How to capture packet on cisco XRV 9K?
Tim.Yu
I tried a lot commands from normal ASR 9000, but seems none works on XRV.
Can anyone help me?
Aleksandar Vidakovic
If you want to see what is happening in the dataplane, you could use:
debug controllers dpa packet-trace [line|inject]
show controllers dpa packet-trace
clear controllers dpa packet-trace
Sorry the command does not exist
RP/0/0/CPU0:Edge1#show version
Mon May 22 08:51:39.787 UTC
Cisco IOS XR Software, Version 6.1.2[Default]
Copyright (c) 2016 by Cisco Systems, Inc.
ROM: GRUB, Version 1.99(0), DEV RELEASE
Edge1 uptime is 2 hours, 9 minutes
System image file is "bootflash:disk0/xrvr-os-mbi-6.1.2/mbixrvr-rp.vm"
cisco IOS XRv Series (Intel 686 F6M14S3) processor with 4193854K bytes of memory.
Intel 686 F6M14S3 processor at 2678MHz, Revision 2.174
IOS XRv Chassis
1 Management Ethernet
9 GigabitEthernet
97070k bytes of non-volatile configuration memory.
866M bytes of hard disk.
2321392k bytes of disk0: (Sector size 512 bytes).
Configuration register on node 0/0/CPU0 is 0x2102
Boot device on node 0/0/CPU0 is disk0:
Package active on node 0/0/CPU0:
iosxr-infra, V 6.1.2[Default], Cisco Systems, at disk0:iosxr-infra-6.1.2
RP/0/0/CPU0:Edge1#debug co?
comms condition config connected
coordinator correlator
This is XRv, not XRV9k.
XRv doens't have a data-plane, only control plane. Hence no 'DPA'.
If you know which process is receiving the packets and they come at high rate, you could use the "show packet-memory job ..." command.
