Beginner
FDP Upgrade on RSP880 following a 6.5.3 Turboboot
I installed cXR-6.5.3 on an ASR9006 with dual RSP880 and one A9K-48X10GE-1G-SE. After running through the FDP upgrade procedure I noticed that three FPDs (fpga2, fsbl, lnxfw) on the RSPs failed to upgrade. (or maybe they did but reporting in the output is wrong?)
RP/0/RSP0/CPU0:ios#admin show hw-module fpd location all
Fri Feb 14 07:04:30.955 UTC
Existing Field Programmable Devices
HW Current SW Upg/
Location Card Type Version Type Subtype Inst Version Dng?
0/RSP0/CPU0 A9K-RSP880-SE 1.0 lc cbc 0 34.39 No lc rommon 0 10.65 No
lc fpga2 0 0.42 Yes
lc fsbl 0 1.80 Yes
lc lnxfw 0 1.80 Yes
lc fpga3 0 0.16 No
lc fpga4 0 0.16 No
lc fpga5 0 0.12 No
lc fpga6 0 0.08 No
0/FT0/SP ASR-9006-FAN-V2 1.0 ft cbc 7 5.05 No
0/FT1/SP ASR-9006-FAN-V2 1.0 ft cbc 8 5.05 No
0/PS0/M0/SP PWR-3KW-AC-V2 1.0 pm fpga11 13 6.04^ No
pm fpga12 13 6.02^ No
pm fpga13 13 6.02^ No
0/PS0/M1/SP PWR-3KW-AC-V2 1.0 pm fpga11 14 6.04^ No
pm fpga12 14 6.02^ No
pm fpga13 14 6.02^ No
0/PS0/M2/SP PWR-3KW-AC-V2 1.0 pm fpga11 15 6.04^ No
pm fpga12 15 6.02^ No
pm fpga13 15 6.02^ No
0/PS0/M3/SP PWR-3KW-AC-V2 1.0 pm fpga11 16 6.04^ No
pm fpga12 16 6.02^ No
pm fpga13 16 6.02^ No
0/RSP1/CPU0 A9K-RSP880-SE 1.0 lc cbc 0 34.39 No
lc fpga2 0 0.44 Yes
lc fsbl 0 1.83 Yes
lc lnxfw 0 1.83 Yes
lc fpga3 0 0.16 No
lc fpga4 0 0.16 No
lc fpga5 0 0.12 No
lc fpga6 0 0.08 No
0/0/CPU0 A9K-48X10GE-1G-SE 1.0 lc cbc 0 47.03 No
lc rommon 0 18.27 No
lc fpga2 0 1.88 No
lc fsbl 0 1.111 No
lc lnxfw 0 1.111 No
lc fpga3 0 1.00 No
lc fpga4 0 1.11 No
0/0/CPU0 A9K-48X10GE-1G-SE 1.0 lc fpga3 1 1.00 No
NOTES:
1. One or more FPD needs an upgrade. This can be accomplished
using the "admin> upgrade hw-module fpd <fpd> location <loc>" CLI.
2. ^ One or more FPD will be intentionally skipped from upgrade using CLI with option "all" or during "Auto fpd".
It can be upgraded only using the "admin> upgrade hw-module fpd <fpd> location <loc>" CLI with exact location.
RP/0/RSP0/CPU0:ios#
According to the output there is still an intent to have these RSPs upgraded so I ran the FPD upgrade again followed by a reload for 0/RSP1/CPU0 just to make sure. But again the same reult --> FPD is not upgrading. However, I dont see any error logs other than the message about the FPD upgrade.
Is there any know caveat with the FPD upgrade with that SW-RSP combination.
Many thanks
1 ACCEPTED SOLUTION
Highlighted
Re: FDP Upgrade on RSP880 following a 6.5.3 Turboboot
it could be related to this bug
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvr08100/?rfs=iqvred
can you try installing the smu for it?
3 REPLIES 3
Highlighted
Highlighted
Beginner
.... ohh yeah, that did the trick. Don't know how I missed that SMU.
Many thanks for your help.
Cheers
Highlighted
glad it worked out!
