HSRP ASR9K vs ASR900 Shutdown
vin.marco
Hi everyone
I have a problem with an HSRP setup on ASR9K with ISO version 6.2.3.
I configured HSRP between two routers, ASR9K and ASR 903 on BDI interface, below is the configuration:
Configuration ASR9K
interface TenGigE0/2/0/12.771 l2transport
 description Link to Nutanix#1 - CUCM
 encapsulation untagged
 l2protocol cpsv tunnel
interface TenGigE0/2/0/13.771 l2transport
 description Link to Nutanix#2 - CUCM
interface TenGigE0/2/0/14.771 l2transport
 description Link to Nutanix#3 - CUCM
interface TenGigE0/2/0/23.771 l2transport
 description Link to ASR 903 for HSRP V771
interface BVI771
 description Server Farm CUCM DF
 vrf XXXXX
 ipv4 address XX.XX.XX.XXX 255.255.255.128
l2vpn
 bridge group CUCM_DF
  bridge-domain Vlan-771
   routed interface BVI771
l2vpn
router hsrp
 interface BVI771
  address-family ipv4
   hsrp 100
    preempt
    priority 150
    track object v771 60
track v771
 type list boolean and
  object v771-TenGigE0-2-0-12
  object v771-TenGigE0-2-0-13
  object v771-TenGigE0-2-0-14
track v771-TenGigE0-2-0-12
 type line-protocol state
track v771-TenGigE0-2-0-13
track v771-TenGigE0-2-0-14
I configured tracking for three interfaces that decrease the priority by 60 on the ASR9000.
I would like HSRP not to decrement by 60 but to shutdown the interface , the command does not exist....
Can you tell me why?
I Dont think it ver. Issue
Ios xr support this feature
Ios xe (asr900) not support it.
Try EEM.
Thanks A Lot
MHM
vin.marco
I saw that on the ASR900 router the shutdown command exists while in XR it doesn't.
ASR903(config-if)#standby 100 track 100 ?
  decrement  Priority decrement
  shutdown   Shutdown group
  <cr>       <cr>
ASR9000(config)#router hsrp interface bvI 771 address-family ipv4 hsrp 100 track object v771 ?
  <1-255>  Priority decrement
  <cr>
I fast check commend reference,
as you mention there is no shutdown there is only decrement.
you can instead use EEM to shut the interface BVI if the track (all) status is down
Thanks A Lot
MHM
In fact I had thought about using EEM to shut the interface, but I wanted to understand if it was an IOS version problem or something else.
Thank you
Try EEM.
Thanks A Lot
MHM
