Maximum lacp max-bundle on asr1006
O.Zang
Beginner
Beginner
Hello Expert,
Hi have to configure a port-channel on a Cisco ASR1006 using five (5)  ports.
The lacp max-bundle command show a muximum of 4 port per bundle.
Is this Plateforme dependent or Software dependent ?
Is-it possible to use for that chassi more that 4 port with PAgP ?
Thanks In advance for your Answer.
Zanga
2 REPLIES 2
balaji.bandi
VIP Guru VIP Guru
VIP Guru
In general Port-channel will be bunder even number as good practice.
like 2 - 4 -6 -8 so on.
i do not see any Limitation as mentioned max 4
General MEC Guidelines should apply when you buiulding LACP -
i do not recall - but as i remember  one of the cisco live session it was mentioned max 14 ports.
BB
Hi BB,
Thanks for your Answer,
on the ASR1006 CLI the " LACP max-bundle" command offer choice from 1 to 4.
and i am not able to add more that 4 port on a bundle.
I saw this link:
https://www.cisco.com/c/en/us/td/docs/routers/asr1000/configuration/guide/chassis/ce-xe-3s-asr1000-book/ce-ieee-link-bndl-xe.html
But ip not sure if this limitation is on hardware or software.
Thanks again.
Zanga
