ISM-100 to VSM-500 Migration and Redundancy managment guide with key performance differances
Nitin Pabbi
Contents
  1. ISM-100 to VSM-500 Migration guide
  2. VSM-500 Redundancy management config inputs
  3. ISM-100 to VSM-500 key performance and scalability points
Graceful insertion of VSM card on ASR9000 routers
Part-A: VSM card readiness
  1. Pre-Installation Information
    1. VSM-500 card supported on ASR9904,ASR9006,ASR9010,ASR9912,ASR9922 chassis
    2. This card supported from IOS-XR 5.1.1 release
    3. VSM-500 is supported with RSP440 / RP2/RSP880
    4. VSM-500 supports CGN and TMS-Arbor services
  1. Prerequisites files for VSM operations are :
VSM Services Infra Pie
asr9k-services-infra.pie
CGv6 Services pie
asr9k-services-px.pie
FPD PIE
asr9k-fpd-px.pie
VSM OVA Package
asr9k-vsm-cgv6-<version>.ova
Mandatory SMU(s) for target release
asr9k-CSCxxxxx-px.pie
Part-B: installation with service configuration
  1. Make sure all above mentioned PIEs are installed.
Check with Show install summary
  1. Make sure FPD is correctly upgraded
Check with sh hw-module fpd location all
  1. Install mandatory SMUs
Note: - To identify the bare minimum mandatory SMUs we need for VSM in key releases using CSM, Please refer below link.
https://supportforums.cisco.com/document/12554686/smu-list-through-cisco-software-manager-csm-recommended-smu-list-using-csm
  1. Install & activation of CGv6.ova for CGN services:-
  1. Once VSM card in IOS-XR RUN state then we need to perform upgrade activity.
Note: - Pre-533 IOS XR code, disabling CoPP TFTP config was required. From IOS-XR 5.3.3 no TFTP config changes required.
RP/0/RSP0/CPU0:ESC_CGN(config)#show run
Building configuration...
control-plane
 management-plane
  out-of-band
   interface all
    allow TFTP
end
RP/0/RSP0/CPU0:ESC_CGN(config)#commit
  1. Installation VSM Ova package with CGv6 config: -
Step 1: Copy cgn.ova file to RSP (E.g. to disk0:)
Step 2: Enable virtual service.
RP/0/RSP0/CPU0:Esc_CGN(config)#virtual-service enable
RP/0/RSP0/CPU0:Esc_CGN(config)#commit
Step 3: Install CGN OVA using CLI from execution mode:
RP/0/RSP0/CPU0:Esc_CGN# virtual-service install name cgn123 package disk0:/asr9k-vsm-cgv6-<version>.ova node 0/1/CPU0
Please note: Installation will take about 6-8 minutes.
Step 4: Check installation progress using show virtual-service list CLI. When the status is shown as "Installed", installation is completed.
RP/0/RSP0/CPU0:Esc_CGN#sh virtual-service list
Mon May 17 18:01:38.310 UTC
Virtual Service List:
Name                     Status             Package Name
__________________________________________________​_______
cgn123                   Installing         asr9k-vsm-cgv6-<version>.ova
Mon May 17 18:10:17.291 UTC
cgn123                   Installed           asr9k-vsm-cgv6-<version>.ova
Activate CGv6 VM
Step 1: Configure CGv6 VM, 10-GE interfaces and Activate
RP/0/RSP0/CPU0:Esc_CGN#conf t
Mon May17 18:10:25.525 UTC
RP/0/RSP0/CPU0:Esc_CGN(config)#virtual-service cgn123
RP/0/RSP0/CPU0:Esc_CGN(config-virt-service)#vnic interface tenGigE 0/1/1/0
RP/0/RSP0/CPU0:Esc_CGN(config-virt-service)#vnic interface tenGigE 0/1/1/1
RP/0/RSP0/CPU0:Esc_CGN(config-virt-service)#vnic interface tenGigE 0/1/1/10
RP/0/RSP0/CPU0:Esc_CGN(config-virt-service)#vnic interface tenGigE 0/1/1/11
RP/0/RSP0/CPU0:Esc_CGN(config-virt-service)#commit
Mon May17 18:11:34.285 UTC
RP/0/RSP0/CPU0:Esc_CGN(config-virt-service)#activate
Step 2: Un-shut and assign description to VNIC interface
Bring up 10-GE interfaces on VSM
Must before configuring any ServiceInfra/App interfaces
Interface TenGigE 0/1/1/0
Description VSM VNIC 1 ===>>>
 No shut
Interface TenGigE 0/1/1/1
Description VSM VNIC 2
  No shut
Interface TenGigE 0/1/1/11
Description VSM VNIC 12
  No shut
 (Note: Adding interface Description is best practice. This will help VNIC interfaces in Admin UP state [Post Installation/Config activity] once VSM          card reloaded due to any operational reasons. )
Step 3: Check VM status via show virtual-service list CLI till it shows as "Activated".
RP/0/RSP0/CPU0: Esc_CGN#sh virtual-service list
Mon May 2 18:12:23.863 UTC
cgn123                   Activated           asr9k-vsm-cgv6-<version>.ova
Please note: After activating the VM, it will take some 5 min for CGv6 Application processes to come up.
Step 4: Configure ServiceInfra interface.
RP/0/RSP0/CPU0:Esc_CGN(config)# interface ServiceInfra 1
RP/0/RSP0/CPU0:Esc_CGN(config-int)# ipv4 address <IP> <mask>
RP/0/RSP0/CPU0:Esc_CGN(config-int)# service-location 0/1/CPU0
RP/0/RSP0/CPU0:Esc_CGN(config-int)# commit
  • After ServiceInfra interface is configured, CGN HA agent will start sending hello packets to the CGv6 Application processes with retry after every 150 seconds.
  • Once response for hello packets is received, configurations will be sent to CGv6 Application processes.
Step 5: Configure Ingress interfaces
interface TenGigE1/0/0/0
  Add it to Inside VRF
 vrf ivrf1
  Assign IP address to it
interface TenGigE1/0/0/1
 vrf ivrf2
Step 6: Configure Egress interfaces
interface TenGigE0/2/0/0
 vrf ovrf1
interface TenGigE0/2/0/1
 vrf ovrf2
Step 6: Configure CGN and NAT44 Service parameters
Define CGN Instance
service cgn cgn1
-- Define location
 service-location preferred-active 0/1/CPU0
 - Define NAT44 Service Type and instance (one per VSM card)
 service-type nat44 nat1
  - Define per-user Port limit for NAT44 instance
  portlimit 250
  inside-vrf ivrf1
    - Define Public IP address Pool
    map outside-vrf ovrf1 address-pool 9.0.0.0/24
   - Define inside VRF
  inside-vrf ivrf2
    map outside-vrf ovrf2 address-pool 9.1.0.0/24
Step 7: Configure Inside and Outside ServiceApp interfaces
Define Inside Service App interfaces
interface ServiceApp 1
-- Define VRF where it should belong to (optional)
 vrf ivrf1
  - Assign IPv4 address and netmask
  - Define CGN instance and service type in which it belongs to
  service cgn cgn1 service-type nat44
interface ServiceApp 3
 vrf ivrf2
-- Define Outside Service App interfaces
interface ServiceApp 2
 vrf ovrf1
interface ServiceApp 4
 vrf ovrf2
Step 8: Configure Inside and Outside ServiceApp interfaces
Define inside Service App interfaces
 vrf ivrf1
 vrf ivrf2
 vrf ovrf1
 vrf ovrf2
Step 9: Define static route for Inside-to-outside traffic
router static
-- Specify the Inside VRF
 vrf ivrf1
  - Define address family
  address-family ipv4 unicast
   - Re-direct all traffic to Inside Service App
   0.0.0.0/0 ServiceApp 1
router static
 vrf ivrf2
   0.0.0.0/0 ServiceApp 3
Step 10: Define static route for Outside-to-inside traffic
router static
 vrf ovrf1
  -Assign IP pool ServiceApp 2
router static
 vrf ovrf2
            -Assign IP pool ServiceApp 4
Refer link for service Configuration
http://www.cisco.com/c/en/us/td/docs/routers/asr9000/software/asr9k_r5-3/cg-nat/configuration/guide/b_cgnat_cg53xasr9k/b_cgnat_cg53xasr9k_chapter_0100.html
  1. Health checks / service verification of VSM by using below commands.
  2. show virtual-service list
  3. show services interfaces serviceinfra <>
  4. show interfaces serviceinfra <> accounting
  5. sh int tenGigE 0/<>/<>/* | i line protocol
  6. show services cgn vsm ha trace all location <>
Part-C: Traffic restoration on VSM
  1. Restore traffic.
  2. Verify the services once traffic is restored completely.
  3. Once traffic flow recorded fine on all LCs then diverts Test IP pools traffic on VSM card and verify the services.
    1. show interfaces serviceinfra <> accounting
    2. show services interfaces
    3. sh int tenGigE 0/<>/<>/* | i packets out
    4. show cgn nat44 nat1 statistics
    5. sh cgn nat44 <> inside-vrf <> counters
Redundancy options on VSM card.
  • HA requirement for CGv6 on VSM is same as that of CGv6 on ISM; there are some similarities as well as differences in HA architecture / implementation across these two platforms.
  • As both implementations use SVI as virtual interface architecture, both can use the service redundancy support that the infra-structure provides and can divert traffic during failover using the same. However, as CGv6 on ISM runs on a native (non-virtualized) platform whereas on VSM, it runs on a virtualized platform, there are differences in HA triggers as well as how we handle those triggers.
Note 1: - on VSM-500 card for redundancy enabling reload we don’t need to enable
  service-cgv6-ha location 0/1/CPU0 puntpath-test command. This command is only applicable
 to ISM-100 card.
Note 2: The data/punt path failures will be detected even if the CLI is not enabled but the card won’t be
reloaded if any problem encounter between CGv6 App to CGv6 HA Agent or vice versa.
VSM on ASR9000 supports 1:1 warm standby redundancy.
  1. Warm-standby
  • Translation state is not synchronized between active and standby, all connections
    will be re-established on failover
  • Pros: simple to configure, a single map pool is used
  • Cons: only 1:1, one card stay unused in standby state.
  • Convergence time takes ~18 sec [Data-path HA packets take 5 x 3 =15 sec for detection and action of failure + ~3 sec for rebuilding translation DB]
  1. An alternative with ABF is available
  • ABF is used to divert Ingress traffic /Private side / Subscriber side IP Pools/traffic towards Public / Core / Network side.
  • Pros: offers more options like n:1 redundancy, converges very quickly
  • Cons: - CGN-App of VSM can’t be monitored. To fix this problem user can use ICMP IPSLA probes for ISM infra/Services state maintenance. Or,
  • Enable “datapath-test” knob for problem detection and action at CGv6-APP.
  • Convergence time takes:-
    1. ~1 Sec if VSM-infra [XR operations] get impacted.
    2. ~16 Sec  it takes if data-path test enable for failure detection CGV6-App
    3. ~4-6 Sec it takes if ICMP-IPSLA with NH tracking is enabled between ServiceApp and outgoing interface IP address
1:1 Warm-Standby Redundancy
  • Configuration
service cgn HA_CGN
service-location preferred-active 0/1/CPU0 preferred-standby 0/2/CPU0 >>>>>
RP/0/RP0/CPU0:Esc_CGN#show services redundancy
Service type     Name                    Pref. Active        Pref. Standby
ServiceInfra     ServiceInfra1           0/1/CPU0 Active
ServiceInfra     ServiceInfra2           0/2/CPU0 Active
ServiceCgn       HA_CGN               0/2/CPU0 Standby    0/1/CPU0 Active
For redundancy enabling reload for data path tests need to config below command on CGN router for VSM-500 card:-
RP/0/RSP1/CPU0:Esc_CGN#configure
RP/0/RSP1/CPU0:Esc_CGN(config)#service-cgv6-ha location 0/x/CPU0 datapath-test
RP/0/RSP1/CPU0:Esc_CGN(config)#commit
CGN n:1 Redundancy with ABF (NAT44)
  • Configuration
Note: - User needs to configure datapath tests knob to detect failure at CGv6 App to CGv6 HA Agent of VSM-500 card
service cgn ABF-cgn-HA1
 service-location preferred-active 0/0/CPU0
 service-type nat44 nat44-ABF
  inside-vrf Inside-1
   map address-pool 10.0.0.0/24
service cgn ABF-cgn-HA2
 service-type nat44 nat44-ABF2
  inside-vrf Inside-2
   map address-pool 10.0.1.0/24
service cgn ABF-cgn-HA-backup
 service-location preferred-active 0/2/CPU0
 service-type nat44 nat44-ABF-backup
  inside-vrf iBackUp-1
 inside-vrf iBackUp-2
ipv4 access-list CGN-ABF-HA
 10 permit ipv4 9.1.0.0/24 any nexthop1 vrf Inside-1 ipv4 100.68.51.6 nexthop2 vrf iBackUp-1 ipv4 100.68.33.6
 20 permit ipv4 9.2.1.0/24 any nexthop1 vrf Inside-2 ipv4 100.68.151.6 nexthop2 vrf iBackUp-2 ipv4 100.68.33.6
 100 permit ipv4 any any
router static
  110.1.0.0/16 100.1.1.2 description Ixia-i2o-Default
  151.0.0.0/24 ServiceApp2 1 description Static-Ixia-o2i-ABF
  151.0.1.0/24 ServiceApp4 1 description Static-Ixia-o2i-ABF
  151.0.0.0/24 ServiceApp6 2 description Floating-static-Ixia-o2i-ABF
  151.0.1.0/24 ServiceApp6 2 description Floating-static-Ixia-o2i-ABF
Performance / Scalability information between ISM and VSM card.
Per Blade Limits
ISM
VSM
NAT44 instances supported
1 per card
1 per card
End-point Dependent Filtering
Not Supported
Supported
TCP Sequence Check
Not Supported
Supported
CLI: map ip many-to-one
Supported
Not Supported
Number of service infra
Number of service app
244 (per system)
256 per card
IP pool supported
/16 to /30 (max 65535 addresses)
/16 to /27(max 65535 addresses)
Max Static Port forwarding
6K
6K
Max number of NAT users
1M
4M
FIB scale
512k
1M
Configuration CLIs
Same
Same
Uses SVI
Yes
Yes
Network Processor
No, handled by a dedicated process
Yes (Typhoon)
Egress FIB Lookup
Within CGv6 App
On Typhoon NPU
ServiceApp placement
Associated with Niantic port/VQI
Associated with NP ports / Niantic ports
# of CGv6 instances
8
48
Stateless protocols (in CGN card)
6rd, MAP-T/E
6rd, MAP-T/E
Inline support
Yes for SL protocols
With Typhoon & Tomahawk LC for    MAP-T/E & 6rd
25 Replies 25
Hi all
I have simulated the ISM redundancy and it functions well
When i turn down one of the modules (the primary) , the traffic is redirected to the secondary module via ABF , the ping continues but the web traffic is lost for a while and comes back again , why the ping is keep working and is there a specific timer that I can tune in order to change the TCP/UDP traffic behavior?
BR,
Mohammad
Hi Nitin,
I am trying to implement "cold-redundancy" with 2 VSM located on 2 different ASR9912 and using ABF with Track feature.
First of all, regardless of the Track feature, I only manage to direct traffic to the inside VRF with this ABF line:
720 permit ipv4 host 172.16.19.9 any nexthop1 vrf PAT3
RP/0/RP0/CPU0:RZ01-9912-01#sh access-lists ipv4 CGN hardware ingress location 0/1/CPU0
Mon Jul  3 11:58:56.951 mesz
 720 permit ipv4 host 172.16.19.9 any (next-hop: addr=0.0.0.0, vrf name=PAT3)
If I put the IP address of the ServiceApp interface together with the inside VRF (see below), it won't work.
720 permit ipv4 host 172.16.19.9 any nexthop1 vrf PAT3 ipv4 172.17.77.9
This is the output of the above command:
Mon Jul  3 12:00:36.341 mesz
When I then add the track option, even the first example won't work.
720 permit ipv4 host 172.16.19.9 any nexthop1 vrf PAT3 track PAT3
Any idea about what could be wrong?
Thanks in advance for your help!
Cheers,
Stefano
And for scalability , I am confused regarding the max number of NAT users mentioned in the table above (which says 4M for VSM and 1M for ISM)
RP/0/RSP0/CPU0:UM-HQ1-CGN-3G-NAT1#sh cgn nat44 nat1 statistics
Sun Sep  4 13:31:04.144 AST
Statistics summary of NAT44 instance: 'nat1'
Number of active translations: 5451912
Number of sessions: 246854
Translations create rate: 26727
Translations delete rate: 25376
Inside to outside forward rate: 1047085
Outside to inside forward rate: 1685388
Inside to outside drops port limit exceeded: 5320844
Inside to outside drops system limit reached: 0
Inside to outside drops resource depletion: 0
No translation entry drops: 4902541717
PPTP active tunnels: 4
PPTP active channels: 4
PPTP ctrl message drops: 7113
Number of subscribers: 311582
Drops due to session db limit exceeded: 0
Drops due to source ip not configured: 0
Is it Number of sessions ?
BR,
Mohammad
Hey Mohammad,
Number of active translations: 5451912 >>> This number indicates per user translation request.
Number of subscribers: 311582 >>> This number indicates total number of active users.
Aside to the query, by seeing the stats, it looks you have either wrong load balancing of traffic among the service apps or less configured port limit. There are high number of drops.
high time for you to optimize the CGN solution over VSM. if port-limit is default then increase it either globally or per VRF basis and check the performance.
Nitin Pabbi
Hi Nitin
What am thinking of is restrictions on ABF
Is there an limitation on ABF ? as I read that the ABF will not work when the nexthop is VRF?
BR,
Mohammad
Carlos A. Silva
Level 3
Level 3
Just a comment. I would revise:
OVA didn't install properly until I added tftp to control-plane config.
c.
Hey Carlos,
If user don't disable management plane config or not edit MPP to allow TFTP then OVA installation will get fail.
This is because of due to default binding between MPP and application.
We have fixed this behavior in 532 code through DDTS CSCut56161.
That way you dont need to disable COPP or enable TFTP on MGMT interface from 532  release onwards.
Nitin Pabbi
What I was trying to say (maybe poorly) is that I know for a fact that it didn't work for me in 5.3.3.
Hey Carlos,
If you help me with error log or can share the access to your node which is in broken state then i can understand the issue.
Otherwise if you have opened SR with Cisco then please share with me.
Below is the error you get when OVA installation fails due to the bug i shared:-
RP/0/RSP0/CPU0:Node1#RP/0/RSP0/CPU0:Mar 25 14:56:55.648 : service_mgr[407]: %OS-SMGR-3-VM_INSTALL_FAIL : 'Install' of service VM 'cgn1' Failed. Error: SM SVC[cgn1]: 'cgn1' VM Installation failed, err code [1], err : VM [cgn1, 0/2/CPU0]: Install failed, server failure result: Failed to tftp
RP/0/RSP0/CPU0:Mar 25 14:56:56.026 : service_mgr[407]: %OS-LIB_VMAN-3-INSTALL_FAILURE : Virtual Service[cgn1]::Install::The installation of the virtual service failed
Nitin Pabbi
Well, I opened 680802487, but the case is not related to my comments above. Thanks, Nitin.
Carlos A. Silva
Level 3
Level 3
Hi, Nitin:
I was wondering if you could help with this. I have 2 VSMs, one of them seems to be working fine since I see this:
RP/0/RSP0/CPU0:XXXXX# show services redundancy
Mon Aug 22 09:16:59.876 CST
ServiceInfra ServiceInfra1 0/7/CPU0 Active
ServiceCgn cgn1 0/7/CPU0 Active
On the other one, I see this (check log message):
RP/0/RSP0/CPU0:YYYYY#show services redundancy
Mon Aug 22 09:25:09.468 CST
ServiceCgn cgn1 0/7/CPU0 Offline
and
LC/0/7/CPU0:Aug 22 09:21:29.350 : secontroller[326]: %SERVICES-SESVI_EA-3-INTERNAL_ERR : ens_read_failed (ignore this error if cgv6 is not configured or sesvi_ea process is not yet spawned) with error : No such process
Both were installed with the same procedure and (up to this point) are configured exactly alike. Is there anything that jumps out at you?
Thanks in advance!
c.
Forgot to add this:
RP/0/RSP0/CPU0:XXXXX#show cgn nat44 NAT44 statistics
Mon Aug 22 09:51:43.606 CST
Unable to obtain requested information Error:'cgn' detected the 'warning' condition 'LWM Channel not open'
