IOS XRv- Mismatch in memory stats taken from CLI and SNMP
Trying to poll the memory stats of IOS XRv mounted in vmware esxi 5.5, there is mismatch of the total memory polled by the NMS and the memory seen in CLI.
Actual memory allocated : 8G
Total Memory displayed in CLI: 8G
Total Memory displayed in any NMS: 4G
RP/0/0/CPU0:LAB-IOS-XRv#sh mem summary
Wed Mar 30 12:29:09.770 IST
Physical Memory: 8191M total (6601M available)
Application Memory : 7992M (6601M available)
Image: 70M (bootram: 70M)
Reserved: 128M, IOMem: 0, flashfsys: 0
Total shared window: 22M
C:\usr\bin>snmpwalk.exe -c xrv -v 2c 124.7.227.10 1.3.6.1.4.1.9.9.48.1
SNMPv2-SMI::enterprises.9.9.48.1.1.1.2.1 = STRING: "processor"
SNMPv2-SMI::enterprises.9.9.48.1.1.1.2.6 = STRING: "reserved"
SNMPv2-SMI::enterprises.9.9.48.1.1.1.2.7 = STRING: "image"
SNMPv2-SMI::enterprises.9.9.48.1.1.1.3.1 = INTEGER: 0
SNMPv2-SMI::enterprises.9.9.48.1.1.1.3.6 = INTEGER: 0
SNMPv2-SMI::enterprises.9.9.48.1.1.1.3.7 = INTEGER: 0
SNMPv2-SMI::enterprises.9.9.48.1.1.1.4.1 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.48.1.1.1.4.6 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.48.1.1.1.4.7 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.48.1.1.1.5.1 = Gauge32: 1457920116
SNMPv2-SMI::enterprises.9.9.48.1.1.1.5.6 = Gauge32: 134217728
SNMPv2-SMI::enterprises.9.9.48.1.1.1.5.7 = Gauge32: 74203380
SNMPv2-SMI::enterprises.9.9.48.1.1.1.6.1 = Gauge32: 2628096000
SNMPv2-SMI::enterprises.9.9.48.1.1.1.6.6 = Gauge32: 0
SNMPv2-SMI::enterprises.9.9.48.1.1.1.6.7 = Gauge32: 0
SNMPv2-SMI::enterprises.9.9.48.1.2.1.1.1 = INTEGER: 35
SNMPv2-SMI::enterprises.9.9.48.1.2.1.1.6 = INTEGER: 0
SNMPv2-SMI::enterprises.9.9.48.1.2.1.1.7 = INTEGER: 100
SNMPv2-SMI::enterprises.9.9.48.1.2.1.2.1 = INTEGER: 35
SNMPv2-SMI::enterprises.9.9.48.1.2.1.2.6 = INTEGER: 0
SNMPv2-SMI::enterprises.9.9.48.1.2.1.2.7 = INTEGER: 100
SNMPv2-SMI::enterprises.9.9.48.1.2.1.3.1 = INTEGER: 35
SNMPv2-SMI::enterprises.9.9.48.1.2.1.3.6 = INTEGER: 0
SNMPv2-SMI::enterprises.9.9.48.1.2.1.3.7 = INTEGER: 100
Warm Regards
5 REPLIES 5
Can you please confirm the
Can you please confirm the software release on the XRv router? Is it 6.0.1?
Hello Osman,
Hello Osman,
XRv runs with 5.1.3.
Warm Regards
Highlighted
Can you also provide the
Can you also provide the output of show version. I think you are using the older version (32 bit).
Hello Osman,
Hello Osman,
Here is the show version for the vm,
RP/0/0/CPU0:LAB-IOS-XRv#sh version
Thu Mar 31 20:41:21.328 IST
Cisco IOS XR Software, Version 5.1.3[Default]
Copyright (c) 2014 by Cisco Systems, Inc.
ROM: GRUB, Version 1.99(0), DEV RELEASE
LAB-IOS-XRv uptime is 2 days, 6 hours, 23 minutes
System image file is "bootflash:disk0/xrvr-os-mbi-5.1.3/mbixrvr-rp.vm"
cisco IOS XRv Series (Intel 686 F6M14S4) processor with 8388158K bytes of memory.
Intel 686 F6M14S4 processor at 2480MHz, Revision 2.174
IOS XRv Chassis
7 GigabitEthernet
1 Management Ethernet
96050k bytes of non-volatile configuration memory.
866M bytes of hard disk.
1866736k bytes of disk0: (Sector size 512 bytes).
Configuration register on node 0/0/CPU0 is 0x2102
Boot device on node 0/0/CPU0 is disk0:
Package active on node 0/0/CPU0:
iosxr-infra, V 5.1.3[Default], Cisco Systems, at disk0:iosxr-infra-5.1.3
Built on Mon Sep 8 20:46:16 IST 2014
By iox-lnx-009 in /auto/srcarchive11/production/5.1.3/all/workspace for pie
iosxr-fwding, V 5.1.3[Default], Cisco Systems, at disk0:iosxr-fwding-5.1.3
iosxr-routing, V 5.1.3[Default], Cisco Systems, at disk0:iosxr-routing-5.1.3
iosxr-ce, V 5.1.3[Default], Cisco Systems, at disk0:iosxr-ce-5.1.3
xrvr-os-mbi, V 5.1.3[Default], Cisco Systems, at disk0:xrvr-os-mbi-5.1.3
Built on Mon Sep 8 20:47:23 IST 2014
xrvr-base, V 5.1.3[Default], Cisco Systems, at disk0:xrvr-base-5.1.3
xrvr-fwding, V 5.1.3[Default], Cisco Systems, at disk0:xrvr-fwding-5.1.3
xrvr-mgbl-x, V 5.1.3[Default], Cisco Systems, at disk0:xrvr-mgbl-x-5.1.3
Built on Mon Sep 8 20:46:25 IST 2014
iosxr-mpls, V 5.1.3[Default], Cisco Systems, at disk0:iosxr-mpls-5.1.3
iosxr-mgbl, V 5.1.3[Default], Cisco Systems, at disk0:iosxr-mgbl-5.1.3
iosxr-mcast, V 5.1.3[Default], Cisco Systems, at disk0:iosxr-mcast-5.1.3
xrvr-mcast-supp, V 5.1.3[Default], Cisco Systems, at disk0:xrvr-mcast-supp-5.1.3
iosxr-bng, V 5.1.3[Default], Cisco Systems, at disk0:iosxr-bng-5.1.3
Built on Mon Sep 8 20:46:14 IST 2014
xrvr-bng-supp, V 5.1.3[Default], Cisco Systems, at disk0:xrvr-bng-supp-5.1.3
iosxr-security, V 5.1.3[Default], Cisco Systems, at disk0:iosxr-security-5.1.3
Built on Mon Sep 8 20:46:07 IST 2014
xrvr-fullk9-x, V 5.1.3[Default], Cisco Systems, at disk0:xrvr-fullk9-x-5.1.3
Built on Mon Sep 8 20:47:28 IST 2014
Warm regards,
Thiyagarajan B
Thanks.
Thanks.
There might be some limitations for SNMP MIB support for the virtual platforms when it comes to extracting hardware specific data. In any case, its best if you upgrade to 6.0.1/IOS XRv 9000 for your testing/deployment. You can run it in ESXi 5.5 and the images are at the following location:
https://upload.cisco.com/cgi-bin/swc/fileexg/main.cgi?CONTYPES=IOS-XR
Release Notes:
http://www.cisco.com/c/en/us/td/docs/routers/virtual-routers/xrv9k-6-0/general/release/notes/xrv9k-rn-6.html
Content for Community-Ad
August's Community Spotlight Awards
