IOS XR - PER VRF BGP NEXT-HOP Loopback
tomislavcer
does anybody know what would be proposed solution for migrating IOS config below to IOS XR ?
IOS =>
vrf data
rd 10000:100
route-target both 10000:100
bgp next-hop loopback100
where loopback 100 is used for MPLS TE traffic routing (per VRF MPLS TE).
In IOS XR there is no possibility to migrate configuration in similar way, so I would like to know is there some by-the-book proposed solution for that ?
thank you
xthuijs
you can apply a route-policy to the route-target config like this, did you try that by any chance already?
vrf Tomislav
address-family ipv4 unicast
  import route-policy setNH
  import route-target
   100:123
route-policy setNH
  set next-hop 1.2.3.4
end-policy
cheers!
xander
Thank you Xander.
This was way to go since I couldn't find upper mentioned equivalent for IOS XR,  but I wanted to check first did I maybe miss something.
regards
Hy,
just to see another issue with this topic.
Let's say that we have Lo0 as global routing loopback and BGP router-id. And, we have Loop 100 for this TE purpose.
How to export from ASR and set next-hop ? I guess I can not do it inside global VRF config with export-policy right, because next-hop will be anyway  set to Loopback0 toward VPNV4 route-reflector, and not Loopback 100 right ?
