o-evdokimov
Beginner
HTTP-Redirect doesn't work on BNG (ASR9000, XR 4.3.0)
Hi, All
1) I need to do http-redirect for IPoE subscribers. Ideally I need to do http-redirect only for some users depending on reply recieved from Radius (accept/reject) or depending on some attribute from Radius. For test I add 15 rule in my control policy-map.
If I remove 15 rule in the policy-map IPOE_POLICYMAP than session activate. But If I use policy-map with 15 rule my BNG send DHCP NAK in reply and user try to re-obtain IP-address. Discover/NAK-Discover/NAK and so on. Session don't establish. Where is issue?
without 15 rule:
DHCPD PROXY: TP1908: Requesting handler called for chaddr aaaa.bbbb.cccc with event PACKET
DHCPD PROXY: TP2483: Will use reply server identifier 213.x.x.254 for yiaddr 213.x.x.211 for chaddr aaaa.bbbb.cccc
with 15 rule:
DHCPD PROXY: TP1908: Requesting handler called for chaddr 0015.582c.96cb with event DPM_DISCONNECT
DHCPD PROXY: TP2805: Client delete called for chaddr 0015.582c.96cb due to reason Session disconnected
DHCPD PROXY: TP1908: Requesting handler called for chaddr 0015.582c.96cb with event DROP-PACKET
2) Can I force to do "http-redirect" via VSA Avpair attributes sent from Radius to BNG in ACCESS-ACCEPT? For example I
successfully do car limit via "sub-qos-policy-in/sub-qos-policy-out". It seems cisco-avpair= "url-redirect=http://..." doesn't work with ASR9000.
3) Why IPoE session stay unauthenticated after ACCESS_ACCEPT has been recieved from Radius? It is normal for IPoE?
I see "sh ipsubscriber session all detail" and "sh radius".
interface Bundle-Ether1.10
description HOMENET
ipv4 point-to-point
ipv4 unnumbered Loopback1
arp learning disable
service-policy type control subscriber IPOE_POLICYMAP
encapsulation dot1q 10
ipsubscriber ipv4 l2-connected
   initiator dhcp
class-map type control subscriber match-any DHCP_INIT
match protocol dhcpv4
end-class-map
policy-map type control subscriber IPOE_POLICYMAP
event session-start match-all
  class type control subscriber DHCP_INIT do-until-failure
    5 authorize aaa list default format SUB_AUTH password cisco
   10 activate dynamic-template IBSUB_TEMPLATE
   15 activate dynamic-template IPSUB_UNAUTH_TEMPLATE         <-- !!!!!!!!!!
dynamic-template
type ipsubscriber IBSUB_TEMPLATE
  ipv4 access-group 100 ingress
  ipv4 access-group 100 egress
type ipsubscriber IPSUB_UNAUTH_TEMPLATE
  service-policy type pbr l4_redirect
policy-map type pbr l4_redirect
class type traffic IPSUB_PERMIT_CLASS
   transmit
class type traffic HTTP_TRAF_REDIRECT_CLASS
   http-redirect http://113.x.x.5
class type traffic class-default
   drop
end-policy-map
class-map type traffic match-any IPSUB_PERMIT_CLASS
match access-group ipv4 110
end-class-map
class-map type traffic match-all HTTP_TRAF_REDIRECT_CLASS
match access-group ipv4 120
end-class-map
ipv4 access-list 100
10 permit icmp any any
20 permit udp any any
30 permit tcp any 113.x.x.0/24 eq www
40 permit tcp 113.x.x.0/24 eq www any
100 deny ipv4 any any
ipv4 access-list 110
ipv4 access-list 120
30 permit tcp any any eq www
1 ACCEPTED SOLUTION
Oleg, another pointer, the first thing you should see is if the pbr is actually being applied to your session, like this:
RP/0/RSP0/CPU0:BNG#show policy-map type pbr int all
Mon Oct  7 23:54:19.361 UTC
node0_0_CPU0: (null): Service Policy not installed
node0_RSP0_CPU0:
Bundle-Ether100.540.ip395 input: HTTPRDRT_PBR
Policy Name: HTTPRDRT_PBR
Class SRVS_CM
  Classification statistics          (packets/bytes) (May be 10secs old)
    Matched             :                 197/17039
  Transmitted statistics             (packets/bytes) (May be 10secs old)
    Total Transmitted   :                 197/17039
Class HTTPRDRT_CM
  Classification statistics             (packets)
    Matched             :                   0
  Httpr statistics                      (packets)
    Requests Received   :                   0
    Responses Sent      :                   0
    Redirect drops      :                   0
Class class-default
    Matched             :                   1/102
  Dropped statistics                 (packets/bytes) (May be 10secs old)
    Total Dropped       :                   1/102
IF you see this and it still doesn't work, then you need to take a look at your redirect config, that for my testing i used and ACL that would permit all tcp/www traffic. i never denied any traffic, like you do on line 100.
10 REPLIES 10
xthuijs
Looks like you are redirecting your redirected traffic baed on this httpr service definition...
Can you google asr9000 http redirect, you find a YouTube with a CFO example
Regards Xander
Alexander, thank you for answer. Of course, I have seen "asr9000 http redirect" from YouTube. But I don't see any differencies between it and mine example. I don't understand what is mean "...you are redirecting your redirected...".
My "open-garden" and "redirect" acls are seen identical to youtube's example. My portal has IP from subnet 113.x.x/24
# open-garden
10 permit tcp any 113.x.x.0/24 eq www log
20 permit udp any any eq domain log
30 permit icmp any any log
#redirect
10 permit tcp any any eq www syn log
20 permit tcp any any eq www ack log
30 permit tcp any any eq www log
My DHCP dump from client:
# with "15 activate dynamic-template IPSUB_UNAUTH_TEMPLATE" -> get DHCP NAK
0.0.0.0          255.255.255.255     DHCP     342     DHCP Discover - Transaction ID 0xae04c951
ASR9000          255.255.255.255     DHCP     363     DHCP Offer    - Transaction ID 0xae04c951
0.0.0.0          255.255.255.255     DHCP     344     DHCP Request  - Transaction ID 0xae04c951
ASR9000          255.255.255.255     DHCP     303     DHCP NAK      - Transaction ID 0xae04c951
# without rule 15 -> get DHCP ACK 0.0.0.0          255.255.255.255     DHCP     342     DHCP Discover - Transaction ID 0xc9c27e06 ASR9000          255.255.255.255     DHCP     363     DHCP Offer    - Transaction ID 0xc9c27e06 0.0.0.0          255.255.255.255     DHCP     344     DHCP Request  - Transaction ID 0xc9c27e06 ASR9000          255.255.255.255     DHCP     363     DHCP ACK      - Transaction ID 0xc9c27e06
Do you have any ideas?
Hi Oleg,
I tried to use that ipad app and it didn't pay off, I immediately started to give crap answers, apologies
I see what is going wrong now; your PBR template is type ipsubscriber, and it needs to be type service
otherwise the configs dont merge properly.
ps. better not use log in the ACL's for policies, not sure if this even meant to work...
Say as for alternatives, you can also use the author failure event (access reject) in a logic like this below.
And yes you can also enable a service via an access-accept and even a COA request!
The precise attributes I have documented in the article for all the VSA's, let me know if you cant find it.
you're using 430, we have 432 out this week, may want to try that also but merely as deployment release when you're ready.
Example TAL policy with HTTPR on auth failure.
policy-map type control subscriber TAL_WEB_LOGON_PM
event session-start match-first
  class type control subscriber DHCP do-until-failure
   20 authorize aaa list AAA identifier source-address-mac password cisco
event authorization-failure match-first
   10 activate dynamic-template IPSUB_UNAUTH_TEMPLATE
   20 set-timer UNAUTH_TMR 7
event account-logon match-first
   10 authenticate aaa list AAA
   20 deactivate dynamic-template HTTPRDRT_TPL
   30 activate dynamic-template IBSUB_TEMPLATE
event timer-expiry match-first
   10 disconnect
end-policy-map
Hi Alexander
I need help. A little.
Step 1:
I have done the both dynamic templates as "type service" as you advise. As before the session is not establish and user host don't get IP-address by dhcp (user get DHCP NAK).
Step 2:
I've found the guide "ASR9000/XR: BNG VSA's." and there is VSA "sub-pbr-policy-in" attribute in.
URL https://supportforums.cisco.com/docs/DOC-35624
I try to use the VSA "subscriber:sub-pbr-policy-in=" from it.
If I get this VSA in radius ACCEPT I have the same situation as in Step 1.
RADIUS: cisco-avpair="subscriber:sub-pbr-policy-in=l4_redirect"
ASR9k:
  transmit
  http-redirect http://10.10.10.10
  drop
end-class-map
class-map type traffic match-any HTTP_TRAF_REDIRECT_CLASS
end-class-map
10 permit tcp any 10.10.10.0/24 eq www
And I cannot find VSA "sub-pbr-policy-in" in the official Configuration Guide Release 4.3.x for ASR9k.
Step 3:
OK. I move http-redirect rule to another ASR9k event "logoff" and then I do COA request (logoff).
1) ASR9k: Session IPoE is established
Policy Executed:
  event Session-Start match-all [at Thu Oct 17 01:12:45 2013]
    class type control subscriber DHCP_INIT do-until-failure [Succeeded]
      2 authorize aaa list default [Succeeded]
      5 activate dynamic-template IBSUB_TEMPLATE [Succeeded]
Session Accounting: disabled
Last COA request received: unavailable
2) Sent COA request
# echo "User-Name=\"0015.582c.96cb\",cisco-avpair=\"subscriber:command=account-logoff\",Cisco-Account-Info=\"S0015.582c.96cb\",Idle-Timeout=200" | radclient -x :1700 coa coa-pass
3) ASR9k: Upgrade session
Policy Executed:
  event Account-Logoff match-all [at Thu Oct 17 01:13:02 2013]
    class type control subscriber class-default do-until-failure [Succeeded]
      10 activate dynamic-template IPSUB_UNAUTH_TEMPLATE [Succeeded]
      20 set-timer UNAUTH-TIMER 1 [Succeeded]
Last COA request: Thu Oct 17 01:13:02 2013
COA Request  Attribute List: 0x500eba58
1:  idletimeout     len=  4  value= 200(c8)
2:  command         len= 15  value= account-logoff
Last COA response: Result ACK
COA Response  Attribute List: 0x500ebc68
4) Checking...
TIMER UNAUTH-TIMER set to 1 minute
but HTTP-REDIRECT don't work  !!!
5) Timer expire  (1 minute)
6) Session IPoE destroy
So
- timer works fine
- HTTP REDIRECT don't work  (dynamic-template IPSUB_UNAUTH_TEMPLATE)
I don't understand why.
Hi Oleg,
In order to traige this further I probably need a lot of debugs, I see this working fine for me.
It might be best to open a tac case so we can assemble those logs and troubleshoot this more effectively.
regards
xander
Oleg,
when you say http redirect don't work, what do you mean? what is the behavior that you see?
do you turn off your browser and reopen it when trying to see if it works?
regards,
c.
node0_RSP0_CPU0:
Class SRVS_CM
    Matched             :                 197/17039
Class HTTPRDRT_CM
    Matched             :                   0
    Responses Sent      :                   0
    Redirect drops      :                   0
Class class-default
    Matched             :                   1/102
First I've done "sh policy-map type pbr interface all". PBR wasn't applied.
Then I've removed "deny any any" and [oh, miracle!] IPoE session has established and HTTP-Redirect begun to work correctly.
[I do http-redirect by getting VSA with radius ACCEPT - cisco-avpair="subscriber:sub-pbr-policy-in=l4_redirect"].
RP/0/RSP0/CPU0:BNG1#sh policy-map type pbr interface all
Bundle-Ether1.900.ip9 input: l4_redirect
Policy Name: l4_redirect
Class HTTP_TRAF_REDIRECT_CLASS
    Matched             :                 147
    Requests Received   :                 147
    Responses Sent      :                  68
    Redirect drops      :                  79
Then I've been tried to return back "deny any any" and after commit ASR9k wrote:
"process : pkg/bin/pbr_ea pid : 508058 node : node0_0_CPU0 rc :'platforms/viking/lc/feature/pbr' detected the 'warning' condition 'Deny ACE not supported in ACL when used in PBR policy'"
But if first do "incorrect" ACL and after do PBR used it ASR9k will do "commit" config without any errors!
Carlos and Aleksander, thank you for help.
Hi Oleg, very good to hear the issue is resolved.
and yes, the PBR ACL doesnt like "deny" statements, similar as QOS ACL btw.
xander
