ISM-100 to VSM-500 Migration and Redundancy managment guide with key performance differances
Nitin Pabbi
Contents
  1. ISM-100 to VSM-500 Migration guide
  2. VSM-500 Redundancy management config inputs
  3. ISM-100 to VSM-500 key performance and scalability points
Graceful insertion of VSM card on ASR9000 routers
Part-A: VSM card readiness
  1. Pre-Installation Information
    1. VSM-500 card supported on ASR9904,ASR9006,ASR9010,ASR9912,ASR9922 chassis
    2. This card supported from IOS-XR 5.1.1 release
    3. VSM-500 is supported with RSP440 / RP2/RSP880
    4. VSM-500 supports CGN and TMS-Arbor services
  1. Prerequisites files for VSM operations are :
VSM Services Infra Pie
asr9k-services-infra.pie
CGv6 Services pie
asr9k-services-px.pie
FPD PIE
asr9k-fpd-px.pie
VSM OVA Package
asr9k-vsm-cgv6-<version>.ova
Mandatory SMU(s) for target release
asr9k-CSCxxxxx-px.pie
Part-B: installation with service configuration
  1. Make sure all above mentioned PIEs are installed.
Check with Show install summary
  1. Make sure FPD is correctly upgraded
Check with sh hw-module fpd location all
  1. Install mandatory SMUs
Note: - To identify the bare minimum mandatory SMUs we need for VSM in key releases using CSM, Please refer below link.
https://supportforums.cisco.com/document/12554686/smu-list-through-cisco-software-manager-csm-recommended-smu-list-using-csm
  1. Install & activation of CGv6.ova for CGN services:-
  1. Once VSM card in IOS-XR RUN state then we need to perform upgrade activity.
Note: - Pre-533 IOS XR code, disabling CoPP TFTP config was required. From IOS-XR 5.3.3 no TFTP config changes required.
RP/0/RSP0/CPU0:ESC_CGN(config)#show run
Building configuration...
control-plane
 management-plane
  out-of-band
   interface all
    allow TFTP
end
RP/0/RSP0/CPU0:ESC_CGN(config)#commit
  1. Installation VSM Ova package with CGv6 config: -
Step 1: Copy cgn.ova file to RSP (E.g. to disk0:)
Step 2: Enable virtual service.
RP/0/RSP0/CPU0:Esc_CGN(config)#virtual-service enable
RP/0/RSP0/CPU0:Esc_CGN(config)#commit
Step 3: Install CGN OVA using CLI from execution mode:
RP/0/RSP0/CPU0:Esc_CGN# virtual-service install name cgn123 package disk0:/asr9k-vsm-cgv6-<version>.ova node 0/1/CPU0
Please note: Installation will take about 6-8 minutes.
Step 4: Check installation progress using show virtual-service list CLI. When the status is shown as "Installed", installation is completed.
RP/0/RSP0/CPU0:Esc_CGN#sh virtual-service list
Mon May 17 18:01:38.310 UTC
Virtual Service List:
Name                     Status             Package Name
__________________________________________________​_______
cgn123                   Installing         asr9k-vsm-cgv6-<version>.ova
Mon May 17 18:10:17.291 UTC
cgn123                   Installed           asr9k-vsm-cgv6-<version>.ova
Activate CGv6 VM
Step 1: Configure CGv6 VM, 10-GE interfaces and Activate
RP/0/RSP0/CPU0:Esc_CGN#conf t
Mon May17 18:10:25.525 UTC
RP/0/RSP0/CPU0:Esc_CGN(config)#virtual-service cgn123
RP/0/RSP0/CPU0:Esc_CGN(config-virt-service)#vnic interface tenGigE 0/1/1/0
RP/0/RSP0/CPU0:Esc_CGN(config-virt-service)#vnic interface tenGigE 0/1/1/1
RP/0/RSP0/CPU0:Esc_CGN(config-virt-service)#vnic interface tenGigE 0/1/1/10
RP/0/RSP0/CPU0:Esc_CGN(config-virt-service)#vnic interface tenGigE 0/1/1/11
RP/0/RSP0/CPU0:Esc_CGN(config-virt-service)#commit
Mon May17 18:11:34.285 UTC
RP/0/RSP0/CPU0:Esc_CGN(config-virt-service)#activate
Step 2: Un-shut and assign description to VNIC interface
Bring up 10-GE interfaces on VSM
Must before configuring any ServiceInfra/App interfaces
Interface TenGigE 0/1/1/0
Description VSM VNIC 1 ===>>>
 No shut
Interface TenGigE 0/1/1/1
Description VSM VNIC 2
  No shut
Interface TenGigE 0/1/1/11
Description VSM VNIC 12
  No shut
 (Note: Adding interface Description is best practice. This will help VNIC interfaces in Admin UP state [Post Installation/Config activity] once VSM          card reloaded due to any operational reasons. )
Step 3: Check VM status via show virtual-service list CLI till it shows as "Activated".
RP/0/RSP0/CPU0: Esc_CGN#sh virtual-service list
Mon May 2 18:12:23.863 UTC
cgn123                   Activated           asr9k-vsm-cgv6-<version>.ova
Please note: After activating the VM, it will take some 5 min for CGv6 Application processes to come up.
Step 4: Configure ServiceInfra interface.
RP/0/RSP0/CPU0:Esc_CGN(config)# interface ServiceInfra 1
RP/0/RSP0/CPU0:Esc_CGN(config-int)# ipv4 address <IP> <mask>
RP/0/RSP0/CPU0:Esc_CGN(config-int)# service-location 0/1/CPU0
RP/0/RSP0/CPU0:Esc_CGN(config-int)# commit
  • After ServiceInfra interface is configured, CGN HA agent will start sending hello packets to the CGv6 Application processes with retry after every 150 seconds.
  • Once response for hello packets is received, configurations will be sent to CGv6 Application processes.
Step 5: Configure Ingress interfaces
interface TenGigE1/0/0/0
  Add it to Inside VRF
 vrf ivrf1
  Assign IP address to it
interface TenGigE1/0/0/1
 vrf ivrf2
Step 6: Configure Egress interfaces
interface TenGigE0/2/0/0
 vrf ovrf1
interface TenGigE0/2/0/1
 vrf ovrf2
Step 6: Configure CGN and NAT44 Service parameters
Define CGN Instance
service cgn cgn1
-- Define location
 service-location preferred-active 0/1/CPU0
 - Define NAT44 Service Type and instance (one per VSM card)
 service-type nat44 nat1
  - Define per-user Port limit for NAT44 instance
  portlimit 250
  inside-vrf ivrf1
    - Define Public IP address Pool
    map outside-vrf ovrf1 address-pool 9.0.0.0/24
   - Define inside VRF
  inside-vrf ivrf2
    map outside-vrf ovrf2 address-pool 9.1.0.0/24
Step 7: Configure Inside and Outside ServiceApp interfaces
Define Inside Service App interfaces
interface ServiceApp 1
-- Define VRF where it should belong to (optional)
 vrf ivrf1
  - Assign IPv4 address and netmask
  - Define CGN instance and service type in which it belongs to
  service cgn cgn1 service-type nat44
interface ServiceApp 3
 vrf ivrf2
-- Define Outside Service App interfaces
interface ServiceApp 2
 vrf ovrf1
interface ServiceApp 4
 vrf ovrf2
Step 8: Configure Inside and Outside ServiceApp interfaces
Define inside Service App interfaces
 vrf ivrf1
 vrf ivrf2
 vrf ovrf1
 vrf ovrf2
Step 9: Define static route for Inside-to-outside traffic
router static
-- Specify the Inside VRF
 vrf ivrf1
  - Define address family
  address-family ipv4 unicast
   - Re-direct all traffic to Inside Service App
   0.0.0.0/0 ServiceApp 1
router static
 vrf ivrf2
   0.0.0.0/0 ServiceApp 3
Step 10: Define static route for Outside-to-inside traffic
router static
 vrf ovrf1
  -Assign IP pool ServiceApp 2
router static
 vrf ovrf2
            -Assign IP pool ServiceApp 4
Refer link for service Configuration
http://www.cisco.com/c/en/us/td/docs/routers/asr9000/software/asr9k_r5-3/cg-nat/configuration/guide/b_cgnat_cg53xasr9k/b_cgnat_cg53xasr9k_chapter_0100.html
  1. Health checks / service verification of VSM by using below commands.
  2. show virtual-service list
  3. show services interfaces serviceinfra <>
  4. show interfaces serviceinfra <> accounting
  5. sh int tenGigE 0/<>/<>/* | i line protocol
  6. show services cgn vsm ha trace all location <>
Part-C: Traffic restoration on VSM
  1. Restore traffic.
  2. Verify the services once traffic is restored completely.
  3. Once traffic flow recorded fine on all LCs then diverts Test IP pools traffic on VSM card and verify the services.
    1. show interfaces serviceinfra <> accounting
    2. show services interfaces
    3. sh int tenGigE 0/<>/<>/* | i packets out
    4. show cgn nat44 nat1 statistics
    5. sh cgn nat44 <> inside-vrf <> counters
Redundancy options on VSM card.
  • HA requirement for CGv6 on VSM is same as that of CGv6 on ISM; there are some similarities as well as differences in HA architecture / implementation across these two platforms.
  • As both implementations use SVI as virtual interface architecture, both can use the service redundancy support that the infra-structure provides and can divert traffic during failover using the same. However, as CGv6 on ISM runs on a native (non-virtualized) platform whereas on VSM, it runs on a virtualized platform, there are differences in HA triggers as well as how we handle those triggers.
Note 1: - on VSM-500 card for redundancy enabling reload we don’t need to enable
  service-cgv6-ha location 0/1/CPU0 puntpath-test command. This command is only applicable
 to ISM-100 card.
Note 2: The data/punt path failures will be detected even if the CLI is not enabled but the card won’t be
reloaded if any problem encounter between CGv6 App to CGv6 HA Agent or vice versa.
VSM on ASR9000 supports 1:1 warm standby redundancy.
  1. Warm-standby
  • Translation state is not synchronized between active and standby, all connections
    will be re-established on failover
  • Pros: simple to configure, a single map pool is used
  • Cons: only 1:1, one card stay unused in standby state.
  • Convergence time takes ~18 sec [Data-path HA packets take 5 x 3 =15 sec for detection and action of failure + ~3 sec for rebuilding translation DB]
  1. An alternative with ABF is available
  • ABF is used to divert Ingress traffic /Private side / Subscriber side IP Pools/traffic towards Public / Core / Network side.
  • Pros: offers more options like n:1 redundancy, converges very quickly
  • Cons: - CGN-App of VSM can’t be monitored. To fix this problem user can use ICMP IPSLA probes for ISM infra/Services state maintenance. Or,
  • Enable “datapath-test” knob for problem detection and action at CGv6-APP.
  • Convergence time takes:-
    1. ~1 Sec if VSM-infra [XR operations] get impacted.
    2. ~16 Sec  it takes if data-path test enable for failure detection CGV6-App
    3. ~4-6 Sec it takes if ICMP-IPSLA with NH tracking is enabled between ServiceApp and outgoing interface IP address
1:1 Warm-Standby Redundancy
  • Configuration
service cgn HA_CGN
service-location preferred-active 0/1/CPU0 preferred-standby 0/2/CPU0 >>>>>
RP/0/RP0/CPU0:Esc_CGN#show services redundancy
Service type     Name                    Pref. Active        Pref. Standby
ServiceInfra     ServiceInfra1           0/1/CPU0 Active
ServiceInfra     ServiceInfra2           0/2/CPU0 Active
ServiceCgn       HA_CGN               0/2/CPU0 Standby    0/1/CPU0 Active
For redundancy enabling reload for data path tests need to config below command on CGN router for VSM-500 card:-
RP/0/RSP1/CPU0:Esc_CGN#configure
RP/0/RSP1/CPU0:Esc_CGN(config)#service-cgv6-ha location 0/x/CPU0 datapath-test
RP/0/RSP1/CPU0:Esc_CGN(config)#commit
CGN n:1 Redundancy with ABF (NAT44)
  • Configuration
Note: - User needs to configure datapath tests knob to detect failure at CGv6 App to CGv6 HA Agent of VSM-500 card
service cgn ABF-cgn-HA1
 service-location preferred-active 0/0/CPU0
 service-type nat44 nat44-ABF
  inside-vrf Inside-1
   map address-pool 10.0.0.0/24
service cgn ABF-cgn-HA2
 service-type nat44 nat44-ABF2
  inside-vrf Inside-2
   map address-pool 10.0.1.0/24
service cgn ABF-cgn-HA-backup
 service-location preferred-active 0/2/CPU0
 service-type nat44 nat44-ABF-backup
  inside-vrf iBackUp-1
 inside-vrf iBackUp-2
ipv4 access-list CGN-ABF-HA
 10 permit ipv4 9.1.0.0/24 any nexthop1 vrf Inside-1 ipv4 100.68.51.6 nexthop2 vrf iBackUp-1 ipv4 100.68.33.6
 20 permit ipv4 9.2.1.0/24 any nexthop1 vrf Inside-2 ipv4 100.68.151.6 nexthop2 vrf iBackUp-2 ipv4 100.68.33.6
 100 permit ipv4 any any
router static
  110.1.0.0/16 100.1.1.2 description Ixia-i2o-Default
  151.0.0.0/24 ServiceApp2 1 description Static-Ixia-o2i-ABF
  151.0.1.0/24 ServiceApp4 1 description Static-Ixia-o2i-ABF
  151.0.0.0/24 ServiceApp6 2 description Floating-static-Ixia-o2i-ABF
  151.0.1.0/24 ServiceApp6 2 description Floating-static-Ixia-o2i-ABF
Performance / Scalability information between ISM and VSM card.
Per Blade Limits
ISM
VSM
NAT44 instances supported
1 per card
1 per card
End-point Dependent Filtering
Not Supported
Supported
TCP Sequence Check
Not Supported
Supported
CLI: map ip many-to-one
Supported
Not Supported
Number of service infra
Number of service app
244 (per system)
256 per card
IP pool supported
/16 to /30 (max 65535 addresses)
/16 to /27(max 65535 addresses)
Max Static Port forwarding
6K
6K
Max number of NAT users
1M
4M
FIB scale
512k
1M
Configuration CLIs
Same
Same
Uses SVI
Yes
Yes
Network Processor
No, handled by a dedicated process
Yes (Typhoon)
Egress FIB Lookup
Within CGv6 App
On Typhoon NPU
ServiceApp placement
Associated with Niantic port/VQI
Associated with NP ports / Niantic ports
# of CGv6 instances
8
48
Stateless protocols (in CGN card)
6rd, MAP-T/E
6rd, MAP-T/E
Inline support
Yes for SL protocols
With Typhoon & Tomahawk LC for    MAP-T/E & 6rd
25 Replies 25
mkhalil10
Hi Nitin
I have prepared my configuration
My concern is , where to apply the ABF and how many outside VRFs I have to configure?
vrf OUTSIDE
vrf INSIDE-1
vrf INSIDE-1-BACKUP
hw-module service cgn location 0/1/CPU0
hw-module service cgn location 0/2/CPU0
ipv4 access-list ISM_ABF
10 permit ipv4 192.168.199.0/24 any nexthop1 vrf INSIDE-1 ipv4 9.9.9.2 nexthop2 vrf INSIDE-1-BACKUP ipv4 19.19.19.2
30 permit ipv4 any any
interface GigabitEthernet0/0/0/9
vrf INSIDE-1
ipv4 address 192.168.199.1 255.255.255.0
ipv4 access-group ISM_ABF ingress hardware-count
interface GigabitEthernet0/0/0/10
vrf INSIDE-1-BACKUP
shutdown
interface ServiceApp1
vrf INSIDE-1
ipv4 address 9.9.9.1 255.255.255.252
interface ServiceApp2
ipv4 address 10.10.10.1 255.255.255.252
service cgn cgn2 service-type nat44
interface ServiceApp3
vrf INSIDE-1-BACKUP
ipv4 address 19.19.19.1 255.255.255.252
interface ServiceApp4
ipv4 address 20.20.20.1 255.255.255.252
interface ServiceInfra1
ipv4 address 10.89.89.1 255.255.255.0
interface ServiceInfra2
ipv4 address 10.93.93.1 255.255.255.0
service-location 0/2/CPU0
router static
  0.0.0.0/0 172.66.66.65
  85.159.218.160/27 ServiceApp4
  85.159.218.192/27 ServiceApp2
vrf INSIDE-1
   0.0.0.0/0 ServiceApp1
vrf INSIDE-1-BACKUP
   0.0.0.0/0 ServiceApp3
service cgn cgn1
  portlimit 4096
  alg ActiveFTP
  inside-vrf INSIDE-1
   map outsideServiceApp ServiceApp2 address-pool 85.159.218.192/27
  protocol udp
   session initial timeout 240
   session active timeout 600
  protocol tcp
  protocol icmp
   timeout 60
  refresh-direction Outbound
service cgn cgn2
  portlimit 4096
  alg ActiveFTP
  inside-vrf INSIDE-1-BACKUP
   map outsideServiceApp ServiceApp4 address-pool 85.159.218.160/27
  protocol udp
  protocol tcp
  protocol icmp
   timeout 60
Hey mkhalil,
>> Few pointers :-
  • Inside VRF must be non-default
  • Outside VRF is optional, we can use the Default or user created VRF
You dont below commands to configure for VSM
You need to apply ABF at default table [ that's the way it works],
What all you need is mapping :-
ipv4 access-list <ACL name>
10 permit ipv4 <access network pool> any nexthop1 vrf <Inside VRF1 map to VSM1> ipv4 <address> nexthop2 vrf <Inside VRF2 map to VSM2> ipv4 <address>
 this is for mapping of internal traffic to VRF for NAT.
Once NAT get done then traffic get redirect to MAPPED outside pool.
In your case is :-
inside-vrf INSIDE-1
here i find the command is wrong and seems you have drafted the config on paper but didn;t applied, otherwise you would have got an error.
because you need to fix the syntax and here is that :-
map outside-vrf outside address-pool <>
=== Mapping to the VRF “outside” in public side
Hope these clues help you.
Nitin Pabbi
Thanks Nitin for your support
I will try to get to a final answer with you
I can remove the outside VRF and just use the outside service app under the service cgn right ?
Why I cannot use the hw-module command , it's not mandatory ?
The inside interface can be part from the global routing table , so there is no need for the ingress interface to be part of the inside VRF?
Below is my final modified configuration:
vrf INSIDE-1
vrf INSIDE-1-BACKUP
 description Inside_Traffic
 vrf INSIDE-1
 vrf INSIDE-1-BACKUP
router static
 vrf INSIDE-1
 vrf INSIDE-1-BACKUP
service cgn cgn1
  portlimit 4096
  alg ActiveFTP
  inside-vrf INSIDE-1
  protocol udp
  protocol tcp
  protocol icmp
   timeout 60
service cgn cgn2
  portlimit 4096
  alg ActiveFTP
  protocol udp
  protocol tcp
  protocol icmp
   timeout 60
Thanks a lot in advance
BR,
Mohammad
Hey Mohammad,
   map address-pool <>
>> Mapping to the default VRF in public side
Above mentioned procedure help you to configure outside Pool without using OUTSIDE VRF.
>> This CLI is for ISM card to initialize CGN services. Where as on VSM card with CGN OVA, user enable CGN services hence dont need extra CLI for the same.
>>> yes Inside interface can be a part of default table.
Config structure looks fine. Please try this at test router before deploying it at production.
Nitin Pabbi
Regarding the ABF redundancy , I have tested the configuration below yesterday , please find my comments and appreciate your help:
vrf INSIDE-1
vrf INSIDE-1-BACKUP
 20 permit ipv4 any any
 vrf INSIDE-1
 vrf INSIDE-1-BACKUP
router static
 vrf INSIDE-1
 vrf INSIDE-1-BACKUP
service cgn cgn1
  portlimit 4096
  alg ActiveFTP
  inside-vrf INSIDE-1
  protocol udp
  protocol tcp
  protocol icmp
   timeout 60
service cgn cgn2
 service-type nat44 nat2
  portlimit 4096
  alg ActiveFTP
  protocol udp
  protocol tcp
  protocol icmp
   timeout 60
The G0/0/0/9 interface is where the host is connected (incoming traffic) , I have removed the VRF binding from it and kept it in the global routing table but it did not work
When I bind the interface to VRF INSIDE-1 , it works with ABF applied
When I bind the interface to VRF INSIDE-1-BACKUP with ABF applied , it do not work , when I remove the ABF it works
As well , when the ABF applied , I can access the Internet , but there is no output in the show cgn nat44 nat1 statistics or show cgn nat44 nat2 statistics
What is wrong with the configuration I have done ? by the way , I have removed the VRF OUTSIDE because am using the outside serviceapp interface and the pool mapping under the service cgn configuration as you can see above
Hi Nitin
Hope this finds you well
I have tried to apply the ABF on G0/0/0/9 interface and it did not work , and I tried to leak the traffic from global routing table into the inside VRF , it did not work
router static
vrf INSIDE-1
192.168.199.0/24 Gig0/0/0/9
and it did not work , I have opened a case with Cisco but till now I got the confirmation it's working but it's not and am not aware what mistakes am doing
SR : 680746749
BR,
Mohammad
Hi Nitin
I have managed to get the setup working as below:
router static
vrf INSIDE-1
192.168.199.0/24 vrf default Gig0/0/0/9
Thanks for your support
BR,
Mohammad
Good to hear that Mohammad. Great work.
Thanks for an update
Nitin Pabbi
Thanks Nitin
I need your help in something please , I have in the HQ two ASR9K equipped each with VSM , they are operating as HSRP active/standby (so , if one of these nodes fails , the traffic is redirected to the other node by means of HSRP)
Now , the two ISM cards installed on the ASR9K in our case is located in a different geographic location (i.e. it’s considered as a DR site)
What should I do in order to redirect all the traffic handled by the VSM modules @ HQ to the DR site in case of site failure?
Is what so called extra-chassis redundancy what am looking for?
Thanks again
BR,
Mohammad
Hey Mohammad,
>> This is something tricky and you need to scale before design failover redundancy from VSM to ISM. Because VSM has more throughput capacity then ISM.
Now to achieve this objective you need to play with routing. You need to be cautious for ingress traffic redirection which is from access network towards CGN node.
For egress traffic e-BGP sessions and its attribute will help you to redirect the traffic.
If you have scalable internal infrastructure which can help you to re-route the traffic between distantly connected nodes then you can achieve this objective.
>>> There are 2 types of redundancy on CGN over VSM:-
a) Warm redundancy
b) Redundancy using ABF. While using ABF you can achieve traffic failover requirement for locally connected or distantly connected nodes.
for distantly connected nodes traffic redundancy we use word called "Geo-redundancy"
Nitin Pabbi
Hi Nitin and thanks for your continuous support
Do you have an reference for Geo-redundancy or configuration examples that can assist me with this?
I have read in some presentation (extra-chassis redundancy and I have to build GRE tunnels to avoid routing loops)
Thanks again
BR,
Mohammad
Hey Mohammad,
There is no specific config for Geo-redundancy but you just need to play with ABF which does lookup at local fib for next hop accessibility for traffic forwarding.
if the distant node [which you want to use as standby] accessible via same access network from which primary CGN router connected then its possible in same way as you configure ABF redundancy between 2 nodes under same premises.
You don't need to use GRE tunnel here. Common Ipv4 infrastructure needed for traffic forwarding
Nitin Pabbi
Hi Nitin
I have a quick question regarding public pools
If I configured multiple /24 public pools for my nat44 service , how the router will assign addresses ? random or does sequence plays role?
Hey Mohammed,
This would be random assignment because of mapping of APPS with NP and virtual cores.
Nitin Pabbi
