ANNOUNCEMENT - The community will be down for maintenace this Thursday August 13 from 12:00 AM PT to 02:00 AM PT. As a precaution save your work.
Highlighted
Golden ISO built failed
When run ./gisobuild.py, below errors seen:
('\n', 'Exception:', <type 'exceptions.RuntimeError'>, RuntimeError("Error CMD=chroot /mnt/hgfs/aaa/tmpfMc211 rpm -qp --qf '%{NAME};%{VERSION};%{RELEASE};%{ARCH};%{PACKAGETYPE};%{PACKAGEPRESENCE};%{PIPD};%{CISCOHW};%{CARDTYPE};%{BUILDTIME};%{GROUP};%{VMTYPE};%{SUPPCARDS};%{PREFIXES};%{XRRELEASE};' asr9k-bng-x64-1.0.0.0-r702.x86_64.rpm returned --->chroot: failed to run command \xe2\x80\x98rpm\xe2\x80\x99: No such file or directory\n",))
Does anyone have ideas?
4 REPLIES 4
Highlighted
Re: Golden ISO built failed
Can you provide the following outputs?
pwd
ls -l
<command line arguments given to giso python script>
<are you calling the script directly or with python gisobuild.py?>
Sam
Highlighted
pwd
/mnt/hgfs/aaa
ls -l
total 1685629
-rwxrwxrwx. 1 root root 0 Jul 27 17:06 1
-rwxrwxrwx. 1 root root 0 Jul 27 17:11 222
-rwxrwxrwx. 1 root root 1655832576 Jul 23 10:07 asr9k-mini-x64-7.0.2.iso
-rwxrwxrwx. 1 root root 2463 Jul 27 15:25 Giso_build.log-2020-07-27:15:03:10.880116
-rwxrwxrwx. 1 root root 2458 Jul 27 21:51 Giso_build.log-2020-07-27:21:21:50.474153
-rwxrwxrwx. 1 root root 141308 Jul 27 12:58 gisobuild.py
 ./gisobuild.py  -i /mnt/hgfs/aaa/asr9k-mini-x64-7.0.2.iso  -r  /mnt/hgfs/aaa/RPM
Thank you
Highlighted
Can you paste the entire build log?
Are you the root user?
Are you using the latest version of the script?
Also there are some hits on google about this error string, so it might be an error with the script:
https://stackoverflow.com/questions/50522550/python-unicode-and-xe2-x80-x98r-xe2-x80-x99-error
Sam
Highlighted
Hi Sam
The issue already resolved. The problem is due to chroot function, I put the script and .iso file to root directory, then it worked.
Thanks for your help!
Content for Community-Ad
