Load balancing on sub-interfaces (3 links)
Hello.
I am trying to load balance between the three links of a bundle. Traffic comes and goes with the same bundle interface.
Launched 5 threads TCP\UDP with different SRC DST IP addresses and see the following balances:
IOS-XR               Monitor Time: 00:00:30          SysUptime: 106:39:28
                          Last Clear:   00:00:22
Protocol:General
Interface             In(pps)      Out(pps)      InPkts/Delta   OutPkts/Delta
Te0/1/0/0             11381           628        102062/25512       256/64
Te0/1/0/1             33849         55965        303244/75700    505364/126230
Te0/1/0/2             11363             0        100800/25200         0/0
Quit='q',     Clear='c',    Freeze='f', Thaw='t',
Next set='n', Prev set='p', Bytes='y',  Packets='k'
(General='g', IPv4 Uni='4u', IPv4 Multi='4m', IPv6 Uni='6u', IPv6 Multi='6m')
We have 10G switch connected to asr9010 three ports and the following configuration:
interface TenGigE0/1/0/0
bundle id 1 mode active
bundle port-priority 2
interface TenGigE0/1/0/1
interface TenGigE0/1/0/2
interface Bundle-Ether1.75
ipv4 address 25.0.0.1 255.255.255.252
encapsulation dot1q 75
interface Bundle-Ether1.76
ipv4 address 26.0.0.1 255.255.255.252
encapsulation dot1q 76
RP/0/RSP0/CPU0: ios # sh bundle load-balancing bundle-e1 detail location 0/1/CPU0
Tue Jun 4 07:03:07.605 UTC
Bundle-Ether1
  Type: Ether (L3)
  Members <current/max>: 3/3
  Total Weighting: 3
  Load balance: Default
  Locality threshold: 65
  Avoid rebalancing? False
  Sub-interfaces: 3
  Member Information:
    Port: LON ULID BW
    Te0/1/0/0 0 0 1
    Te0/1/0/1 1 1 1
    Te0/1/0/2 2 2 1
  Sub-interface Information:
    Sub-interface Type Load Balance Locality
                                        Hash Threshold
    Bundle-Ether1.76 L3 Default 65
    Bundle-Ether1.75 L3 Default 65
    Bundle-Ether1.100 L3 Default 65
  Platform Information:
                  * Bundle Summary Information *
Interface: Bundle-Ether1 Ifhandle: 0x08000160
Lag ID: 1 Virtual Port: 255
Number of Members: 3 Local to LC: Yes
Hash Modulo Index: 3
Member Information:
LON Interface ifhandle SFP port slot remote / rack_id
Te0/1/0/0 0x02000140 0 12 0 1 0/0
Te0/1/0/1 0x02000180 1 13 0 1 0/0
Te0/1/0/2 0x020001c0 11 2 0 1 0/0
                   * Bundle Table Information *
[NP 0]:
   Unicast (Global) LAG table
idx local LON VQI port
   1 0 0 12 0
   2 0 1 13 0
   3 0 2 11 0
[NP 1]
   1 0 0 12 0
   2 0 1 13 0
   3 0 2 11 0
[NP 2]:
   1 0 0 12 0
   2 0 1 13 0
   3 0 2 11 0
[NP 3]
   Unicast (Global) LAG table | Multicast (Local) LAG table
idx local LON VQI port | idx local LON VQI port
   1 0 0 12 0 1 1 2 11 0
   2 0 1 13 0 2 0 0 0 0
   3 1 2 11 0 3 0 0 0 0
[NP 4]:
   1 1 0 12 0 1 1 0 12 0
   3 0 2 11 0 3 0 0 0 0
[NP 5]
   1 0 0 12 0 1 1 1 13 0
   2 1 1 13 0 2 0 0 0 0
[NP 6]
   1 0 0 12 0
   2 0 1 13 0
   3 0 2 11 0
[NP 7]
   1 0 0 12 0
   2 0 1 13 0
   3 0 2 11 0
xthuijs
Yeah 5 flows is not enough to create enough spread.
You could use the show cef exact route and or the bundle bundle-hash commands to findout which path or member a flow owuld take. Note however that there was a bug in these show commands if you are not running 423 with pack2.
Also have you maybe found the asr9000 loadbalancing architecture?
https://supportforums.cisco.com/docs/DOC-26687
‎it holds a lot of detail on the LB architecture.
xander
20 flows and a bit better result:
IOS-XR               Monitor Time: 00:00:08          SysUptime: 133:33:44
                     Last Clear:   00:00:06
Protocol:General
Te0/1/0/0             11794         14977             0/44696         0/44484
Te0/1/0/1             10682          8786             0/37924         0/25456
Te0/1/0/2             18243         16958             0/44596         0/57579
Can the ASR9K more or less normal balance on uneven number of links?
Yup, that confirms the suspicion that the entropie in your flows was too little.
You'll also notice that instead of using, sequential addresses for your test flows using more randomized L3 and L4 combo's (especially random high source ports to simulate clients), the spread will get better too.
We use a hash result of 256 buckets, these buckets are shared over the members you have.
So the spread, when entropie is good enough, will be a near equal spread. 20 flows is likely not good enough to produce that spread. In non facto 2 number of members with a facto 2 number of buckets, the spread will never be a perfect x/members.
In older releases we only had 8 buckets which inherently means that a non facto 2 number of members will
be problematic in terms of member loading.
Make sure you verify this with either XR 4.2.3 and smu pack2 or XR 4.3.1
regards
xander
