08-18-2020 05:16 PM
Hello Expert,
Hi have to configure a port-channel on a Cisco ASR1006 using five (5) ports.
The lacp max-bundle command show a muximum of 4 port per bundle.
Is this Plateforme dependent or Software dependent ?
Is-it possible to use for that chassi more that 4 port with PAgP ?
Thanks In advance for your Answer.
Zanga
08-19-2020 07:07 AM
In general Port-channel will be bunder even number as good practice.
like 2 - 4 -6 -8 so on.
i do not see any Limitation as mentioned max 4
General MEC Guidelines should apply when you buiulding LACP -
i do not recall - but as i remember one of the cisco live session it was mentioned max 14 ports.
08-21-2020 05:06 AM
