How to find all routes that are going out an interface in IOS-XR.
acivciss
Hi all,
So if I have the following set up in IOS:
interface GigabitEthernet7/0/0.265
encapsulation dot1Q 265
ip vrf forwarding test
ip address 1.1.1.1 255.255.255.252
ip verify unicast reverse-path
end
ip route vrf Apollo 2.2.2.0 255.255.255.248 1.1.1.2
I can see all the routes that are going out the interface using show ip cef command:
ios-router#show ip cef vrf test GigabitEthernet7/0/0.265
2.2.2.0/29
  nexthop 1.1.1.2 GigabitEthernet7/0/0.265
1.1.1.0/30
  attached to GigabitEthernet7/0/0.265
1.1.1.2/32
In case of IOS-XR (ASR9K 4.3.2 or 4.3.1) the same setup and command shows only
attached routes:
router static
vrf test
  address-family ipv4 unicast
   2.2.2.0/29 1.1.1.2
RP/0/RSP0/CPU0:TST_riga-sb7-pe-asr9#show cef vrf test bundle-ether2.265
Prefix              Next Hop            Interface
1.1.1.0/30          attached            Bundle-Ether2.2220333
1.1.1.0/32          broadcast           Bundle-Ether2.2220333
1.1.1.1/32          receive             Bundle-Ether2.2220333
1.1.1.2/32          1.1.1.2             Bundle-Ether2.2220333
1.1.1.3/32          broadcast           Bundle-Ether2.2220333
Is there any command to see all the routes that are going out an interface without complicated parsing
of the configuration, recursive show cef commands etc.?
Bryan Garland
You can accomplish this with the "show route" command.  Here is an example:
P/0/RSP1/CPU0:ASR9006-E#sh route next-hop tenGigE 0/3/0/2
Tue Oct  8 15:34:58.046 UTC
Codes: C - connected, S - static, R - RIP, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
       i - ISIS, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, su - IS-IS summary null, * - candidate default
       U - per-user static route, o - ODR, L - local, G  - DAGR
       A - access/subscriber, - FRR Backup path
Gateway of last resort is 172.18.87.1 to network 0.0.0.0
D    10.95.248.1/32 [90/128512] via 10.129.56.210, 4d00h, TenGigE0/3/0/2
C    10.129.56.208/30 is directly connected, 4d00h, TenGigE0/3/0/2
L    10.129.56.209/32 is directly connected, 4d00h, TenGigE0/3/0/2
O    10.242.142.240/30 [110/20] via 10.129.56.210, 3d11h, TenGigE0/3/0/2
                       [110/20] via 10.129.56.214, 3d11h, TenGigE0/3/0/3
D    192.168.1.16/32 [90/128512] via 10.129.56.210, 4d00h, TenGigE0/3/0/2
D    192.168.20.39/32 [90/128512] via 10.129.56.210, 4d00h, TenGigE0/3/0/2
RP/0/RSP1/CPU0:ASR9006-E#
Bryan
Bryan Garland
Bryan
