ThomasD86
Beginner
MC Lag betweeen ASR 9k
I am trying to configure this scenario between two ASR 9k but, I cannot get the standby link to work, the status of the LACP link is always "Link Defaulted; LACPDUs are not being received from the partner"
The scenario is the following: Leaf and spine topology with 2 NCS 5508 routers acting as a spine and 2 ASR9906 acting as leaves. The configuration is the following:
Active PoA:
redundancy
 iccp
  group 100
   mlacp node 0
   mlacp system mac 1.1.1
   mlacp system priority 1
  member
    neighbor 172.16.0.49
   backbone
    interface HundredGigE0/0/0/1
    interface HundredGigE0/0/0/2
Standby PoA:
redundancy
 iccp
  group 100
   mlacp node 1
  member
    neighbor 172.16.0.48
   backbone
This works, the output of the "show iccp group 100" shows me the domain is up and running.
Then the two Bundles:
interface Bundle-Ether100
 mtu 9212
 lacp switchover suppress-flaps 300
 mlacp iccp-group 100
 mlacp switchover type revertive
 mlacp switchover recovery-delay 120 sec
 mlacp port-priority 1  <<<<<<<<<<<This is changed to 2 on the standby router.
 mac-address 2.2.2
 bundle wait-while 100
Finally the two attachment circuits, same configuration on both routers:
interface TenGigE0/1/0/7
 description *** MC LAG ***
 bundle id 100 mode active
On the standby router though, I get this message:
BM-DISTRIB[1288]: %L2-BM-6-MEMBER_COMPATIBILITY : Interface TenGigE0/1/0/7 in Bundle-Ether100 is incompatible with the bundle operational state; link is not using LACP but bundle is running mLACP
BM-DISTRIB[1288]: %L2-BM-6-MEMBER_COMPATIBILITY : Interface TenGigE0/1/0/7 in Bundle-Ether100 is no longer incompatible with the bundle operational state (link is being removed from the bundle)
I cannot figure out the first of the two messages "Link is not using LACP" when I set the configuration to active.
This is the output of "show bundle Bundle-Ether 100" on the active router:
Bundle-Ether100
  Status:                                    Up
  Local links <active/standby/configured>:   1 / 0 / 1
  Local bandwidth <effective/available>:     10000000 (10000000) kbps
  MAC address (source):                      0001.0001.0001 (Configured)
  Inter-chassis link:                        No
  Minimum active links / bandwidth:          1 / 1 kbps
  Maximum active links:                      64
  Wait while timer:                          100 ms
  Load balancing:
    Link order signaling:                    Not configured
    Hash type:                               Default
    Locality threshold:                      None
  LACP:                                      Operational
    Flap suppression timer:                  300 ms
    Cisco extensions:                        Disabled
    Non-revertive:                           Disabled
  mLACP:                                     Operational
    ICCP Group:                              100
    Role:                                    Active
    Foreign links <active/configured>:       0 / 1
    Switchover type:                         Revertive
    Recovery delay:                          180 s
    Maximize threshold:                      1 link
  IPv4 BFD:                                  Not configured
  IPv6 BFD:                                  Not configured
  Port                  Device           State        Port ID         B/W, kbps
  Te0/1/0/7             Local            Active       0x0001, 0x8001    10000000
      Link is Active
  Te0/1/0/7             172.16.0.49      Configured   0x0002, 0x9001    10000000
      Link is down
This on the standby:
Bundle-Ether100
  Status:                                    Down
  Local links <active/standby/configured>:   0 / 0 / 1
  Local bandwidth <effective/available>:     0 (0) kbps
  Load balancing:
    Hash type:                               Default
  LACP:                                      Operational
  mLACP:                                     Operational
    ICCP Group:                              100
    Role:                                    Standby
    Foreign links <active/configured>:       1 / 1
  Te0/1/0/7             Local            Configured   0x0002, 0x9001    10000000
      Link is Defaulted; LACPDUs are not being received from the partner
  Te0/1/0/7             172.16.0.48      Active       0x0001, 0x8001    10000000
Could anyone please advise?
0 REPLIES 0
