC links are down. these links are the ethernet out of band links that connect the LC to the RSP, to push code/updates etc
this happens on a normal reload. here is output from our lab.
as long as the links come up there is nothing to worry about.
status of all of these links can be checked with the command below.
show controllers epm-switch port-mapping location 0/RSP0/CPU0
you will see "LC_EOBC_X_X" for the links connected to the LC
RP/0/RSP0/CPU0:ASR9904-B#hw-module location 0/1/CPU0 reload Fri Nov 29 13:51:14.328 UTC WARNING: This will take the requested node out of service. Do you wish to continue?[confirm(y/n)]y RP/0/RSP0/CPU0:ASR9904-B#term mon Fri Nov 29 13:51:16.837 UTC RP/0/RSP0/CPU0:ASR9904-B#RP/0/RSP0/CPU0:Nov 29 13:51:17.508 UTC: canb-server[156 ]: %PLATFORM-CANB_SERVER-7-CBC_PRE_RESET_NOTIFICATION : Node 0/1/CPU0 , Power Cy cle (0x05000000) RP/0/RSP1/CPU0:Nov 29 13:51:17.512 UTC: canb-server[156]: %PLATFORM-CANB_SERVER- 7-CBC_PRE_RESET_NOTIFICATION : Node 0/1/CPU0 , Power Cycle (0x05000000) RP/0/RSP0/CPU0:Nov 29 13:51:20.520 UTC: canb-server[156]: %PLATFORM-CANB_SERVER-7-CBC_POST_RESET_NOTIFICATION : Node 0/1/CPU0 , Po wer Cycle (0x05000000) RP/0/RSP1/CPU0:Nov 29 13:51:20.522 UTC: canb-server[156]: %PLATFORM-CANB_SERVER-7-CBC_POST_RESET_NOTIFICATION : Node 0/1/CPU0 , Po wer Cycle (0x05000000) RP/0/RSP1/CPU0:Nov 29 13:51:20.918 UTC: pfm_node_rp[381]: %PLATFORM-CARD-3-CPI_NOT_READY : Set|rspfpga_server[36897]|0x1026003|CPI not ready signal detected on card 0/1/CPU0 RP/0/RSP0/CPU0:Nov 29 13:51:22.162 UTC: shelfmgr[436]: %PLATFORM-SHELFMGR-6-NODE_STATE_CHANGE : 0/1/CPU0 A9K-48X10GE-1G-TR state:B RINGDOWN RP/0/RSP0/CPU0:Nov 29 13:51:22.182 UTC: shelfmgr[436]: %PLATFORM-SHELFMGR-6-NODE_STATE_CHANGE : 0/1/CPU0 A9K-48X10GE-1G-TR state:R OMMON RP/0/RSP0/CPU0:Nov 29 13:51:22.185 UTC: epm_switch_rp[60]: %PLATFORM-EPM_SWITCH-6-EOBC_LINK_DOWN : EOBC port 51 link down towards LC RP/0/RSP0/CPU0:Nov 29 13:51:22.185 UTC: invmgr[270]: %PLATFORM-INV-6-NODE_STATE_CHANGE : Node: 0/1/CPU0, state: BRINGDOWN RP/0/RSP1/CPU0:Nov 29 13:51:22.193 UTC: epm_switch_rp[60]: %PLATFORM-EPM_SWITCH-6-EOBC_LINK_DOWN : EOBC port 51 link down towards LC RP/0/RSP0/CPU0:Nov 29 13:51:24.700 UTC: pfm_node_rp[381]: %PLATFORM-CARD-3-CPI_NOT_READY : Set|rspfpga_server[36897]|0x1026003|CPI not ready signal detected on card 0/1/CPU0 RP/0/RSP0/CPU0:Nov 29 13:51:34.700 UTC: pfm_node_rp[381]: %PLATFORM-CARD-3-CPI_NOT_READY : Clear|rspfpga_server[36897]|0x1026003|CPI not ready signal detected on card 0/1/CPU0 RP/0/RSP1/CPU0:Nov 29 13:51:40.920 UTC: pfm_node_rp[381]: %PLATFORM-CARD-3-CPI_NOT_READY : Clear|rspfpga_server[36897]|0x1026003|CPI not ready signal detected on card 0/1/CPU0 RP/0/RSP0/CPU0:Nov 29 13:53:14.370 UTC: canb-server[156]: %PLATFORM-CANB_SERVER-7-CBC_POST_RESET_NOTIFICATION : Node 0/1/CPU0 , Auto Reset (0x0d000000) RP/0/RSP1/CPU0:Nov 29 13:53:14.374 UTC: canb-server[156]: %PLATFORM-CANB_SERVER-7-CBC_POST_RESET_NOTIFICATION : Node 0/1/CPU0 , Auto Reset (0x0d000000) RP/0/RSP0/CPU0:Nov 29 13:53:17.718 UTC: canb-server[156]: %PLATFORM-CANB_SERVER-3-ERROR_INFO : Error from CBC in slot 0/1/CPU0, error msg Device=INTEL 82599, inst=0, errCode=EOBC Niantic-Switch Link Down RP/0/RSP1/CPU0:Nov 29 13:53:17.721 UTC: canb-server[156]: %PLATFORM-CANB_SERVER-3-ERROR_INFO : Error from CBC in slot 0/1/CPU0, error msg Device=INTEL 82599, inst=0, errCode=EOBC Niantic-Switch Link Down RP/0/RSP0/CPU0:Nov 29 13:53:21.347 UTC: epm_switch_rp[60]: %PLATFORM-EPM_SWITCH-6-EOBC_LINK_DOWN_CLEARED : EOBC port 51 critical link down cleared RP/0/RSP1/CPU0:Nov 29 13:53:27.908 UTC: canb-server[156]: %PLATFORM-CANB_SERVER-3-ERROR_INFO : Error from CBC in slot 0/1/CPU0, error msg Device=INTEL 82599, inst=0, errCode=EOBC Niantic-Switch Link Down RP/0/RSP0/CPU0:Nov 29 13:53:27.916 UTC: canb-server[156]: %PLATFORM-CANB_SERVER-3-ERROR_INFO : Error from CBC in slot 0/1/CPU0, error msg Device=INTEL 82599, inst=0, errCode=EOBC Niantic-Switch Link Down RP/0/RSP0/CPU0:Nov 29 13:53:34.382 UTC: shelfmgr[436]: %PLATFORM-SHELFMGR_HAL-6-BOOT_REQ_RECEIVED : Boot Request from 0/1/CPU0, RomMon Version: 18.27 RP/0/RSP0/CPU0:Nov 29 13:53:34.383 UTC: shelfmgr[436]: %PLATFORM-MBIMGR-7-IMAGE_VALIDATED : Remote location 0/1/CPU0: : MBI tftp:/disk0/asr9k-os-mbi-6.4.2.CSCvj68649-1.0.0/lc/0x3C0266/mbiasr9k-lc-x86e.vm validated RP/0/RSP0/CPU0:Nov 29 13:53:34.386 UTC: shelfmgr[436]: %PLATFORM-SHELFMGR-6-NODE_STATE_CHANGE : 0/1/CPU0 A9K-48X10GE-1G-TR state:MBI-BOOTING RP/0/RSP1/CPU0:Nov 29 13:53:44.609 UTC: canb-server[156]: %PLATFORM-CANB_SERVER-3-ERROR_INFO : Error from CBC in slot 0/1/CPU0, error msg Device=INTEL 82599, inst=0, errCode=EOBC Niantic-Switch Link Down RP/0/RSP0/CPU0:Nov 29 13:53:44.618 UTC: canb-server[156]: %PLATFORM-CANB_SERVER-3-ERROR_INFO : Error from CBC in slot 0/1/CPU0, error msg Device=INTEL 82599, inst=0, errCode=EOBC Niantic-Switch Link Down
11-29-2019 10:51 AM
Thank you very much for your reply and simulating this condition.
Below you will find the output of the command that you have suggested. Let me know if this looks normal.
RP/0/RSP0/CPU0:ios#show controllers epm-switch port-mapping location 0/RSP0/CP$
Fri Nov 29 11:06:39.903 UTC
Port | Link Status | Vlan | Connected to
0 | Down | VLAN_EOBC_0 | OFFLOAD_0_0
1 | Down | VLAN_EOBC_0 | OFFLOAD_1_0
2 | Down | VLAN_DEFAULT | OFFLOAD_2_0
3 | Down | VLAN_DEFAULT | OFFLOAD_3_0
9 | Up | VLAN_PUNT | NIANTIC_0_0
16 | Up | VLAN_PUNT | FPGA_6_0
17 | Up | VLAN_PUNT | FPGA_5_0
18 | Up | VLAN_PUNT | FPGA_7_0
19 | Up | VLAN_PUNT | FPGA_4_0
23 | Up | VLAN_10XGE_SWITCH | 10XGE SWITCH_0_0
24 | Up | VLAN_EOBC_0 | NIANTIC_1_1
25 | Up | VLAN_EOBC_1 | NIANTIC_1_0
36 | Up | VLAN_PUNT | FPGA_0_0
37 | Up | VLAN_PUNT | FPGA_1_0
38 | Up | VLAN_PUNT | FPGA_2_0
39 | Up | VLAN_PUNT | FPGA_3_0
41 | Up | VLAN_DEFAULT | NIANTIC_2_0
54 | Up | VLAN_EOBC_0 | PEER_RP_0_0
55 | Up | VLAN_EOBC_1 | PEER_RP_0_1
We have 2 of these A9K-48X10GE-1G-TR modules installed in the ASR-9904, and we have not upgraded the FPDs on the second unit yet. Both modules boot into the "IOS XR RUN" state, but the unit which was not upgraded does not show any of these messages while booting
Here is the output of the "show hw-module fpd location all" command
RP/0/RSP0/CPU0:ios(admin)#sh hw-module fpd loc all
Tue Nov 26 15:27:47.106 UTC
Existing Field Programmable Devices
HW Current SW Upg/
Location Card Type Version Type Subtype Inst Version Dng?
0/RSP0/CPU0 A9K-RSP880-SE 1.0 lc cbc 0 34.39 No
lc rommon 0 10.65 No
lc fpga2 0 0.66 No
lc fsbl 0 1.109 No
lc lnxfw 0 1.109 No
lc fpga3 0 0.16 No
lc fpga4 0 0.16 No
lc fpga5 0 0.12 No
lc fpga6 0 0.08 No
0/FT0/SP ASR-9904-FAN 1.0 ft cbc 7 31.06 No
0/BPID0/SP ASR-9904-BPID2 1.0 bp cbc 11 7.105 No
0/PS0/M0/SP PWR-3KW-AC-V2 1.0 pm fpga14 13 3.18^ No
pm fpga15 13 3.06^ No
pm fpga16 13 3.12^ No
0/PS0/M1/SP PWR-3KW-AC-V2 1.0 pm fpga14 14 3.18^ No
pm fpga15 14 3.06^ No
pm fpga16 14 3.12^ No
0/PS0/M2/SP PWR-3KW-AC-V2 1.0 pm fpga14 15 3.18^ No
pm fpga15 15 3.06^ No
pm fpga16 15 3.12^ No
0/PS0/M3/SP PWR-3KW-AC-V2 1.0 pm fpga14 16 3.18^ No
pm fpga15 16 3.06^ No
pm fpga16 16 3.12^ No
0/RSP1/CPU0 A9K-RSP880-SE 1.0 lc cbc 0 34.39 No
lc fpga2 0 0.66 No
lc fsbl 0 1.109 No
lc lnxfw 0 1.109 No
lc fpga3 0 0.16 No
lc fpga4 0 0.16 No
lc fpga5 0 0.12 No
lc fpga6 0 0.08 No
0/0/CPU0 A9K-48X10GE-1G-TR 1.0 lc cbc 0 47.03 No
lc rommon 0 18.24 Yes
lc fpga2 0 1.87 Yes
lc fsbl 0 1.104 Yes
lc lnxfw 0 1.104 Yes
lc fpga3 0 1.00 No
lc fpga4 0 1.09 Yes
0/0/CPU0 A9K-48X10GE-1G-TR 1.0 lc fpga3 1 1.00 No
0/1/CPU0 A9K-48X10GE-1G-TR 1.0 lc cbc 0 47.03 No
lc rommon 0 18.27 No
lc fpga2 0 1.88 No
lc fsbl 0 1.110 No
lc lnxfw 0 1.110 No
lc fpga3 0 1.00 No
lc fpga4 0 1.11 No
0/1/CPU0 A9K-48X10GE-1G-TR 1.0 lc fpga3 1 1.00 No
Thank you again for any feedback that you can provide on this issue.
12-01-2019 05:09 AM
12-01-2019 09:49 AM
12-01-2019 05:11 AM
hi!
cheers!
xander
