High card temperature on Chassis ASR 9922
ccarloscorrea
Hi guys,
I work in a company where there are 4 ASR 9922 chassis newly installed, each have 4 and 5 cards SFC. They have the same behavior of high temperature over 40 ° C (as the website says Ciscohttp://www.cisco.com/c/en/us/products/collateral/routers/asr-9000-series-aggregation-services-routers/data_sheet_c78-501767.html ) In the NPs, FIA and other components. Currently, there is no traffic through them, all were installed correctly and tell us the installation guide procedure (http://www.cisco.com/c/en/us/td/docs/routers/asr9000/hardware/installation/guide/asr9kHIGbk/asr9kIGprep.html). These chassis are installed at different sites that have a room temperature 21°C. Could someone tell me that can be happening?
Here is fragment  from "show  environments."
R/S/I Modules Sensor (deg C)
0/RP0/*
host die_CPU 39.0
host die_FabArbiter0 43.0
host die_FIA 43.0
host die_FabSwitch0 56.0
host temp_u18cb 24.5
host temp_u16cb 40.6
host temp_u14cb 36.1
host temp_u12cb 28.0
host temp_u17cb 34.5
host temp_u15cb 40.0
host temp_u13cb 30.9
host temp_u11cb 36.1
host Inlet0 24.3
host Hotspot0 40.6
0/RP1/*
host die_CPU 39.5
host die_FabArbiter0 54.0
host die_FIA 56.0
host die_FabSwitch0 45.0
host temp_u18cb 25.1
host temp_u16cb 34.0
host temp_u14cb 29.5
host temp_u12cb 34.3
host temp_u17cb 38.6
host temp_u15cb 44.8
host temp_u13cb 32.8
host temp_u11cb 39.7
host Inlet0 25.0
host Hotspot0 34.0
0/6/*
ep0 Inlet0 36.0
ep0 Hotspot0 44.0
host die_NP0 74.0
host die_NP1 72.0
host die_NP2 63.0
host die_NP3 65.5
host die_FIA0 64.0
host die_FIA1 63.0
host die_FIA2 59.0
host die_FIA3 56.0
host die_FabSwitch 66.5
host Inlet0 30.0
host Hotspot0 55.3
0/9/*
host die_NP0 78.0
host die_NP1 68.5
host die_NP2 70.5
host die_NP3 65.5
host die_NP4 66.0
host die_NP5 70.5
host die_NP6 60.0
host die_NP7 68.5
host die_FIA0 58.0
host die_FIA1 48.0
host die_FIA2 59.0
host die_FIA3 67.0
host die_FabSwitch 71.0
host db_np_0 66.2
host db_np_1 57.9
host db_skt_0 54.2
host db_inlet 36.7
host bb_inlet 30.5
host bb_hotspot_0 54.1
host bb_exhoust_0 66.4
host bb_exhoust_1 61.0
host bb_hotspot_1 54.6
host Inlet0 30.1
host Hotspot0 54.3
0/16/*
ep0 Inlet0 35.5
ep0 Hotspot0 42.6
host die_NP0 64.5
host die_NP1 68.5
host die_NP2 57.0
host die_NP3 61.5
host die_FIA0 67.5
host die_FIA1 67.0
host die_FIA2 61.5
host die_FIA3 59.0
host die_FabSwitch 64.0
host Inlet0 30.3
host Hotspot0 52.8
0/19/*
host die_NP0 67.5
host die_NP1 65.0
host die_NP2 67.5
host die_NP3 62.5
host die_NP4 63.5
host die_NP5 64.0
host die_NP6 53.5
host die_NP7 58.5
host die_FIA0 58.0
host die_FIA1 49.0
host die_FIA2 57.0
host die_FIA3 63.0
host die_FabSwitch 69.0
host db_np_0 60.5
host db_np_1 56.0
host db_skt_0 49.4
host db_inlet 34.9
host bb_inlet 34.9
host bb_hotspot_0 54.8
host bb_exhoust_0 64.1
host bb_exhoust_1 60.3
host bb_hotspot_1 52.0
host Inlet0 34.8
host Hotspot0 54.8
xthuijs
hi carlos,
actually I want to say that these temperatures are not that bad. the modular cards are a bit hotter then what I would expect to see but your inlet temperatures are somewhat high also, could it be that the air flow is obstructed?
possibly as a suggestion you could tweak the altitude of the system so that the fans spin a bit faster to provide more cooling.
admin config: environment altitude 4000
it might need a few minutes to adjust the fan speeds.
at my 3000 meter config I have fan speeds of 6000rpm that can be seen via admin show env fan
cheers
xander
here is a snippet from my lab 9922:
RP/0/RP1/CPU0:ASR9922#admin show env temp
Wed Aug  3 12:09:52.163 EDT
0/RP0/*
        host    die_CPU                 34.5
        host    die_FabArbiter0         45.0
        host    die_FIA                 42.0
        host    die_PCH                 38.0
        host    die_DIMM0               32.0
        host    die_DIMM1               32.0
        host    die_DIMM2               32.0
        host    die_DIMM3               30.0
        host    die_FabSwitch0          42.0
        host    air_inlet               28.4
        host    sm15_0_downstream       39.3
        host    sm15_0_inlet            35.4
        host    sm15_1_upstream         30.5
        host    air_outlet              32.3
        host    Inlet0                  28.4
        host    Hotspot0                39.3
0/8/*
        host    die_NP0                 63.0
        host    die_NP1                 47.0
        host    die_FabArbiter0         50.0
        host    die_FIA0                53.5
        host    die_FIA1                46.0
        host    die_FabSwitch           60.0
        host    die_DPSwitch            48.5
        host    die_CPU                 39.0
        host    Hotspot1                44.5
        host    Hotspot2                38.5
        host    bb_inlet                31.3
        host    bb_hotspot_0            38.1
        host    bb_hotspot_1            40.5
        host    db_inlet                28.1
        host    db_outlet               40.7
        host    apm_inlet               32.0
        host    Inlet0                  31.3
        host    Hotspot0                38.1
0/14/*
        ep0     Inlet0                  28.7
        ep0     Hotspot0                35.3
        ep1     Inlet0                  26.0
        ep1     Hotspot0                31.6
        host    die_NP0                 42.5
        host    die_NP1                 51.5
        host    die_FIA0                50.5
        host    die_FIA1                46.0
        host    die_FabSwitch           52.0
        host    Inlet0                  26.8
        host    Hotspot0                36.6
Hi xthuijs,
Thanks you for reading my post. The air flow ins't obstructed.I think that it change this parameter, Could not degrade the life of the fans? because I don't know if the chassis systems have a temperature controller. What do you say?
I changed my system to the default alititude and I saw my fan speed dropping to 4k rpm.
the temperatures start to match what you are having at 60C.
as long as they are below 90C is what you must maintain.
I think you'll want to set the altitude to 4000meters to increase the fan speed and get some more airflow. the fan trays are rated up to 14k rpm.
so with the adjustment well within bounds! :)
cheers!
xander
please follow the advice in Field Notice FN 64117, there is an issue with the default fan speed (RPM) on that box.
http://www.cisco.com/c/en/us/support/docs/field-notices/641/fn64117.html
greetings
thomas
