Interop between ASR9K and ALU 7750
fbloss100
Beginner
Beginner
Has anyone been successful at getting a L2VPN established between these two chassis? It appears the ALU is good (LSP/SDP is up/up) but the L2VPN (VPLS instance) will not establish. I'm using RSVP signalling and the LSP(ALU) is up and the Tunnel-TE (Cisco) interface is up. It appears to be a problem with LDP. I tried just straight LDP signalling and had the same problem. Any help would be great.
Sunil Bhadauria
Beginner
Beginner
Hello Fbloss100
I believe i misread the problem statement and so correcting my response as well .
Sounds like below is the concerned configuration :
l2vpn
 pw-class test
  encapsulation mpls
   preferred-path interface tunnel-te 1
 bridge group test1
  bridge-domain test1
   neighbor 104.153.31.93 pw-id 101
    pw-class test
   routed interface BVI101
Yet, i do not see any attachment Circuit configuration in this configuration as well. Without it i believe it will not work .
Could you paste output of " show l2vpn bridge-domain bd-name test1 detail "
Sunil Bhadauria
Recognize Your Peers
