IOS XR Release 5.3.4 for ASR9000 and CRS
Aleksandar Vidakovic
[toc:faq]
IOS XR Release 5.3.4 Introduction
IOS XR release 5.3.4 is a supplemental Extended Maintenance Release for the ASR9000 and CRS platforms. The previous EMR 5.3.3 maintains the EMR status. IOS XR release 5.3.4 is the Cisco suggested software release for all ASR9000 and CRS deployments.
The driver for XR release 5.3.4 was to provide a leaner 5.3.x SW package for the older generation of ASR9000 and CRS cards because beyond XR release 5.3.x these older generation cards are not supported. The end goal is much more than that: XR release 5.3.4 enhances the quality of 5.3.3 release by:
  • Hardening target areas:
    • A9K-VSM-500 infrastructure
    • BNG:
      • special attention to PWHE and Satellite as subscriber access interfaces
      • Geo-Redundancy
    • FPD
    • EnvMon on ASR9K
    • Infrastructure hardening on CRS
  • Integrating selected SW fixes:
    • Released 5.3.x Production SMUs
    • Selected customer found SW defects (bug scrub, early trial, 5.3.x deployments)
    • fixes for SW bugs found during 5.3.4 test cycle
XR Release 5.3.4 Content and Delivery
Feature content of XR release 5.3.4 is identical to 5.3.3.
Early Trial
Early trial is closed with the posting of the release.
64 Replies 64
I have used it once and it was working fine. Just give it a try.
So it will work ? as per the combination above ? I will try it
But what confused me is how Cisco sent a notification that the 5.3.4 install kit is available and it's not
It was definitely available at some point, I downloaded asr9k-ism-cgv6-install-kit.5.3.4.00.sh from software.cisco.com soon after it was made available.  It seems to have been removed from the site since then.
I guess ISM is no longer officially supported on 5.3.4 although I am sure a previous version of this discussion mentioned that 5.3.4 would be the last supported version for ISM (as well as Trident cards)
Hi Martin
Thanks for the reply
I have downloaded the 5.3.4 software with 5.3.3 install-kit and seems it's working fine till the moment :)
I was checking the software and I found 6.1.2 is available (which I was waiting for as I have QSFP-40G-ER4 which is supported on this software release)
I am searching for the release notes but could not find it , can anyone share it? and is there anything new/special in the installation or it's the usual procedure?
Thanks in advance
BR,
Mohammad
hi Mohammad,
we don't claim support for the combination of 5.3.4 IOS XR image and 5.3.3 ISM install kit. Please reach out to your account team at Cisco. There's an interesting programme for migrating ISM to VSM. VSM will bring you many benefits and also a much longer support cycle.
Release 6.1.2 was posted yesterday. The Release Notes will follow this week.
hope this helps,
/Aleksandar
I can confirm that ISM install kit 5.3.3 is working fine on IOS-XR 5.3.4.
Nevertheless, an upgrade to VSM-500 is the only option to be safe.
Hi Aleksandar
Yes I know , I just wanted to migrate to the recommended release :)
I already have two VSMs and the customer wants to utilize the ISM as well
Thanks for the information
As the 6.1.2 release was posted on Cisco website , I can download it and install it without issues right?
hi Mohammad,
yes, all releases that we post to software download portal on cisco.com can be used. Our suggestion for general deployment is always the latest EMR (at this point 5.3.4), but you are free to use any other release. The EMR 6.1.3 will be available in about 3 months from now.
/Aleksandar
Hi Aleksandar
Hope this finds you well
I can see that the release notes is available now :
http://www.cisco.com/c/en/us/td/docs/routers/asr9000/software/asr9k_r6-1/general/release/notes/b-release-note-asr9k-612.html#id_34254
But there is something I want to make sure of please
In the Cisco ASR 9000 Series Aggregation Services Router Line Cards table , i can see under the VSM on version 6.1.2 is not supported , what does that really means?
It is not supported for the 64 bit version, you need to use the 32 bite version.
Hi Aleksandar
I tried on two different ASR9K to install add the 6.1.2 mini package
Error:    the 'fatal' condition 'An attempt to read()/write() failed.': Connection timed out.
Error:    Suggested steps to resolve this:
Error:     - check the network connectivity.
Error:     - check the disk or file for corruption.
Error:     - repeat the operation after waiting for a while, or copy the file via tftp to the router's disk using the copy tftp: <device> command, then install the
Error:       local file.
Error:
Error:    The following pie was not added due to an error:
Error:        asr9k-mini-px.pie-6.1.2
Install operation 26 failed at 15:42:30 EET Sun Nov 20 2016.
BR,
Mohammad
Please check the connectivity to the ftp server. If everythings is ok then you also try to copy the pkg to the routers disk, like it was suggested in the logs.
I have downloaded the 5.3.4 PIE files
I have reserved the necessary space , what I have faced when issuing the command admin install add ftp://x.x.x.x/mini (FTP tested and worked with another PIE files) is that I was prompted with the message pie file corrupted when reaching 49% each time!
BR,
Mohammad
please check the hash of the pie and compare it. Use this tool if you are using Win OS.
http://www.winmd5.com/
Here is the list.
049945c5267bbe840a4d83e9fe14211c asr9k-asr9000v-nV-px.pie-5.3.4
60f34e2eaa9e83f8f89e6acd2f222a9c asr9k-asr901-nV-px.pie-5.3.4
5a98dbf90d61942ea84aedc8dcf554af asr9k-bng-px.pie-5.3.4
19748040239390a30dd2f814a04a3fe2 asr9k-doc-px.pie-5.3.4
91fe24ff977a369ce8e751f1b6e02c1a asr9k-fpd-px.pie-5.3.4
e809d55203d446dfe9bd510d6de45654 asr9k-k9sec-px.pie-5.3.4
ad8992c0ade2ebefff4c9bbc7e041e1c asr9k-li-px.pie-5.3.4
e8aba42635bde28ee13b9e09b4ffaaa3 asr9k-mcast-px.pie-5.3.4
3679d0d88ad2054c4e38490ca21a0d02 asr9k-mgbl-px.pie-5.3.4
64f2c3da2d3fe61142acefcb10425264 asr9k-mini-px.pie-5.3.4
0b9e2bad1419464493492bdffec9d43a asr9k-mpls-px.pie-5.3.4
0f39b8d3494fb6577c266071034889e7 asr9k-optic-px.pie-5.3.4
f0e36f83bba75fed2502d0cd7817f8de asr9k-services-infra-px.pie-5.3.4
fbc0f76733a70d91ffa46aca6ca14e34 asr9k-services-px.pie-5.3.4
4443da49c428613991def91bf79a33cb asr9k-video-px.pie-5.3.4
One tip for you. Always install first then activate later.
Install add ftp://xxxx. After the installation is done for all packages do this
install activate disk0:"mini" disk0:"fpd" disk0:"mcast" test.
If you don't get any errors you can try without "test" at the end of the command.
Hi Smail
Thanks for your mail , I have used the tool and it gives me matched
The error I got is when I was trying to add before install that what confused me , I will try again and update
Thanks again
BR,
Mohammad
