08-21-2020 04:55 AM
Hello Expert,
I have configure Port-channel with 4Tengig interfaces.
I have somme 3 interface working well, with lot of traffic. But on 1 interface, we are not receiving enougth Packet.
I have : 5 minute output rate 0 bits/sec, 0 packets/sec.
I have change interface but that same issue.
Can you please Help solve this ?
Zanga
08-21-2020 05:26 AM
Can you post below output :
show version
show running-config interface port-channel X (x is your Port-channel number)show etherchannel load-balancing
show interface port-channel 2 etherchannel
also let us know what device other side connected with more information and config other sde too.
08-21-2020 06:15 AM
08-22-2020 05:58 AM
08-22-2020 09:47 AM
High level, for now, i only see inconsistency on the config interface TenGigabitEthernet1/4/1 compare to others
disconnect the port and default the information and put the configuration from the work port and test it.
later day i will look deep and let you know if i see anything abnormal
can you also post-show module from cisco switch side.
08-27-2020 06:42 AM
Hello BB,
I have already tried that. I have change interfaces on both side ( Switch and router). but that the same result.
Zang
08-27-2020 07:28 AM
2 suggestions :
1. Configure different port from different module and join to teh Port-channel by removing (not working one)
2. at maintenance window, shutdown Port-channel both end and check
