09-18-2015 10:56 PM
This is a place holder for questions on FN 63979
Details are here: http://www.cisco.com/c/en/us/support/docs/field-notices/639/fn63979.html
Use this thread to ask any questions.
12-04-2015 01:29 AM
Hi Eddie,
We have ASR9k platform and XR version 5.1.2 and are going to install an SMU to fix a bug. I tried to add the SMU but it showed error of certificate expired. I have gone through this thread and different ones. Is it necessary to install CSCup93021 pie or i can just add certificate through below procedure(example)
12-04-2015 01:34 AM
Hi, You'll need to follow these steps:
1) Copy the cert (it looks like you've completed this)
2) Install CSCut52232 (It looks like your missing this)
3) You can then install CSCup93021
Eddie.
12-04-2015 01:42 AM
Hi Eddie,
am sorry i mistyped SMUs in my question. so here i am mentioning the steps again with correct SMUs, pls confirm once more
1. Add cert (have already done through samcmd add cert in shell)
2. Install CSCut52232 (its tagged as hitless means shouldnt interrupt device operations?)
3. Install CSCup93021 (recommnded to fix a bug)
Cheers
12-04-2015 01:52 AM
Correct steps and correct assumption in step 2 about the SMU being hitless.
Eddie.
05-03-2016 01:21 AM
Hi Guys,
I have the same Issue of Nayatel.
From 5.1.2 to 5.1.3
I downloaded the asr9k-px-5.1.2.CSCut52232.tar and installed correctly, after that Do I need to install another package? CSCup93021? for 5.1.2.o 5.1.3 rel?
After that, can I to proceed with upograde to 5.1.3 rel?
Thanks for your help,
A.
05-03-2016 01:30 AM
CSCup93021 is already fixed in 5.1.3 release. You can just upgrade from 5.1.2 to 5.1.3 without SMU for.
Please make sure that all the 5.1.3 recommended SMUs are added and activated on the node.
Santosh
05-03-2016 01:33 AM
Before the uprade I tried to install only asr9k-px-5.1.2.CSCut52232.tar and then upgrade but I receive the same issue: certification expire!
Is it mandatory to install the cert.css from console o Can I install from shell with root and trust?
Thx
A
05-03-2016 01:37 AM
Yes, cert.css is mandatory.
Below will be the set of steps:
1. add "cert.css".
2. install add/activate "asr9k-px-5.1.2.CSCut52232.tar"
3. Install add 5.1.3 pies/SMUs
4. Install activate 5.1.3 pies/SMUs
Santosh
05-03-2016 01:40 AM
Thanks, I will try!!!
A.
05-03-2016 01:45 AM
or if you want to save yourself the hassle, just set your router clock back to 2013 before you upgrade.
05-03-2016 02:12 AM
Thanks guys, I am upgrading ;)
05-03-2016 01:43 AM
Try this
run
03-09-2016 03:46 AM
command "run" will get me into shell and from there I can add the cert?
