EVPN VXLAN Layer 2 Data Center Interconnect Gateway
oeche
Hello Guys,
I have an AS9902 connection to a Nexus 9000v.
On the Nexus i have configure a VNI and a VLAN association. I also have configure a peering with the ASR9k.
On the ASR i have configure the EVPN VXLAN Layer 2 Data Center Interconnect Gateway.
On the Nexus 9000v i have an ubuntu server on the vlan 10.
I try to ping the ASR9k on an IP also on the vlan 10 from the ubuntu server.
Configuration on the ASR
interface nve40
member vni 40002
host-reachability protocol bgp
overlay-encapsulation vxlan
source-interface Loopback40
anycast source-interface Loopback41
ingress-replication protocol bgp
Wed Jun 28 00:11:42.255 CEST
evpn
evi 32
evi 40
bgp
route-target import 65020:40
route-target export 65020:40
advertise-mac
bvi-mac
vni 40002 stitching
bgp
route-target import 200:40002
route-target export 200:40002
advertise-mac
l2vpn
bridge group bg1
bridge-domain bd2
routed interface BVI22
evi 40
member vni 40002
interface BVI22
host-routing
vrf 2222
ipv4 address 1.1.1.253 255.255.255.0
mac-address 1001.1001.11
=== On the Nexus ==
evpn
vni 40002 l2
route-target import auto
route-target export auto
vlan 10
vn-segment 40002
interface nve1
no shutdown
source-interface loopback100
member vni 40002
Everything seem's to work fine.
The route are exchange between the ASR and the Nexus.
The MAC addresse table and the inclusive multicast route are there.
But the ASR seems to not take into account a VXLAN packet when it comes from the fabric.
one thing strange on the ASR :
show inter description
nv40 up not ready
If someone can help
Thanks in advance,
M02@rt37
Hello @oeche,
Some ways for troubleshooting:
The output of "show interface description" on the ASR9k shows that "nv40" is "up not ready." This indicates that the NVE interface is up but not fully operational. You should investigate further to determine why the interface is not ready. Check the configuration of the NVE interface, including the source interface and any associated VRFs.
Ensure that the VXLAN tunnel configuration on both the Nexus 9000v and the ASR9k is correct. Verify that the source interfaces (Loopback40 on the ASR9k and loopback100 on the Nexus 9000v) are correctly specified. Additionally, confirm that the VNI (VXLAN Network Identifier) 40002 is consistent on both devices.
Verify that the BGP peering between the Nexus 9000v and the ASR9k is established and functioning correctly. Check the BGP neighbor status and ensure that the correct BGP address families (including EVPN) are being exchanged.
Best regards
M02@rt37
@oeche,
Other thing:
If the MAC addresses are not being learned correctly, review the ingress replication configuration on the ASR9k. Confirm that the appropriate VNI [40002] is configured for ingress replication and that the BGP peering is correctly established.
Best regards
oeche
Hi M02@rt37 ,
Thanks for your help.
On the ASR9k
Wed Jun 28 11:50:49.575 CEST
interface nve40
member vni 40002
Both inter lo40 and lo41 are routed and up.
The BGP session with the N9000v is UP and i received two route :
RP/0/RP0/CPU0:ASR9k#show bgp l2vpn evpn summary
10.154.255.238 0 65020 210090 103803 1038174 0 0 6d20h 36
10.154.255.240 0 65020 151203 40901 1038174 0 0 6d21h 36
18.18.18.18 0 200 3215 3664 1038174 0 0 17:57:19 2  ==> N9000v
Route Distinguisher: 15.15.15.15:32777
*> [2][0][48][5254.0014.6ebd][0]/104 => is the MAC @ of the ubuntu vn connected on the N9k
18.18.18.18 0 200 i
*> [3][0][32][18.18.18.18]/80 => Mutlicast route from the N9k for ingress replication
18.18.18.18 0 200 i
RP/0/RP0/CPU0:ASR9k#show evpn evi bridge-domain bd2 mac
Wed Jun 28 11:56:52.969 CEST
VPN-ID Encap MAC address IP address Nexthop Label SID
40 MPLS 00cc.fceb.a820 :: 10.154.255.236 24062
40 MPLS 00cc.fceb.a820 :: 10.154.255.240 24187
40002 VXLAN 5254.0014.6ebd :: 18.18.18.18 40002
RP/0/RP0/CPU0:ASR9k#show evpn evi bridge-domain bd2 inclusive-multicast
Wed Jun 28 11:57:10.475 CEST
VPN-ID Encap EtherTag Originating IP
40 MPLS 0 10.154.255.236
40 MPLS 0 10.154.255.237
40 MPLS 0 10.154.255.240
40002 VXLAN 0 17.17.17.17 ==> Multicast label for ingress replication for VNI40002 for ASR9k
40002 VXLAN 0 18.18.18.18  ==> Multicast label for ingress replication for VNI40002 for N9k
On the ASR9k i configure a BVI 22 to try to join the Ubuntu VM on the VLAN it doesn't work ...
sphere365
Hi, just wondering have you ever figured this out?
Cheers
